查看: 24575|回复: 52
数控车高级(实操题)
发表于 2006-5-21 14:03:34 | 显示全部楼层 |阅读模式
图纸见附件
( h, `/ _+ c8 _* B/ l* a
一号刀:偏刀
二号刀:切断刀
三号刀:螺纹刀
9 X4 l( V8 a; g
$ ~: |2 O4 W( v2 `: ^1 J, _% x
N10 M03 S2
N20 T0101
N30 G00 X31 Z0
N40 G71 U1.0 R0.5
N50 G71 P60 Q120 U0.4 F50
N60 G01 X0 F30
N70 X2.163 Z-1.873
N80 G02 X12.792 Z-7.26 R15
N90 G03 X25 Z-18 R12.5
N100 G01 Z-35
N110 X28
N120 Z-69.5
N130 G00 X50 Z80 M05
N140 M00
N150 M03 S1
N160 T0101
N170 G00 X30 Z0
N180 G70 P60 Q100
N190 G00 X50 Z80 M05
N191 M00
N192 M03 S1
N194 T0101
N196 G00 X30 Z0
N197 G70 P60 Q100
N198 G00 X50 Z80 M05
N200 M00
N210 M03 S2
N220 T0202
N230 G00 X30 Z-30.9
N240 G01 X15.5 F15
N250 G00 X30
N260 G72 W3 R0.5
N270 G72 P280 Q330 U0.2
N280 G00 Z-17.5
N290 G01 X25 F15
N300 Z-18
N310 G03 X17.857 Z-26.748 R12.5
N320 G02 X15 Z-30.247 R5
N330 G01 Z-30.98
N340 G00 X50 Z80 M05
N350 M00
N360 M03 S1
N370 T0202
N380 G00 X30 Z-30.9
N390 G70 P280 Q330
N392 G00 X50 Z80 M05
N394 M00
N396 M03 S2
N398 T0202
N400 G00 X30 Z-50
N410 G75 X20 Z-65 P2000 Q3500 F15
N420 G01 X10.5
N430 G00 X30
N440 G72 W3 R0.5
N450 G72 P460 Q492 U0.2
N460 G00 Z-34.5
N470 G01 X28 F15
N480 Z-39.412
N490 G03 X15.774 Z-50 R15
N492 G01 X10
N500 G70 P460 Q490
N600 G00 Z-50.98
N610 G01 X10.5 F15
N612 X10
N620 Z-50
N630 G00 X18 Z-50.98
N640 G01 X19.8 Z-51.98
N650 Z-64
N660 X18 Z-65
N660 X17
N660 G00 X50
N670 Z80 M05
N680 M00
N690 M03 S1
N700 T0303
N710 G00 Z-55
N720 X20
N730 G92 X19.3 Z-65 F1.5
N740 X18.8
N750 X18.6
N755 X18.4
N756 X18.3
N760 X18.2
N770 X18.1
N780 X18.05
N790 G00 X50
N800 Z80 M05
N810 M00
N820 M03 S2
N830 T0202
N840 G00 Z-65
N850 X20
N860 G01 X2.5 F15
N870 G00 X50
N880 Z80 M05
N890 T0100 M30
/ `' G4 v+ m" l) ^- c+ |
发表于 2006-5-23 18:49:53 | 显示全部楼层
Re: 数控车高级(实操题)
G00X100Z100                     设定坐标
: c1 ^6 x+ C" ?6 AS2M3T0202                       560转主轴低速正转,2号粗车刀
; ]: Y9 i5 A7 ^3 }- k$ i) n; G7 LG00X32Z2M085 {5 d" {* G) ]" U2 I9 E
G73U14W0R0.007                  2 e6 x4 v; E9 j+ M2 ~3 n7 @1 J# a
G73P1Q2U0.3W0F100
/ P2 }$ J' W6 P' }3 ?, `, aN1G01X0Z0F40
# v& e) d! @" `/ cX2.16Z-1.87( S5 \! m7 @* I. k2 p5 ]
G02X12.79Z-7.26R15F30+ }# h$ p2 y7 O& N% s/ E& z0 g" \( z
G03X17.86Z-26.75R12.5   (如有偏差可将此值适当增大,根据误差来确定)
$ C0 N6 |1 P) g3 aG02X15Z-30.25R5
& I! S# _) n  |2 |G01Z-35F404 u- p, R* U4 m: T. l
X27
% G3 S: _, W6 k6 DX28Z-35.5( {# c% b' W, H5 n. A/ F  M
Z-40" i9 H" U! x8 r& G& _. a
G03X16.45Z-50R15F30     (如有偏差可将此值适当调整,根据误差来确定)
$ S5 g+ T! h: mG01Z-55F40
$ M- w8 ~4 H( S9 o4 HX19.8& T6 p6 k- S4 F3 N
Z-70
+ F2 C! l# i8 U& H. |/ j$ rG00X100Z100M05
1 t) @) E5 D7 z% y2 b/ AM00. d# P. W1 a/ G; ~9 B3 r
S1M3T0101
* F0 e& U2 y" W8 {: ?6 q5 OG0X32Z2M08, g$ }# ~6 q' B5 `' i
G70P1Q2
! X+ ~- H5 J* l- \4 G( GG00X100Z100M05: p! q2 Y4 J1 v
M00
4 z' `) W; P) k" V( e' yS2M3T0303
( n% Z0 i. U2 c% VG00X29Z-52M08! R, `8 ]/ t; G9 g
G76P030060Q10R0.01
6 E* x8 z  I, w, SG76X18.05Z-66P975Q250F1.5
9 y# ]1 q8 D( RG00X100Z100M05/ ?" c0 e8 |5 `6 B2 P. m+ U
M00( T. u. D3 Z$ }/ ^1 e: D) t
S2M3T0404
+ P( q7 w1 Y# [5 K$ j; d! ]G00X29Z-50M08
. I3 y5 R) u7 ]- E' a- ~G01X10.1F40
8 t% c' Y7 Y; j$ v0 Y4 l/ d# d4 {G00X29. q! K( `; y9 ^
Z-51.8& z/ K$ e7 s- ]* s, u  n
G01X10F30
5 D5 ?# Z3 `; q& k) aZ-50
+ l: I  m0 v  M5 T( EG00X100+ S( a. ^$ ?3 A2 S" s% i
Z100M05
& n% {& u# T/ g( W9 ?* ]( V2 q0 HM00
4 }( h- O* O' i; XS2M3T0404
. G$ K$ z1 K/ Y9 S; F  rG00X29Z-65M084 z! m* g: D5 U1 U1 f
G01X0F40$ x7 z5 D! g9 A) A; A, a) _  X9 D
G00X1008 O6 f2 P4 V" U2 D  Q0 T
Z100M050 g; p& |+ |! x# B
T0101$ W: b) m' r9 x  v+ Y0 t
M30# K# i+ u: C0 J9 z( A: _
1号刀为90度,副偏角60度的精车刀;
* Q/ h" ~2 A3 c2号刀为90度,副偏角60度的粗车刀;6 f- e4 i. m6 f& B) m
3号刀为60度的高速钢螺纹车刀;
* V# W" t: l" K8 A" x4号刀为刀宽3.2MM的高速钢槽刀;
) M6 K1 t2 L- E4 [9 c
# S/ f& ]7 h' j. ]这是我用G73编的,请大家多多指教.....
发表于 2006-5-23 18:50:22 | 显示全部楼层
Re: 数控车高级(实操题)
N1 G00X100Z100                     设定坐标
2 K0 X/ G% v. l$ O1 CN2 S2M3T0202                       560转主轴低速正转,2号粗车刀! c4 ?4 V9 X/ l1 e
N3 G00X32Z2                        快速定位
8 E# \% L4 }" J! c- xN4 G90X28.5Z-75F100                 粗车零件轮廓,留余量0.5MM / W4 z+ I% y* K) N) p
N5 G00X28.5
1 g! ^$ M8 `3 i) o/ s5 F# Z4 cN6 G90X25.5Z-35/ Y2 ^4 k9 ~+ Q  I. ^; ^" ?
N7 G00X25.58 l" c1 V5 l+ c; u9 t% q# a/ x
N8 G90X24.44Z-14.35/ y4 l9 B, b  U! c7 |1 |4 S
N9 G00X24.44
% a/ A. l# \1 S8 lN10 G90X20.44Z-10.373 p8 y7 Y; U9 ?
N11 G00X20.44
9 c( A2 S3 ^0 [% F0 T8 AN12 G90X16.44Z-8.25
9 s  Y9 a/ [8 u" K- L+ eN13 G00X16.44/ {; F; w, s2 _) \4 E) p! O
N13 G90X12.44Z-6.86
" O, B( R' S( f# x) Z4 S8 AN14 G00X12.44
& w1 s; C( v2 ^0 ^, aN15 G90X8.44Z-5.35/ |7 ~% X8 N$ P4 I
N16 G00X8.44
& h6 S' |  |$ F% D7 Q! {- d8 h9 @$ t' TN17 G90X4.44Z-3.157 Q& U5 S2 v5 j; z
N18 G00X0.5Z0.13- S' y9 Z; K- z7 e
N19 G01X2.6Z-1.75# I7 ^( c( n9 M4 h: _) p
N20 G02X13.04Z-7.05R14.75
; p& n* i* c; j. l0 T* ON21 G3X25.5Z-18R12.75
3 c1 i5 }" p! x2 Z6 F* }: Q- p6 tN22 G0X100Z100M05                        返回参考点,主轴停止
  d. ^5 z+ n2 H, O; aN23 M00                                        程序暂停6 a& K2 c6 e. g1 X% k, _
N24 S2M3T0404                         560转低速正转,4号切槽刀& _- u8 d$ e3 U0 k
N25 M08                                        冷却液开
$ n# q1 p" ^+ S6 h  NN26 G00X29Z-31.8                       用3个G72粗车循环指令,
1 u4 P7 Z0 D2 p# C( g$ q5 eN27 G01X15.5F40                        对三外轮廓进行粗车,; r' P" ^3 H4 ~' J0 b0 \. @5 G8 e
N28 G00X29                                留余量0.5MM
2 s. z8 U( S( Z  C3 l7 ?2 Z% ^8 M3 xN29 G72W2.5R0.5
7 ~* o- D/ z3 j1 x! U' D2 nN30 G72P31Q35U0.5W0F30- B) F) T, @' r  @- e3 |/ ?/ s7 [
N31 G00Z-18
" r5 q, ~( r5 M, [6 B0 {3 [* wN32 G01X25F40
) w, h  P' p4 u0 v  _N33 G03X17.86Z-26.75R12.5F30
" B) _! P. X0 K* G, @9 U( ~N34 G02X15Z-30.25R5F30
( n3 r- x( y$ o& NN35 G01Z-31.8F40
( S# {8 [0 [4 z. h, F* k! B& t5 YN36 G00Z-51.8
7 K$ |+ O& v$ ]( F3 C& o0 h) v9 sN37 G01X10.5F40: x' J. W9 P& j  H' g% W
N38 G00X29
* G, f$ H( H6 m% k  ?N39 G72W2.5R0.5
7 z, W* W/ a, [5 p- x3 DN40 G72P41Q45U0.5W0F40$ j5 O. |8 Q" {" ~
N41 G00Z-401 F  I8 h( {0 k9 D" J8 `
N42 G01X28F40
9 S, }+ W6 `8 z/ p1 @N43 G03X16.45Z-50R15F30- M% K# s4 d# e5 v4 O- F& s. ?
N44 G01X10F40
  y( ~9 ?3 C$ g/ PN45 Z-51.8! s. o! @0 h/ d7 r" d1 j  n
N46 G00Z-65
" t9 T6 S$ o: Q8 eN47 G01X18F40
( ^/ t  q" M+ C6 s/ NN48 G00X298 J6 o  X4 U0 I- q' b# N" c' I
N49 G72W2.5R0.5! R: ?1 ^7 I. C. d" c- c2 }; P& b
N50 G72P51Q53U0.5W0F405 Z7 {. ]- d9 j$ K7 E( L1 }3 q
N51 G00Z-55
9 W! h# Y3 s7 B7 @N52 G01X19.8F40
+ _/ v1 j+ n- j8 ^/ N- GN53 Z-65
9 \" ?8 f" H0 q7 i8 s. u. i7 kN54 G00X100Z100                                返回参考点
# U0 B! T  ^0 dN55 S1M3T0101心                       1120转主轴高速正转,1号精车刀( K: o- ^$ o8 R- M2 w7 t
N56 G00X-0.5Z2                                  快速定位
; x% R+ M; v2 ^! ?0 G( C' ]N57 G01X0Z0F40                              精车零件轮廓
9 U' Z- b. `6 j  r8 D$ @N58 X2.16Z-1.87
. ?' _5 `( E- H/ VN59 G02X12.79Z-7.26R15F30
/ O% _+ b# ]! T2 iN60 G03X17.86Z-26.75R12.5             (如有偏差可将此值适当增大)) z* q8 a' D0 w. m
N61 G02X15Z-30.25R5
' m' f" l: p; T6 F6 \, W* LN62 G01Z-35F40; }/ S. V& ^9 v3 \9 h( m# m
N63 X27
& H' P% z8 D; g/ U* lN64 X28Z-35.5
% Z# v4 F4 j7 T6 r- y- ^N65 Z-40                               (如有偏差可将此值适当调整)
" l1 D; l& q1 y6 nN66 G03X16.45Z-50R15F30- y) ^2 T, V3 ^7 {" |8 h
N67 G01Z-55F40
' H+ P6 ~! Q" S% l2 |0 [, ]. b/ jN68 X19.83 y# n% M7 h! d( V& {
N69 Z-65+ C) O, A4 P6 e/ Z- u$ f
N70 G00X100Z100                                 返回参考点
9 L/ ~. K1 V; c$ xN71 S2M3T0303                           560转低速正转,3号螺纹刀4 `5 R# C9 l# j: y) B# i4 @
N72 M08                                          冷却液开
7 h0 q, h, O  Z' Z! ]9 [) YN73 G00X29Z-52                                   快速定位
& O0 W) G) ~$ k3 G# cN74 G76P050060Q10R0.01                       粗精车M20X1.5螺纹
" O/ p$ j9 t$ G+ fN75 G76X18.05Z-66P975Q250F1.5- v9 q( L6 `- }! ^& R  V2 i$ ]
N76 G00X100Z100                                返回参考点
3 a- y1 E1 \$ B  ]$ ~2 lN77 S2M3T0404                            560转低速正转,4号切槽刀
* u# v" c: r5 G- E% `( tN78G00 X29Z-50                                  返回参考点) U5 g: C3 `' U! b# E
N79 G01X10F40                                  精车 10槽处6 a3 F0 h) \, J
N80 Z-51.8
' L- g5 R, M, s# b+ fN81 G00X100+ }! k  _  g, }# _2 k4 `
N82 Z100M05                                返回参考点,主轴停止
! i% l) x4 b7 D- ]N83 M00                                           程序暂停
1 @: [7 x; R$ x0 L" IN84 S2M3T0404                            560转低速正转,4号切槽刀      ; s3 r9 N$ P+ w& X; k
N85 G00X29Z-65                                    快速定位
( e& W6 Z. I$ F! e) r- L4 |3 BN86 G01X0F40                                        切断工件1 C& ?* H* g3 x8 O
N87 G00X100
$ e' s. G% {& a$ }! n8 N& TN88 Z100                                 返回参考点,主轴停止% U8 m- m* L/ x0 U  V, A
N89 M05  ^! K8 X0 \0 w/ P4 O  F2 g& z
N89 T0100                                   返回基准刀9 P8 F' h, Q, Y  Y
N90 M30                                     程序结束
- V$ ?( m+ h8 N. J& ~1 u1号刀为90度,副偏        角60度的硬质合金精车刀;+ m# e! Y7 g1 f/ A
2号刀为90度,副偏角6~8度的硬质合金,粗车刀;4 G3 o5 c3 v2 B: V5 V' h
3号刀为60度的高速钢螺纹车刀;
9 G; Q8 _% B; D4号刀为刀宽3.2MM的高速钢槽刀;9 f7 P- W) Q  O2 S* A
* i6 R+ L* Q. z" ^: B
注:第一件试切时,应在设置坐标(G50)处预留余量0.5MM。试切一遍后,再根据实际尺寸的偏差进行调整,把尺寸控制在公差范围内。9 a# s# \3 a5 l! d
发表于 2006-5-23 18:52:14 | 显示全部楼层
Re: 数控车高级(实操题)
这是用G90和G72编程的,比用G73的粗车加工时间提高差不多两倍以上.3 Q+ }  R$ h/ A7 C
大家可以试试看....
4 R" G* z- E  E# G1 Z. t
# J& W. [1 _6 q2 @请大家多多指教.....
发表于 2006-5-23 18:56:30 | 显示全部楼层
Re: 数控车高级(实操题)
因为不是用圆心编程,所以加工出来在圆球的部分和R15的部分会存在一定的误差.' v/ S+ v# t, ^
本人用直接修改坐标的方法来进行补偿,用千分尺测量可以控制在公关范围内.: \' F  ~; L7 E
7 @1 R2 i6 t! I: K; @. `- N0 }  u; W* @9 Q6 `) D7 H
/ d4 Z$ @& f! _: l/ i7 N楼主可以做个朋友吗,我的QQ是84079975
 楼主| 发表于 2006-5-23 20:14:29 | 显示全部楼层
Re: 数控车高级(实操题)
我认为: S指令跟T的指令最好是分为两段来写较安全一些
$ E4 j% W& s& O! f如 N1 M03 S500
1 |% y+ j' ?7 L- |2 j6 G+ b    N2  T02026 E8 D) {  x* r8 A/ Z
; \/ A- w3 M# \$ W8 [6 Q. x+ X( a. k二楼的程序 G73后开始的第一行程序不能有Z 方向的,G71也一样,而G72后的第一行程序不能有X方向的。如果该工件用G73的话我建议分两段来要好一点,速度会快点。 还有我想问一下GSK980T有G76的吗?2号刀用90度,副偏角60度的粗车刀,强度够吗?  M  W: e2 s$ I( c4 I' [
* f' ~& }- }& [7 T  C
对于三楼的我觉得用G71要比用G90方便和省时间
发表于 2006-5-23 23:47:13 | 显示全部楼层
Re: 数控车高级(实操题)
实际加工用循环指令是比较少的,用单一循环指令比较多.
' l3 I8 d) o4 p) O% T* E9 Y& H如果就单件加工来讲,用G71和G72会方便一些.
1 `: [# \2 S7 M6 N# a, W; k7 F6 |, g2 j2 `( _( T  p. Z& p$ L
用G90和单段指令编程会麻烦一些,但在实际加工中效率就会体现出来的.: T+ H2 j3 `+ w
8 K# d6 D+ J0 m$ F. }为了避免与工件产生干涉,所以副偏角要大一些.
: u( ~4 a- S- v( N$ R# M, u- NG73的第一段是可以有X和Z的,你可以试一下阿!!
) ?0 v# |2 r$ n  q
+ B- T4 B: ?8 A8 D) g把S指令和T指令分开或合在一段都问题不大,系统会先S\T\G的顺序进行的.
发表于 2006-5-23 23:47:47 | 显示全部楼层
Re: 数控车高级(实操题)
各位高手们多多交流阿,学习中...
 楼主| 发表于 2006-5-24 00:04:53 | 显示全部楼层
Re: 数控车高级(实操题)
不好意思,我因为在实际加工中没有用过G90,我只是从编程的角度来讲的,有机会我一定要试试。 阿承:你也在汕头? 我QQ241150329,有空的话大家一起研究
发表于 2006-5-24 12:43:30 | 显示全部楼层
Re: 数控车高级(实操题)
对阿,我是澄海的.不过现在在广州,楼主还要向你多多学习呢!!
GMT+8, 2025-2-20 04:40 , Processed in 0.084371 second(s), 16 queries , Gzip On.
