http://trial.autodesk.com/SWDLDNET3/2014/INVNTOR/DLM/Autodesk_Inventor_2014_Simplified_Chinese_64bit_dlm_001_002.sfx.exe, l, t/ m7 I) N; P
http://trial.autodesk.com/SWDLDNET3/2014/INVNTOR/DLM/Autodesk_Inventor_2014_Simplified_Chinese_64bit_dlm_002_002.sfx.exe
- S$ f; u+ Z) K两个都得下载,体积4G,下载后双击其中之一就会开始解压缩,将安装包解压缩到一个文件夹里,体积8G,然后再点击setup文件,启动安装,安装时选30天单机试用,这样安装后就是30天试用版,想激活就上网搜索autodesk2014注册机和序列号,注册机是通用的。所谓的正式版对于企业而言就是试用版加序列号,对个人而言就是试用版加注册机5 q o4 Q+ Y7 q* M6 k
& x/ e9 \1 m7 Z2 q3 v; `' ]8 |
新功能的限制条件(简体中文):http://images.autodesk.com/adsk/files/autodesk_inventor_2014_readme_chs.htm#_Autodesk_Inventor_Professional_2014
( M) Q$ H6 F: C$ }2014版本地帮助文件(简体中文):http://images.autodesk.com/adsk/files/Autodesk_Inventor_2014_Help_CHS.exe
$ U! j* p- o7 i& b如何安装本地帮助文件(简体中文):http://images.autodesk.com/adsk/files/help_install_instructions_inventor_2014_chs.html
9 b/ z9 r% ^- }1 h* G& G! t- T7 I+ g1 j! F2 e1 {: r" h
, _! Q" {0 s% s5 [& a# u
