/ `% b* T' r) o, L" v3 ~! 这些选项控制与其他选项无关的文本/ @" |' ?! y9 Y/ Z. I
!& U% Z' u+ e+ } Y: q% O8 G" z/ x
drawing_text_height 3.500000& O6 u5 t# m3 J" v2 [* R0 m2 q
text_thickness 0.35
, p% v; p( h" \) Y. V: P @text_width_factor 0.850000
9 o9 }/ n( R3 y8 a!
' s9 ^8 ]' m3 J; M' H!
8 l4 V; h6 B/ a: o) j! 这些选项控制视图和他们的注释
) Q5 A3 G+ J- F, l# `!
k/ [( S k7 [# v5 `# Mbroken_view_offset 5.000000
3 a0 [ i: B# S" _' A* d6 |( Gdef_view_text_height 3.5' M( L( u8 d, h# b+ V, y e
def_view_text_thickness 0.35! A6 m- o+ z) {
detail_circle_line_style PHANTOMFONT
" q3 {: L+ l i4 `) C: D6 ydetail_view_circle ON
0 w+ D. n" S0 k3 j+ dhalf_view_line SYMMETRY
* e/ }4 n- y, jprojection_type FIRST_ANGLE" r8 e! o* B* l; U0 K8 i
show_total_unfold_seam YES
! D! m o- F) \view_note STD_DIN
6 J. ^& W* J' Bview_scale_denominator 09 e) }! a3 G# L. f n' L6 y
view_scale_format DECIMAL
$ I$ c( P9 s# y6 h b V/ {!
8 b& x' ~4 r* E- j! 这些选项控制横截面和它们的箭头
4 `" f* |& O+ w! x!
9 [/ N n! ^; R* W1 m. }" `% Acrossec_arrow_length 6
; T" F7 V+ ~/ h- d( Ccrossec_arrow_style tail_ONLINE, w1 O3 i6 L% s( v$ M
crossec_arrow_width 3
, J; ]4 n" E! B S2 ]crossec_text_place ABOVE_TALL/ k. y; c H6 l3 c
cutting_line STD_ISO
$ E7 P1 w3 _6 S, A$ Y" n, A% v4 T. zcutting_line_adapt NO( k0 U' C( n7 L+ f1 l
cutting_line_segment 10.000000* m8 y$ K& [( ]1 j; V5 A7 j1 u
draw_cosms_in_area_xsec NO) i5 v1 b2 O# D( Z
remove_cosms_from_xsecs TOTAL# }8 P) [7 i3 U
' v) i5 m7 d1 h!这些选项控制在视图中显示实体! b- u( O- G6 W4 A8 J
!0 Q! a1 E1 D# c& U# r$ z
datum_point_size 0.312500" c6 s) M6 ?; f) `9 Q! Z
datum_point_shape CROSS
3 ?: N4 m" ^/ Chlr_for_pipe_solid_cl NO: a* |$ l2 M! r! g# ]3 o) Y! i( U
hlr_for_threads YES
* O* X4 \5 T& p1 k+ V `$ Q7 Nlocation_radius DEFAULT(2.)3 W7 }4 Z7 ^, V5 P7 S: `
mesh_surface_lines OFF1 r2 p* U" a( {
thread_standard STD_ISO_IMP_ASSY
" [( P* m' U0 M, g1 n- L( Whidden_tangent_edges DEFAULT, E: ^$ n; F, P1 U; z
!6 E7 o. C _+ }
!这些选项控制尺寸9 [+ {. P8 i* U* w3 f2 r3 o( a
!0 T; M6 p! y/ y, L1 Y& D: g
allow_3d_dimensions YES
) p, D& X4 A5 Y& p/ X* k3 aangdim_text_orientation HORIZONTAL
2 X! C, w; W1 }associative_dimensioning YES
$ ]' u/ W, y2 j5 j% rblank_zero_tolerance NO
# x6 I* r4 o! `( s( \/ p' lchamfer_45deg_leader_style STD_iso
6 K3 E5 t; j5 h5 s; qclip_dimensions YES) _, f, s7 B* R- H' W6 P( M
default_dim_elbows YES
1 v$ F0 P% }9 q- L) I. _3 zdim_leader_length 5.000000
9 {, Q% [. j& K. t3 Jdim_text_gap 0
$ q7 @4 _# e' b1 h. O- y% rdraft_scale 1.000000
& B' C7 m9 Z! J; u3 c7 \draw_ang_units ANG_DEG+ S* z# e# G- W- m( Q
dual_digits_diff 1: ?' i% F* q6 [+ Y3 V% V: R! L0 S
dual_dimension_brackets YES* {# A) v7 m# y
dual_dimensioning NO
; R% M9 C5 @0 y2 a8 r, idual_secondary_units MM4 B: T7 Y; S: W
iso_ordinate_delta YES" m& @# B7 [0 V) I6 f
lead_trail_zeros STD_METRIC" g% X% U) ]1 w4 i" d7 t( {- S/ r$ ]
ord_dim_standard STD_ISO5 t) z) C( | Y7 E3 C
orddim_text_orientation PARALLEL1 r% s* ^# _ ]; `" U' G
parallel_dim_placement ABOVE
: P& a/ r, W, j' ?2 |: ]: Vshrinkage_value_display PERCENT_SHRINK
0 Y# i# ?! U) [) h; ~& r& `text_orientation PARALLEL_DIAM_HORIZ
& g @% T: `/ e2 r: f# ]tol_display YES8 q* \0 |$ b5 }3 K. d* e2 W u) K
tol_text_height_factor 0.600000
$ \- U- m* G d) [4 d% Jtol_text_height_factor 0.600000
3 h: z' H: s T6 G6 E5 h* Vwitness_line_delta 1.5000000; t4 r4 M/ W1 E: F* m
witness_line_offset 0.000000" f A- F" ?* I' z3 `! T- Q" K
!% `- {. K$ W; R/ t
! 这些选项控制文本和线性4 n g6 Y! ~+ q. x5 H: \
!1 X& K* h& F/ A1 ?, N+ X
aux_font 1 filled* t1 e; r. q+ i' W( r' X. y1 m' |
aux_font 2 leroy$ ? v. Y' A: R1 t: ~ s
aux_font 3 cal_alf
[; o6 B1 _/ S* @# @1 g1 ^' m! caux_font 4 cal_grek8$ g0 {! @0 g! T' P
aux_font 5 font3d% ]5 d: [% s& i2 n- q- W
!' q1 H* m1 |2 \: C+ l
! 这些选项控制方向指引
( {0 `& k6 x' Q+ U2 g" h4 ]0 U0 E, {!8 q) m8 Z6 R9 p' r
draw_arrow_length 3
; Q/ e1 q* {/ X3 mdraw_arrow_style FILLED2 r, d9 o" H2 V' U: D
draw_arrow_width 1
+ n z, t j- }8 mdraw_attach_sym_height DEFAULT
* N* N9 a: T4 n. Gdraw_attach_sym_width DEFAULT* A6 @" p4 g+ w ~
draw_dot_diameter 1.000000. ~0 x0 b9 M3 p8 b6 L4 v2 U7 b
aleader_elbow_length 6.000000
* Y' T, a/ j+ d8 n0 D% Q!
; G* Z: p* l& y" c! 这些选项控制轴
: S2 t- N; s7 ^7 D* o!+ q; |( s$ ?2 a7 D4 M7 [
axis_interior_clipping NO: ]" X& ]9 \& U) T3 c
axis_line_offset 5.000000: O8 J8 L0 n! V3 _- f/ k
circle_axis_offset 4.000000
$ k$ k3 I2 ?' v$ lradial_pattern_axis_circle YES
8 ?0 u L- @9 y g4 t$ i!8 l m1 Y" U4 O: N
! 这些选项控制几何公差信息
3 t4 t& s$ o# ~7 j8 W!, r/ i# E h7 \
gtol_datums STD_ISO
6 U8 X+ L' R4 d$ \, t+ z B$ agtol_dim_placement ON_BOTTOM + ^( p& o+ s+ l# H+ Q- h- g
new_iso_set_datums YES1 {. Q' }- ?: L
[, l5 I* F4 k. h) U" I- X5 u! 这些选项控制表,重复区域和材料清单球标
8 d' u: C5 v2 P- z! @. C!+ ^( u# {! i$ r* f3 F8 s. U
dash_supp_dims_in_region YES: q. d- Y6 {% _2 I
def_bom_balloon_leader_sym ARROWHEAD5 H7 F$ I5 f4 x! B
model_digits_in_region NO. K$ i- o8 t, v
show_cbl_term_in_region YES0 H! Z! B2 l" m$ s
!3 W$ O/ L# O" g& E, f4 n0 G
! 这些选项控制层. p: Z8 Q4 M+ j* J/ y, C
; }; L/ i" a! k* _+ `* t" t8 Ddraw_layer_overrides_model YES
0 E. D# F" k3 S3 [) U E3 oignore_model_layer_status YES
v7 W* V$ e& _. m+ \!
% D; S+ w2 `! U l6 }% f: f' F' w! 这些选项控制模型网格7 A6 ^$ g7 W. c4 m
; t( K* a; K& ]$ P, Emodel_grid_balloon_size 0.200000
^; c8 B9 @) ~+ imodel_grid_neg_prefix -* v$ q8 n6 P a1 K! P2 {3 F6 o
model_grid_num_dig_display 0
9 ^5 L/ h+ l: v: \, Y# X: m: U!
; S# K; Z9 k; j2 R! 杂项选项- ^& v6 Q+ K5 ^8 Q. V: w
1 ?* ?- ~- G ?: ndecimal_marker COMMA_FOR_METRIC_DUAL4 J8 h2 P! x# |$ g' B) 5 c6 f4 ~2 [; P* Z) v
drawing_units MM
: i; i& t' s3 |8 e) b* |/ lmax_balloon_radius 0.000000
" Q2 x; a" [9 q6 z' Lmin_balloon_radius 0.000000$ r2 Q9 J/ I* D# X+ e4 j8 I& W _: ?3 r: R! |" V' y) A
node_radius DEFAULT9 l( N' i( O, u' A9 J3 E% K7 a7 A: v! |/ s' S2 F0 f
sym_flip_rotated_text YES5 p# c9 d9 p6 w9 g% x4 ^6 I. ?# A
sym_rotate_note_center NO
4 b$ m/ N2 ~9 T6 s' V: Z1 hweld_symbol_standard STD_ANSI
( r; z$ ^4 n2 g+ fyes_no_parameter_display TRUE_FALSE # {. l" j/ k+ c* A8 g
Projection_type first angle/third angle
9 s1 ~ k, [& i1 P/ tDrawing_units 设置绘图单位.mm是毫米,inch是英寸等等
2 u9 s5 `" j7 Z w. }ADual_dimensioning 是否同时显示两个单位的尺寸
, Y9 q, s8 V! u# b9 ]' oDual_secondary_units 第二尺寸单位
R. ~) q, D l1 utol_mode nominal K. a( e$ R8 Y0 m. Y
) G5 T) x% K" S! Q5 L J$ p |
