查看: 2806|回复: 9
求大师帮忙
发表于 2014-11-24 18:43:39 | 显示全部楼层 |阅读模式
1 I$ R8 c8 E1 G" b2 W/ G: j9 w1 F6 V0 n3 y, k# Z  v
我要放在数控上车一个圆弧R30,外圆是140,圆弧底径是110,圆弧宽度是30,圆弧刀是R5,工件长度为45,请问怎么编程
, m6 \6 D* e5 K3 ^9 v
发表于 2014-11-24 19:06:04 | 显示全部楼层
这个用不到大师,翻过数控书的都可以。。。
回复 支持 0 反对 1
发表于 2014-11-24 20:12:28 | 显示全部楼层
粗车
5 o5 n% e  g0 |# B4 S# l5 o
发表于 2014-11-24 20:17:36 | 显示全部楼层
N130G0T0101 G54
$ X; c  d1 J+ n. [N140G97S300M03
# ]5 b. w4 |0 ]& h& r7 c! }2 YN150G0X140.4Z8.M80 }: i; I, C) H5 f6 a, i
N160G99G1Z7.5F.125
: r$ E5 ^$ M3 k) `0 UN170Z-7.5
/ b, E- ~2 @. R: b8 ]+ yN180G3X138.4Z-10.566R5.2
; M% n  B3 J8 S; YN190G1Z-34.434
1 B" F+ k& n9 k. @8 L8 \) h' {6 g/ hN200G3X140.4Z-37.5R5.29 Q( j- m2 ^/ N7 p. @
N210G1Z-45.& F9 `/ {7 Z+ z9 p& m
N220X143.228Z-43.586
! n* o( L3 ?8 Y; p% gN230G0Z-10.161, `  ]% G& P" f. R/ Z
N240X139.775% `& C  v6 a$ `8 t% L" {
N250G1X138.8Z-10.271
& V7 j, ?. b( @7 ?N260G3X136.4Z-11.599R5.2- d& E0 L/ w, p; W7 D9 A. x6 f
N270G1Z-33.401
& A  [( u! j3 t' i' T+ I! ^N280G3X138.8Z-34.728R5.2. ]' K/ C, {2 c( C4 m! n: b% M
N290G1X141.628Z-33.315
0 m7 t  \* s, G: qN300G0Z-11.471# e1 c$ M0 n( N: N& M+ d1 @, b
N310X137.797
  Z4 q; \) N$ _, Y: F5 W2 b$ r9 lN320G1X136.8Z-11.434
" i- E. d/ O: H  NN330G3X134.4Z-12.211R5.2
. A, w5 r% }4 V$ A* \" \# o  gN340G1Z-32.788
3 W" c0 |" ^) k. n7 HN350G3X136.8Z-33.566R5.2( w7 v' w. Z$ o1 ?& S7 s) t
N360G1X139.628Z-32.151
" S7 g, q7 y3 g2 D3 p/ CN370G0Z-12.263/ {$ X& p& y3 i! Q7 d
N380X135.754
1 f/ a% L* w1 O7 p7 [2 J+ U4 B, Q8 hN390G1X134.8Z-12.1138 y" |5 `3 O8 s
N400G3X132.4Z-12.56R5.2
# `; N4 ^$ B3 E( s. W( H& JN410G1Z-32.44
0 o$ P! {3 t% XN420G3X134.8Z-32.887R5.25 N% \7 D" |) l' J- U$ I
N430G1X137.628Z-31.473
5 b7 u! v3 O2 O( u2 N1 v* kN440G0Z-12.753& `) K' D. e: H7 ^) u) D
N450X133.671# e, D, I/ |6 p3 D! G' M- ?6 F; Q
N460G1X132.8Z-12.508# L3 U" @, G, n9 S# \: G. f
N470G3X130.4Z-12.696R5.2
+ \4 A# Z& m7 z1 x, D! g9 B6 TN480G1Z-32.304
% @+ \% _! z" b& B7 ^& f1 ^N490G3X132.8Z-32.492R5.2
' V5 M. {( B! ]2 ^9 xN500G1X135.628Z-31.078
4 P* v% D& O+ ?% [& C% vN510G0Z-13.019 M  X9 O' m5 |5 Q
N520X131.559
9 F- X" k, `4 p9 x* PN530G1X130.8Z-12.685
+ M5 ~, M8 C4 h1 @N540G3X130.Z-12.7R5.2! Z2 J$ x& E- t, f# j% R7 V: U
N550G2X128.4Z-12.733R9.8
" T# ^$ E& l4 @! X) s9 HN560G1Z-32.267
2 |0 q- m4 W; X1 oN570G2X130.Z-32.3R9.8
8 p1 S+ B0 l7 m/ U  o  Y# fN580G3X130.8Z-32.316R5.22 g- _: K4 u* d1 E( p" x
N590G1X133.628Z-30.901+ E4 p: ^+ Y5 E  h: j4 P
N600G0Z-13.05
* }* }5 H# O% u. z# \& TN610X129.549
6 D4 W; N7 `6 ?$ N$ \N620G1X128.8Z-12.718# @, C. u3 U! O
N630G2X126.4Z-12.867R9.8
! _; g5 H  U  t6 i% \; e: [N640G1Z-32.133  u0 v. L1 x; a
N650G2X128.8Z-32.282R9.86 m, u: L. L7 z( w' v0 z
N660G1X131.628Z-30.867
. Y. v6 x; u" Q/ i8 J  G! JN670G0Z-13.123
9 E* A; c3 ~  q. v* [N680X127.613; ~7 c/ B" N+ h
N690G1X126.8Z-12.831
8 F1 l% z2 w) f& m% D6 yN700G2X124.4Z-13.108R9.8' U8 Z  k8 p/ p5 }4 l
N710G1Z-31.8916 l' ~4 r8 s7 d
N720G2X126.8Z-32.169R9.8# u6 z, U6 T( `+ U) L. K
N730G1X129.628Z-30.754+ s$ z# C5 d  ~4 y. \
N740G0Z-13.298
- }% p' O4 J! @" D8 NN750X125.669+ e2 W( \! w! _
N760G1X124.8Z-13.0512 C6 n7 L- ]" L$ Z
N770G2X122.4Z-13.467R9.80 ]9 s: p1 P2 W9 ]$ {9 ^' u  [
N780G1Z-31.5337 A; D( r7 L% e. Z+ F/ e
N790G2X124.8Z-31.949R9.83 ~1 Y( `. ]0 _* r& A3 @* g
N800G1X127.628Z-30.535
$ l; `) C4 I6 a1 p& n: U/ E9 Q1 mN810G0Z-13.584
: s6 I, n+ L2 e2 tN820X123.717
( p! G; I3 j' f4 e/ O; U) S: _: vN830G1X122.8Z-13.385
, w: w: G( Z5 V, V* F) TN840G2X120.4Z-13.956R9.8; R' q5 l' p+ m
N850G1Z-31.044
2 ~' j% p0 P+ [, w3 F5 R4 G+ L* cN860G2X122.8Z-31.615R9.8
0 P' [+ T1 A+ Z& [9 r. n: B, E4 vN870G1X125.628Z-30.201
! C8 t0 Y( ~, a5 HN880G0Z-13.993( V0 \$ f' d! L! b# t$ u0 o; p
N890X121.756
) A) z# Z  Q; D8 tN900G1X120.8Z-13.847! c3 ^" U( Z! x# r  f# b3 G
N910G2X118.4Z-14.601R9.8
+ _! u5 w& E0 UN920G1Z-30.399  z7 g" w. [% @
N930G2X120.8Z-31.154R9.87 G, ?2 f0 P7 O! g7 x5 \
N940G1X123.628Z-29.739
* s$ H4 q0 r* ?! U+ d$ ]* p) Y; PN950G0Z-14.546
( e) n' N  ~+ E  nN960X119.7844 T& e2 d' |4 ?& k
N970G1X118.8Z-14.458  ?) j3 g( Z0 I9 t6 j: Y% P
N980G2X116.4Z-15.443R9.80 v1 f& f9 L  `  c8 u/ I
N990G1Z-29.557
" F% l' o4 L# Z5 YN1000G2X118.8Z-30.543R9.8- A. S, a% n2 M
N1010G1X121.628Z-29.1287 n# A+ x; G* i$ `
N1020G0Z-15.2792 |7 G8 {; ]4 I
N1030X117.7990 I/ r8 }1 _7 P4 T: R2 v
N1040G1X116.8Z-15.256
9 i' L4 C, H' jN1050G2X114.4Z-16.567R9.8
& v4 w) J0 I% R- f! ]5 yN1060G1Z-28.433# L9 N) M7 p: c+ q+ A
N1070G2X116.8Z-29.744R9.87 ]' x, e8 ?8 l$ g
N1080G1X119.628Z-28.33
# A( d1 `" G, H- t( A; RN1090G0Z-16.262
' z. P; p  @! ^N1100X115.795
0 q1 d- ~) V1 s; yN1110G1X114.8Z-16.313
3 r) ^# v: q* Q8 eN1120G2X112.4Z-18.187R9.85 s7 i! Y$ a( p
N1130G1Z-26.813
6 y7 E' @# q! d6 \N1140G2X114.8Z-28.687R9.8
9 |" S  _; @3 g- Q  S9 W" ON1150G1X117.628Z-27.2733 o% D  \2 o0 g6 i* E4 k
N1160G0Z-17.66& Z7 f$ I$ T/ Z+ m
N1170X113.768 K% R& O; A: m& F0 _: |; r9 @9 u* P
N1180G1X112.8Z-17.801. {4 j8 O3 J" r, M0 ?$ K% N" s' {
N1190G2X110.4Z-22.5R9.8
& R, q0 ?& ^- Z( uN1200X112.8Z-27.199R9.8
  `2 m6 h7 r# t4 ?; N: }/ uN1210G1X115.628Z-25.785
; t% b" {' V. I( GN1220G0X142.3810 l4 B; _" J, r4 e" K
z150
$ [4 E6 Q& F$ V- z  j% M- VN1250T0100( y! S; |3 Q1 p# {9 ?) j8 w
N1260M30
' c- ]7 J5 F' [9 j%( _$ p. L4 C" W) g5 p6 k3 f8 ?
+ C2 ]1 D  z4 I  T
+ @! Z) T; U9 t) u: ~, _! R/ p' D4 t
发表于 2014-11-24 23:03:54 来自手机 | 显示全部楼层
楼上这是二逼到极致的程序。只要用WHEN或者WHILE再加若干变量,只写几行就够了。你这长篇大论贴出来都懒得看。
发表于 2014-11-25 18:23:15 | 显示全部楼层
不会宏的不能见人了吗? 太打击人了啊) g3 X5 J& W' m9 a, C
发表于 2014-11-25 18:44:19 | 显示全部楼层
工件描述不清楚 不会宏的话 用G71也是可以的
发表于 2014-11-26 10:39:02 | 显示全部楼层
hf2003@yahoo.cn 发表于 2014-11-24 20:17
! ?* |2 S4 \# U6 ^# H) H. XN130G0T0101 G54
3 [5 ~( r4 g. A0 ?: cN140G97S300M036 z+ C5 C( k# i! b* n( I4 O7 H+ c
N150G0X140.4Z8.M8
) N9 o) v# ?5 Q+ _乖乖,,这么长,最好用子程序,,,
发表于 2014-11-26 20:42:22 | 显示全部楼层
G71  二型 可以做
发表于 2014-12-31 16:10:13 | 显示全部楼层
街边¥垃圾? 发表于 2014-11-25 18:23 0 }1 }! W* v8 w- n4 V! Q; D! o/ w, k
不会宏的不能见人了吗? 太打击人了啊
% j) b5 G: U4 Z! ]$ c7 t$ o% ?支持你,有的床子就不支持宏
9 k. e! r$ f) p' P9 y
GMT+8, 2025-1-10 23:46 , Processed in 0.059980 second(s), 21 queries , Gzip On.
