查看: 3348|回复: 7
一个固体力学的仿真计算
发表于 2013-12-19 19:22:36 | 显示全部楼层 |阅读模式
3 D- r# j" |: J6 C" ]4 c+ H/ C8 `4 Q$ L; L( u- W* H
Two metallic beams a  and  c are fixed to a block as shown below. Both beam a  and beam  c  remain perpendicular
( L# i, o7 y4 @, P3 y& ]% n1 X, |to block  b  at the connecting points. Beam  a  is attached to a wall and it remains perpendicular to the wall at the
  y+ y% [6 H- M# Lother end. Beam c is passed through a hole in the wall. Direction of the hole is perpendicular to the wall surface.   ) m- k1 |- C9 K$ i
Related dimensions are shown on the diagram. The diagram is in millimeter. Beams  a  and c  have a circular
+ c: }  y2 B3 s5 B. e2 H. c2 ^5 Zcross-section with a diameter of 0.7mm. The Young’s modulus is 70 GPa. Both beam a  and beam  c  are initially 3 m$ v: X9 t; L- R& D- I6 \% ^- a
straight.  9 u6 T. ?2 p9 [3 t0 _) r% _! g5 ]
Neglect gravity. Assume a perfect linear relationship between stress  and strain for beams  a  and c . Neglect axial
8 G7 D2 z: N6 n# G1 V% l4 Y- m8 Melongation or compression of beams  a  and  c .  6 F& U% o' l6 Z; v# e# h- n
Using elliptic integrals, derive relevant entities to predict the final shapes of beams a  and  c  when beam c  is pulled
  _0 P1 A) m: ffor 10 mm in the indicated direction.   # ?: o5 v: U. ]8 x
Use Matlab to implement your derivations and plot the deflected shapes of beams a  and  c  in a figure. You should & D/ B# `" j1 u/ @' O
also plot block  b at the desired position. Please make sure your plot has a correct X-Y scale so that the figure ( f/ _* W  |( Q+ J3 y- _/ v1 d
looks realistic.
9 \; r; P' G3 h# R/ D2 I+ M9 qPlease also compare how close the deflected shapes of beams  a  and  c  are to circular arcs, by drawing circular arcs
& Q' Y! w! D" {# m# j  e5 H4 d& awhich pass through the two ends of beams a  and c . The circular arcs should also be perpendicular to the wall . W! l  R4 i* f# S  ]5 }- f
surface at one end.
  r1 E# h) u! R8 }! R: y/ `
 楼主| 发表于 2013-12-19 19:25:39 | 显示全部楼层
大概有10个以上的未知数和方程,但是含有数个超越方程,用matlab做仿真一直没出来" T/ K/ C( T# f2 W+ I; x
有大侠有好的方法么。。。。。
发表于 2013-12-19 20:42:31 | 显示全部楼层
这个没有人会回的,楼主放弃吧
unmark 外语小白表示‘亚历山大’  发表于 2013-12-20 10:35
mark一下,过几年回来再看看会不会。  发表于 2013-12-19 20:47
发表于 2013-12-19 21:08:16 | 显示全部楼层
茉莉素馨 发表于 2013-12-19 20:42
& Q, y/ ?. W* o2 h6 o0 R, g' Q这个没有人会回的,楼主放弃吧
, K! W3 N" ]: Y2 ]0 ]; ~$ }, L同马克
. l) }% m- J) B
发表于 2013-12-19 23:11:57 | 显示全部楼层
楼主这是在国外深造啊?
发表于 2013-12-19 23:39:19 | 显示全部楼层
老实说,我不会做,看了下题目,估计了下,估摸着是这种形状,哈哈
5 B4 X8 U0 ~' V$ U  C$ P) h2 f- @; _6 d  |
应该B的重力影响比较大吧
7 l; c  E) ^4 a  m0 p- [. Z. s0 z: u
题目里说了不考虑B的重量  发表于 2013-12-20 12:04
发表于 2013-12-20 16:38:24 | 显示全部楼层
求变形吗?可以使用有限元?
是可以 主要是老师在教这一块 要求我们用椭圆积分  发表于 2013-12-20 19:25
发表于 2013-12-23 22:38:38 | 显示全部楼层
B看成刚性体. I+ U3 S( t6 {; I& e
或略a和c的轴向变形% B' e$ U- j7 L2 l" ]
根据挠度方程联列a和c的变形方程
GMT+8, 2025-4-29 15:59 , Processed in 0.066895 second(s), 17 queries , Gzip On.
