发表于 2014-2-6 11:52:55
显示全部楼层
1 通用零部件Common Parts1 ! i6 z6 G! O0 @; i e" [% R* W
1.1 紧固件及连接件Fasteners and Joints1 ; a) I) F5 T- J4 r5 A4 P) N
1.2 轴承Bearing19 9 E. _5 C3 Z0 @* q2 \/ ~
1.2.1 滑动轴承Sliding Bearing19 6 h! J% y, K. k4 z7 i: x2 E9 X
1.2.2 滚动轴承Rolling Bearing24 R& o+ v H% V7 O
1.3 联轴器、离合器和制动器Coupling,Clutch and Brake30
( E& t1 b- J5 m. ]4 B8 A 1.3.1 联轴器Couplings30
# J3 D c0 P1 t6 U9 p 1.3.2 离合器Clutch33 3 Z* n. G( b! Y' ^, M
1.3.3 制动器Brake36
. n2 T' _( O0 _5 P% l. S4 K, |& z" }( k 1.4 弹簧Spring41
* x6 S# I* w8 h, G4 a$ G. e2 v 1.4.1 圆柱螺旋弹簧Cylindrical Spiral Spring41 - r( I. Z& f7 S8 y; V1 P
1.4.2 圆锥形螺旋弹簧Conical Coil Spring 43
2 |% M; w, m5 @/ a 1.4.3 碟形弹簧Disc Spring 43 5 A" Z2 k- b3 o9 k0 d* L$ v
1.4.4 片弹簧Leaf Spring 44 ! \2 |$ o' F, N
1.4.5 板弹簧Plate Spring45
* S: e+ s, {- b" K2 { 1.4.6 扭杆弹簧Torsion Bar Spring 45
& Z& ^' m) G; |$ e! W6 z1 A 1.4.7 空气弹簧Air Spring46 , `" Z! L; J, c6 L
1.4.8 油气弹簧HydroPneumatic Spring47
+ G2 M7 A, T3 K0 Z5 ` k9 l& h 1.4.9 环形弹簧Ring Spring 48
+ E2 c s9 h+ Z+ ^. g$ z 1.4.10 橡胶弹簧Rubber Spring49
1 K: z" p) U9 o! @ 1.4.11 发条弹簧Clockwork Spring50 ! ]* y( q7 R; M$ t) C* M
1.5 操作件Operating Parts51
/ [3 C2 d9 _4 @- F 1.6 润滑装置Lubricating Device53
4 i2 Z3 r' q+ A5 A* n+ g7 w% t) E2 动力装置Power Plant55
# R, ^+ {! ^7 s2 R' \ 2.1 内燃动力装置Internal Combustion Power Plant55 % h1 K9 M M: \ ~3 r8 q9 w1 D
2.1.1 内燃发动机Internal Combustion Engine55 * }) G6 [8 K4 W( w9 p
2.1.2 内燃机曲柄连杆机构零部件Parts of Engine Crank Link Mechanism60
/ C, W$ X6 c6 t; l+ e4 t. m 2.1.3 缸体及汽缸盖Cylinder Block and Cylinder Head64
% D' a9 \9 o( x& n5 u* c! Z' { 2.1.4 配气机构和进、排气系统Admission Gear,Intake and Exhaust System66
& U( W+ K' S% I 2.1.5 发动机增压器Engine Supercharger68 - I5 K' E" R3 A
2.1.6 燃油供给系Fuel Supply System 71 . D! m" `5 Q6 M. f5 a
2.1.7 冷却系统Cooling System73 2 o0 U( V8 z$ `4 M
2.1.8 润滑系统Lubrication System74
* v9 _8 A* t3 z- K$ U. S 2.1.9 点火系Ignition System76 4 M/ s" q, D7 z- F; J! |( L: A
2.2 电力动力装置Electricity Power Plant 79
6 j5 W6 `. i* G6 h# o* r$ B3 机械传动系统及主要零部件Mechanical Drive System and Major Components84
" ~, [0 ~( n1 W; [2 @/ R4 液压传动Hydraulic Transmission173 ) k' ?" S$ K" |! l0 v
5 液力传动Hydraulic Transmission214
e3 }% F+ J7 `9 g6 w. b6 起重机械零部件Components of Hoisting Machinery227 * ?4 L X8 J1 `# P
7 机械设备结构件Mechanical Equipment Structural Member239 + ~1 L2 S" Z4 p& G8 G0 e
8 履带式行驶系零部件Components of Tracked Driving System271
! m" @" {2 U. t参考文献28
6 E w$ M, t B8 a; M( w+ |3 F. s: g2 a
当当网找到的目录 |
