查看: 4284|回复: 0
[ansys] ansys求解出错
发表于 2013-6-4 20:30:15 | 显示全部楼层 |阅读模式
建模,网格,施加力和约束都没有问题,一到求解就出问题了,An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes.
' q& B" W* V7 \我看了Solution Information,上面说:" P# L9 f' k( A3 R
*** WARNING ***                         CP =       2.668   TIME= 20:12:31
/ v2 m% g) I* RFile ds.dat does not exist.
6 X2 A6 V( {7 |, r& y* d  The /INPUT command is ignored.
5 g# C9 m1 _: `6 j: k) k3 d0 E
" [/ R* ]8 z% c8 b' _1 c6 ^EXIT ANSYS WITHOUT SAVING DATABASE0 Z. T" [2 k4 v: l9 y. `6 X# B
; `/ J* G& ]& z# D% x* j6 z
/ H7 d: o5 |! ]NUMBER OF WARNING MESSAGES ENCOUNTERED=          1; d9 R/ Y: u3 b7 a8 r" A( J
NUMBER OF ERROR   MESSAGES ENCOUNTERED=          0& c4 ~. G$ V3 U# R& Z& h
% S/ m1 l+ Z% N5 \; u
我去文件夹下看了,ds.dat这个文件是存在的,而且我用记事本打开这个文件,里面也有东西的啊!
2 m$ k9 E0 N- ?: \2 v$ k
GMT+8, 2025-2-23 16:36 , Processed in 0.068054 second(s), 19 queries , Gzip On.
