发表于 2013-8-13 18:56:28
显示全部楼层
一、在装配设计方面:
! L: d( G* w% D# oWhen choosing more views from the viewpalette, SolidWorks indicates which are being used, and which are missing;(在视角调色板当选择很多视角时,SolidWorks会显示正在使用的,以及错过的)/ n* L Q+ }3 U7 q
Display Style context menu (显示样式出现在快捷工具栏上)) G1 ^4 t3 i, }% _+ P
High-quality shaded views (高品质阴影视图)
9 w6 ~$ r5 D" _) H3 M1 F1 I9 f' e0 SAngular running dimensi — Can changethe dimensi , run bidirectionally, set the extension lines to the center(标注角度带辅助线)# k) g' a( p- t1 ^: I& V' `
Split table by row count — For a bill ofmaterials with many components; SolidWorks remembers the number specified(表格的单元格拆分出行)+ u3 @# x D( f. L! Y/ T5 y4 F* S
Smart mate delay — Components only tryto mate themselves to the geometry when the user pauses for a customizablelength of time(智能装配延迟,时间由用户来自定义,组件根据几何形状来装配)# B5 I& Y, J+ L6 h% X
Feature-driven component pattern(特征驱动组件方式)
6 |7 y2 B3 `- x9 sRotate exploded views(带旋转角度的爆炸视图)7 y4 |. Z3 `! H' b( w& l1 U
Quick Mate context menu(快速装配方式出现在快捷工具栏中)
7 v4 C) c. T, U- j+ @* P! h& f0 G7 o
本帖隐藏的内容0 l3 [' H- _& {( l0 W& a2 J. O
# \8 s! v8 U( H+ ?$ T( H/ L二、有限元分析方面:2 S8 n% M+ [ o4 [! \
CircuitWorks now supports thermalproperties — Including specific
& P- P$ i% v# @ \- u/ Qheat and thermal conductivity(CircuitWorks现在支持热能属性- 含比热和热导率)- I* M8 O# v+ f/ O( Q$ D8 |& n
Link to
" n) T$ | a; Y& b! _SolidWorks Flow Simulation — Cannow assign these properties to each component,
9 G1 b$ j2 V' r% hor automatically create heatsources(SolidWorks Flow Simulation - & A/ z# _& h4 E
现在可以把这些热能属性分配给每个组件,或自动创建热源)$ C0 @+ ~+ a( U6 W3 P
Bolt mapping — SolidWorks Simulation v7 [6 s) j7 W' P5 n$ E" P
canautomatically create connectors in the simulation
( n( W, r4 Q) B% Fmodel(螺栓贴图,SolidWorksSimulation中可以自动创建螺栓联接的仿真模型)
* {1 S w) S) D* ?* UResults symmetry(结果对称)
: L1 S3 ?/ D+ @2 c3 y0 Z/ F" M4 W% t: h6 k# r u6 s
Residual stress from SolidWorks Plastics— Can also add other loads for a more
0 O3 | c2 a, v5 [; C% q# y& Kcomplete picture(来自于SolidWorks注塑分析的残余应力,也能加进荷载中去了,这样才有全面的分析) w" S9 ?$ }. }8 q* V) v/ E. U" S
三、草图绘制方面:1 S' l2 K' M3 w* j6 H
& J9 P! ^# Q6 S; C i; a3 m$ Y1 fSlots in hole wizard — Swap out holesfor slots, # Y5 O2 }3 ], J0 _8 F8 V) a3 g
including counterbore, countersink, and regular 0 a! x% {' E; f% N' R6 s" H
slots(槽口孔向导,槽口与孔特征互换,包括扩孔,锪孔和规则排列的槽口)
5 ~0 [/ G# R5 FHardware is locked to temporary . ( C5 l* q) [5 c9 Z( \! m: \6 ]
axesthat are automatically placed in the slot.(强行锁定到临时轴并自动放置槽口位置)! H' Y+ K, L0 ]& I4 ]1 p
. m+ P3 T! n$ D y: l
Fixed-length spline — Drag any of thepoints and manipulators and the length is 6 @$ e0 x/ Q# I+ a
retained.(固定长度的样条曲线 - 拖动点和操纵和被保留的长度)2 c. b+ T6 _+ Y# O* ~0 W' n3 z( G( |
Style spline — Offers more control 1 u4 D; u$ n# T3 z0 A" |3 V
overshape Replace sketch entities(样式样条曲线 - 提供更多的控制权外形替换草图实体)
7 H7 t0 r( u$ L) \8 u! i槽口特征与孔特征的互换& o/ |( _; j& A6 G
$ e: n$ g a- J- R* G
0 q( w# o) ^0 b( s( p四、电气设计方面:
( k" D: z- d8 m1 {$ g5 I/ N: T/ rSolidWorks Electrical harness — Required connectors
1 [5 Q' v$ f Kareinstantly available, and can be inserted by snapping them into
) q, M5 M/ g; M* j" Splace(SolidWorks的电气线束- 通过捕捉到的地方,可以插入所需的连接器立即可用)
9 v* b; E( ]; s/ z1 p+ ^Reuse existing 0 q% ^7 ~/ u% B& Q
harness(重用现有配线)
4 Y5 Y1 B& t- u! C; |Clips in flattened representation(扁平表示在剪辑) q% h$ y% j* w2 C j" i
Colored ) \+ t) C3 [+ Z) d+ @$ C4 w
connector pins(彩色端子)* W! Y: h+ V/ V; |/ C8 g
7 y0 l4 ]$ Z k% Q+ [五、可视化设计方面:
/ ]3 z1 O# ]- uOrder-independent transparency — For
* q' g) M& k/ h' B& B; H! grendering that makesthe internal components visible(顺序无关透明度 - 对于渲染,使内部组件可见)
6 R* D: U9 U# e: |0 c
% G' h% K" |% B' T7 D* b1 \1 ISunlight and sunlight animati — Enter the longitudeand latitude of " s: m9 H1 X, D' F
any location, as well as the date and time of day(日光和日光动画 -
; j# T( P- h3 L; q输入的任何位置的经度和纬度,以及一天中的日期和时间)
' }3 h& D, b( x4 BeDrawings with augmented reality — Overlay images ' g( q1 G, I: I2 Z/ _( ?
of thedesign on live feed from a mobile device's camera(带增强现实技术的eDrawings -
$ ]2 n/ Q1 Q8 M5 E! R从移动设备摄像头对设计直播的覆盖图像)
0 ~- C/ f! H' m) A$ N2 uNetwork rendering animati (用局域网分布式计算技术对动画进行渲染)
2 l, ~- o. |7 @3 M: u3 T1 |3 u; V. ^" C
4 z+ J/ g! J( L1 d# D1 l7 t六、设计管理方面:3 K9 E- n( Y+ x% S3 E1 S( M# \
Environment themes — Use precreated themes or create yourown + s; o, _$ P% f2 w! M2 @
add butt to toolbars, modify mouse gestures(环境的主题 -
& G3 O3 S" ~( k$ o6 L7 W5 x使用预先创建的主题,或创建自己的按钮添加到工具栏,修改鼠标手势)3 o! o, p. y7 [3 I$ F% H
History folder — Located at the top of the + E; V$ b' V$ v# o* N% e. h
FeatureManager, lists last five features worked on(历史记录文件夹 -
- V9 Z9 d' W8 K9 W位于顶部的特征管理器,列出最后编辑的五个特征)
3 D8 s5 d; Z r6 K: D; QFlexible Assemblies context * j9 g/ a4 {3 }, r
menu(活动件进入快捷工具栏上)
' s' z8 @ v& F; i七、钣金设计方面:
6 r/ Z5 O. [; A0 w1 `8 ?Sheet metal corner gussets — Gussets are ' h, @2 c _% k
automaticallyignored when gussets are unfolded(钣金边角角撑板 - 强化骨架时自动忽略褶子展开), V. T* A5 {2 u$ b2 y( o' a$ C
/ R: y8 L1 u g M8 g! w
Lofted bend transiti (放样弯曲转换) |
