发表于 2014-1-17 15:45:24
显示全部楼层
本帖最后由 LIAOYAO 于 2014-1-17 15:46 编辑 7 w! \7 c! ?- o6 f' j
: ^6 z( n( Z/ g& L5 Y! NMRC# R* i h$ h% o' ~" [1 C0 `
MRC 5204 CFF 20 mm x 47 mm x 13/16" Shielded, Both Sides, Angular Contact Bearing
& _. X( l% M7 j i0 Z/ v: AMotion Item No.: 000441098 l4 V5 q6 p9 ^1 }$ W. _
Manufacturer Part Number: 5204 CFF
: c; Z- S( g0 OManufacturer Description: 5204 CFF BRG (OLD 5204 SBKFF)" n O, F4 A' C: w r8 Y/ D
$ C% {0 e* S4 X; [6 W! O! aInside Diameter:20 mm8 ]& p+ {, _8 R- F, y3 K' ^
Outside Diameter:47 mm$ s0 Y' T" j, M( d( L
Width :13/16"4 \4 u0 {+ y% t8 ]9 X1 O, p+ y; W+ Q9 B
CLOSURE TYPE:Shielded, Both Sides
. c4 z2 X' L4 K2 C$ J: hSnap Ring:No% w2 E4 ]* L8 ]+ ^9 ?* Z' r
ROW: Double Row @$ D2 u+ J# N! G+ F0 N
Type Of Bearing:Angular Contact
7 N0 L& A1 g" t) e( E2 v! L# [ACTUAL MFG SERIES:3200 / 5200 - Light Series+ c4 E. D4 V6 Y0 g, z/ z5 d
CATALOG SERIES:3200 / 5200 - Light Series* N- U/ O; h' h, e: B
CATALOG TYPE: Double Row Angular Contact - Conrad Type
1 o. |; T0 k+ uINTERNAL CLEARANCE TYPE:Normal Fit
; j- N4 `3 z2 h2 {2 HMFG PART NUM:5204 CFF
# r" ]1 k8 ~) _) O3 |/ [% @ALTERNATE PART NUMBER:MRC 5204CFF, MXME20146, 0103004, 5204 CFF |
