各位使用CAD的大侠们:
! U7 l: r% P0 }, g- \* w" x, j$ D我刚才安装CAD2006时刚进行到第一步,点安装图标后也就10秒,必须的支持文件都没安装完,就出现提示。说已终止cad2006的安装,详情请查看一个文件,我把这个文件复制如下,大伙帮我看看问题出在哪,是不是和操作系统有关?我先谢谢大家。 / K0 b _/ m5 M7 w6 k
3/8/2007 22:42:16] === Installation started on D3E7F8F455444CA by new === [3/8/2007 22:42:25] [Info] Windows Installer upgrade is not required [3/8/2007 22:42:25] System Version = 3.1.4000.2435 [3/8/2007 22:42:25] Installation skipped: MSI Runtime 3.0 [3/8/2007 22:42:25] [Info] .NET Framework Runtime upgrade is not required [3/8/2007 22:42:25] System Version = 2.0.50727.42 [3/8/2007 22:42:25] Installation skipped: .NET Framework Runtime 1.1 [3/8/2007 22:42:25] Installation started: .NET Framework Runtime 1.1 Language Pack [3/8/2007 22:42:25] Command = "support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb" [3/8/2007 22:42:28] [Error: 1603] 安装时发生严重错误 [3/8/2007 22:42:28] Installation failed: .NET Framework Runtime 1.1 Language Pack [3/8/2007 22:42:28] Installation aborted [3/8/2007 22:42:41] === Installation ended ===
