发表于 2013-12-14 21:40:12
显示全部楼层
1. If you have got SW2013 installed and activated this setup will update your SolidWorks 2013 to SolidWorks 2013 SP5.0. No additional crack is needed.
+ } f8 y3 ~: {4 x2 ]1 `- v* A8 h1 _, a9 t# S
2. If it is your first installation of SW2013
3 s3 s0 Z; i! k u( v F$ T, ?$ k. u9 }2 f' s c0 ]& x" T+ c4 f
2.1. Install SW2013 SP5.0 using next serials8 Z4 m3 U7 U! I! J
6 O- m. }' C: [9 v% P
SolidWorks Serial:1 t, ^; A5 ?9 T) e
' ~9 w3 m; t6 z* V3 ]8 f1 K
0000 0000 0000 3486 Q5HF FG98# s- Q9 A1 j. T& w8 i( T# \
or* L# c0 u6 F+ w6 x/ C3 b
0001 0001 0736 0361 JK3Q HDJ3# x. E8 M8 x0 F, |
0 c( H3 P. N t2 B1 a$ ?
$ O! `* g" r% J
For Simulation stuff USE ONLY THESE SERIALS:
( k* s; `% W' u# F% M6 M4 x' [& e, l) U
SolidWorks Simulation
# _) ^. {* m8 j- K: A; z9000 0000 0001 8043 TB9T SGD9) }/ ^6 K Z7 q8 v( a- u$ C$ I
9 k9 O" _) C5 d- Y5 V: fSolidWorks Motion
- D# |6 ~3 i0 P+ u0 Z; I: c6 b9000 0000 0002 7942 9KW4 9FBC5 s# Q! f# t, y) g
& _, e$ c0 A$ F8 Q) `4 ]
Flow Simulation
7 K5 R9 D/ G5 \& ?% I9000 0000 0003 3107 V8F3 PG44
# U7 R) x4 o7 C3 Y& k
2 o$ P! J* Y: B8 V3 k# p! B2.2. Run "SW2010-2013.Activator.GUI.SSQ.exe" (as Administrator!). On "General" tab check if all SW2013 products are selected to activation and click "Activate!"/ L0 W0 S5 S: t; y& D& d* Z
, y: F. X( S' S! O9 W
2.3. Wait for Activator message "All done! Enjoy" and click OK to close Activator
& e2 F% V& o2 P& q" K5 Z- H. T
6 ]- i$ V9 o/ T9 H5 o/ R- N! ?3. Enjoy
4 ?) b- I) {$ E" r" q/ H* `; O5 s9 @
# A: m" o* ?* q' X/ Y( ?3 X# ], ATo install Workgroup PDM Server:, A. m. O* b" _% n! n- E0 |
3 |. n; c9 |0 E% R
1. Install IIS full configuration if you plan using Web Portal& |# ]" m# D, i4 k! i
2. Install PDM Server from CD
) O# R1 Z% ^$ l3. If your computer is not connected to Internet, use arbitrary email and SW serial to get a key from PDMWorks keygen( m3 d" ?' _/ n8 Y n2 Y
4. If installing Web Portal, leave license string from Workgroup PDM Viewer empty
`# w0 D( r' l `5. When installation completes, apply a fix inside keygen: t/ f2 ?) F6 x* z3 E$ z3 T2 ]0 G2 H/ a
6. Reboot your computer# e0 ]* C! j; n* K& o. `2 t
7. Enjoy!
; j5 g& B- \. a$ E! o. @9 Z7 x5 R& X& @& F8 g
Cracked by Team-SolidSQUAD (SSQ) |
