查看: 1823|回复: 0
求圆柱形双出头双向自保持电磁铁
发表于 2014-5-22 10:02:20 | 显示全部楼层 |阅读模式
7 z1 N  c9 b; r8 l* [* K" A4 x4 O( d
# I5 p. f" ~9 _( w5 |2 l2 w7 h电压C24V,行程6mm,初始驱动力1000g,自保持力300g,外径小于30mm,阀体高度小于30mm;
" r( g& r, h5 }! m8 }/ L* D0 N
" f/ _) v& R8 @# a哪能买到这种电磁铁( e) x- R: B" V. P2 i9 R  V
. @$ M8 S# X6 d2 i% h" }请多多关照,谢谢大侠们!
GMT+8, 2024-11-15 17:35 , Processed in 0.053271 second(s), 20 queries , Gzip On.
