查看: 2721|回复: 0
关于ansys14.5的空间桁架
发表于 2014-3-5 20:03:48 | 显示全部楼层 |阅读模式
初学ansys,各种不懂。想做一个空间桁架受力分析,然后代码写了,导入ansys后加载,实常数,单元类型,材料属性都定义了,就是不求解,也查不到错,求大神们指教T^T. j- Q; i% O" {2 C) B. q
问题是这样的:
2 C+ ]0 S% I7 o! a- n% D. h# I线L1,L9受Y负方向的均布载荷1000N/m,关键点7,15,19全约束,受重力场的影响下看它的变形和应力。/ U7 X: [6 Z' Y5 O( q4 h. W
这个是我写的APDL代码6 C0 o6 a, Q! J, `
!桁架分析
. G8 ^- @  R1 vFINISH$/CLEAR$/PREP76 Y2 t4 @8 I3 b, g; f  {) A  G- N' C
!方铝截面5 `$ I& S& R6 `7 C/ R9 Z
ET,1,BEAM4' j: @6 ?6 ^% r# r3 A' e) T
R,1,0.902E-4,0.534E-8,0.534E-8,0.02,0.02
7 j2 q- w/ f2 J4 bMP,EX,1,6.9E10  x1 M/ I) v5 A7 E( t7 B
MP,PRXY,1,0.33
6 ^4 ], p, Y- W* Q* b8 ?MP,DENS,1,2900* K( s7 K4 `1 Z) b/ b# o5 r
SECTPYE,1,BEAM,HREC: G; M, Y; K) F2 ^6 r  \
SECDATA,0.02,0.02,0.0012,0.0012,0.0012,0.0012/ ?6 s7 n5 O+ H3 j
!桁架线体模型1 K5 G( e+ r5 m- x/ A
K,1$K,2,0.140$K,3,0.360$K,4,0.680$K,5,0.930$K,6,1) `) d/ D, z8 G- \+ p" E% ~. i) z+ J* ^
K,7,0.680,-0.150$K,8,0.680,-0.1204 u3 P, N  P8 A2 \' y1 S) z$ Z1 `" T
L,1,2$L,2,6$L,4,7$L,2,7$L,5,7
/ [3 P+ h8 P$ u& d# lK,9,0,0,-0.360$K,10,0.360,0,-0.360$K,11,1,0,-0.360$ u1 o+ [9 M1 R  A3 A: L# D% Z
K,12,0.140,,-0.360$K,13,0.680,0,-0.360$K,14,0.930,0,-0.360* d1 N5 x$ ]3 \* ]5 Y. r
K,15,0.680,-0.150,-0.360$K,16,0.680,-0.120,-0.360
6 U" Q% m2 O+ q9 r; {L,1,9$L,3,10$L,6,11$L,9,12$L,12,11$L,13,15
3 z" e  u$ x/ o7 z. o" iL,3,10$L,12,15$L,14,15
- \9 l, S- N3 M; sL,8,16* T3 \( J/ e5 b' t
K,17,0.356,-0.060$K,18,0.356,-0.060,-0.360
" r( M& d9 Z1 G8 iL,17,186 K0 z( F( u! Q4 L& x2 ?6 l
K,19,1,0,-0.180
4 G' P# @2 }7 N+ ^!分网
/ t# e& D( P( E$ i0 l5 P9 YLESIZE,ALL,,,10
9 m- T( Z9 D' ~( O6 \5 qLMESH,ALL
* ?/ v. q# l2 D8 SFINISH
" j3 K; a( O- j4 e% q6 g: r8 o3 N* E" E+ N5 U& L
究竟是ansys14的BEAM单元的问题还是我自己的问题,反正我就是不能用梁单元在ansys里求解。用solid95单元的话,这个结构分网困难,难以计算,简化就不求解,求给位大神指点,小弟感激不尽T^T
% [' ^: u+ ?4 b1 `. ~在线急等% W! @; {/ u8 O0 v. ^! L, l
GMT+8, 2025-4-4 18:25 , Processed in 0.053875 second(s), 18 queries , Gzip On.
