标题:
发那科310I系统的有没有人用过啊?
[打印本页]
作者:
宵夜有风
时间:
2014-1-14 13:51
标题:
发那科310I系统的有没有人用过啊?
发那科310I系统的有没有人用过啊?谁有编程手册?好多指令不太懂啊~~求大神
作者:
gongfei2419
时间:
2014-1-14 18:56
30i\31i吧
作者:
HC小丁
时间:
2014-1-14 19:32
gongfei2419 发表于 2014-1-14 18:56
( ?9 N& l/ R6 I# z# o
30i\31i吧
: I7 ]0 [# Y) V. Y/ N
有300i、310i、320i都有,310i好像是触摸屏的了和30i、31i基本操作一样,与0I有所区别
( c" K) b! H; [ r" j. p
/ g* }; Q( R( c- Z: N+ d5 U; U- k
作者:
shixzc
时间:
2014-1-15 11:59
GE FANUC 310i SERIES CONTROL
* x2 ~" C& @$ r$ w3 z. N; y6 j4 A# |
PREPARATORY FUNCTION
7 {) ?0 W- l D9 }' R0 d' D
The preparatory function codes are used to establish modes of operation. The following G codes are listed in their numeric sequence and also by group. In any group, one G code will cancel the other. The * denotes the default code when power is applied to the control.
: ]. L8 w6 X+ r2 N6 q
9 W# M7 T. K2 F: \
Up to five G codes may be programmed on one line. If a line contains conflicting G codes, such as G00 G01, the last one read will control, but not in all cases.
9 q& l1 U0 @+ e, H5 H! U
CODE GROUP DESCRIPTION MODAL STD./OPT
* e; G& u1 F5 Q* L5 ~
3 e: [7 D4 h0 L$ O; q
G00 01 Point to point positioning YES Standard
0 R8 n4 @8 I5 P, U; h" l! h* B
G01* 01 Linear interpolation YES Standard
$ _. a- u; I% B! p
G02 01 Circular interpolation-CW Arc YES Standard
" {& Z; j" h: J: [. x
G03 01 Circular interpolation-CCW Arc YES Standard
6 b( P) ^- D9 n, D0 r3 |$ ]
G04 00 Dwell NO Standard
: ]' z% Z' j! F
G09 00 Deceleration NO Standard
( s6 |! S7 F* V2 u; `1 }* m
G10 00 Programmable data input mode SOME Optional
7 i% c6 K `/ f0 w& |
G11 00 Programmable data input mode cancel YES Optional
4 `% z! a1 [" b, t2 U
G10.6 00 Tool retract and recover NO Optional
& p0 C; I7 v* k0 @
G12.1 26 Polar coordinate interpolation YES Optional
* o- h! P$ l- c7 J ]0 n$ G6 t
G13.1* 26 Polar coordinate interpolation cancel YES Optional
1 M( K8 x: [' p' l# f f+ B8 y
G18* 16 ZX plane selection YES Standard
2 J5 D: y8 y9 _$ ]7 r# U
G19 16 YZ plane selection YES Standard
( N# M) \3 J6 M/ u
G20 01 Turning cycle YES Standard
' k; L P A2 P9 d( k
G21 01 Threading cycle YES Standard
7 X+ _4 w; i, a
G24 01 Facing cycle YES Standard
/ m1 {! w# U; O; _, \
G22 04 Stored stroke check ON YES Optional
. P( x" w0 Q b0 F( E" y1 V( E
G23 04 Stored stroke check Off YES Optional
8 [8 v; {# j: D/ e8 ?% n
G27 00 Reference point return check NO Standard
J* }7 b$ R C
G28 00 Reference point return NO Standard
/ d$ y' g7 d1 Y) i" L
G29 00 Return from reference point NO Standard
( m, }; j# i7 E- z0 Z
G30 00 2nd, 3rd & 4th reference point return NO Optional
+ s4 X' u( r+ U# N7 y
G30.1 00 Floating reference point return NO Optional
7 g8 N, q, k. M# ?5 ]& W* H5 I
G31 00 Skip function NO Optional
5 e$ j4 O- I: p8 w# z% N
G33 01 Thread cutting, constant lead YES Standard
: Y( r$ j: }% m& c$ e/ n
G40* 07 Tool nose radius compensation cancel YES Standard
+ e/ h7 ?* M6 E- e' \, H/ e
G41 07 Tool nose radius compensation Left YES Standard
$ l# c+ U" {; f1 t# ^0 v( E2 Y
G42 07 Tool nose radius compensation Right YES Standard
$ } V3 g4 a( J. ~0 P
G43.7 23 Tool offset compensation (extended tool selection) YES Optional
2 O' ~8 G1 @# I# P
G52 00 Local coordinate system shift YES 2 axis only
9 L0 S7 c: Q) _# E/ K0 X4 q
G53 00 Machine coordinate system selection NO Standard
0 ^0 P% a9 ?* |, V6 [
G54 14 Work coordinate system 1 selection YES Standard
) d. m9 H2 @# J& V) w4 B
G55 14 Work coordinate system 2 selection YES Standard
+ t7 X7 I/ [# G H
) R( J3 M w9 f# O8 q
G56 14 Work coordinate system 3 selection YES Standard
& Y6 d8 C O# {+ H. i
G57 14 Work coordinate system 4 selection YES Standard
2 S) I' J: l% u, q! |; H$ }6 d
G58 14 Work coordinate system 5 selection YES Standard
1 t6 A, B* h$ F* X( v2 \! s
G59 14 Work coordinate system 6 selection YES Standard
. m" ^% Y' l$ o& _( U! ?8 }+ o
G61 15 Exact stop mode YES Standard
$ w5 e2 }9 V' I8 r7 j( ^, \. c8 H0 j
G62 15 Automatic corner override YES Standard
% o( y2 j- d+ V, e, Q
G64* 15 Cutting mode YES Standard
0 m+ o9 H* Q: M4 |0 F: s
G65 00 Marco call NO Optional
+ Z- f6 l* D! z" b: y
G66 12 Macro mode call A YES Optional
* {' o2 X; }; `: q
G67* 12 Macro mode call cancel YES Optional
1 t% e$ U. g! A& y R
G68 13 Balance cutting YES Optional
: N1 {: f1 t$ ~! M% P
G69 13 Cancel balance cutting YES Optional
* @4 [& {; v& W- Y+ B' a4 @6 M
G70 06 Inch programming YES Standard
: n2 ]* ~* ?8 e, ~
G71 06 Metric programming YES Standard
, E8 t; t7 {6 z3 a
G72 00 Finishing cycle YES Optional
7 E& v& x9 o7 Z& Q6 t
G73 00 Stock removal-turning YES Optional
\* e- F5 ^/ k) }
G74 00 Stock removal-facing YES Optional
3 v$ y- j$ `) @8 E E: ~
G75 00 Pattern repeat YES Optional
1 D( Z1 X* }0 K$ O' ?
G76 00 Peck drilling in Z axis YES Optional
7 q( p2 `; ^" M2 U, @4 K
G77 00 Grooving-X axis YES Optional
* ]% H) J, P6 R" o/ o( K
G78 00 Threading cycle YES Optional
; f, o5 K/ g( }/ W# ~( s. W4 o
G80* 09 Canned cycle cancel YES Optional
0 q1 C/ v/ H# Y4 j5 B! S* ]
G83 09 Face drilling cycle YES Optional
2 Z- R5 }; W) A4 d) q+ U
G84 09 Face tapping cycle YES Optional
% E5 @ X) I: W. ?( W# R h }
G85 09 Face boring cycle YES Optional
# H! L9 n* m0 c" O! {5 M
G87 09 Side drilling cycle YES Optional
$ L5 p; v! N& n' T# d
G88 09 Side tapping cycle YES Optional
2 m0 x! E" I: x' `. n% i$ d
G89 09 Side boring cycle YES Optional
2 U9 l7 k- H. O
G90* 03 Absolute dimension input YES Standard
$ ]7 r3 j5 y2 Y
G91 03 Incremental dimension input YES Standard
( v O8 A" d* w! l. n c* {
G92 00 Work change/ maximum table speed NO Standard
$ s3 n: y4 C3 q: O7 m1 B: k
G94 05 Inches (MM) per minute feedrate YES Standard
, m6 @+ L- p# s
G95* 05 Inches (MM) per table revolution YES Standard
- N# g1 h! @. ~
G96 02 Constant surface speed YES Standard
: o4 J% r# ~, v( i O$ J2 _5 c
G97* 02 Direct rpm YES Standard
|5 F5 u* x7 ]) o6 `: H( {* n
G98* 10 Canned cycle initial level return YES Optional
4 ?$ \9 `, }& r- n+ e* x
G99 10 Canned cycle R point level return YES Optional
欢迎光临 机械社区 (http://www.cmiw.cn/)
Powered by Discuz! X3.4
