楼主: 狙击手
地球的正中间压力多大
发表于 2013-4-6 18:36:24 | 显示全部楼层
什么是重力?就是万有引力。
" ]- ?: n4 R% S3 ^那么当你在地心时,你就时个点,没有质量,那么你对地球没有引力,那这个时候只有地球内部的引力。
7 q! `% |# ^, q. W) s! p8 u- s0 O8 {假设地球是个水球,把水球分成360分,那么每一份都有相对180度处有一个相反的一份和他平衡,两者均向中心点有引力作用,也就作用在你身上。以此类推可以得出有360分引力对你产生压力。用微积分地球分成N分,然后计算总的引力,就是对你的压力。好大好大。
发表于 2013-4-6 18:43:46 | 显示全部楼层
内部核心(inner core)压力在330到360 GPa之间
# n$ Z8 m4 C) [! O+ V0 _参考:David. R. Lide, ed (2006-2007). CRC Handbook of Chemistry and Physics (87th ed.). pp. 14–13.
发表于 2013-4-6 18:45:45 | 显示全部楼层
本帖最后由 开水滋养 于 2013-4-6 18:47 编辑 0 {9 _8 y1 ]1 G; T4 `. N
8 A" ~1 ^  J5 ?& M) _
Temperature and pressure* }. f4 Q4 g# N  W' L$ F
$ J6 ^0 m2 u" X: Q5 n* jThe temperature of the inner core can be estimated by considering both the theoretical and the experimentally demonstrated constraints on the melting temperature of impure iron at the pressure which iron is under at the boundary of the inner core (about 330 GPa). These considerations suggest that its temperature is about 5,700 K (5,430 °C; 9,800 °F).[13] The pressure in the Earth's inner core is slightly higher than it is at the boundary between the outer and inner cores: it ranges from about 330 to 360 gigapascals (3,300,000 to 3,600,000 atm).[14] Iron can be solid at such high temperatures only because its melting temperature increases dramatically at pressures of that magnitude (see the Clausius–Clapeyron relation).[15]+ x* ?+ m: K% I; L
. F$ G# H6 i! T" w  ]  X
so
8 h( |, B" H- b( d6 k/ R
The inner core of the Earth has temperatures and pressures so great that the metals are squeezed together and are not able to move about like a liquid, but are forced to vibrate in place as a solid. The inner core begins about 4000 miles beneath the crust and is about 800 miles thick. The temperatures may reach 9000 dgrees F. and the pressures are 45,000,000 pounds per square inch. This is 3,000,000 times the air pressure on you at sea level!!!
发表于 2013-4-6 19:06:50 来自手机 | 显示全部楼层
应该可以通过微积分算出来的
 楼主| 发表于 2013-4-6 19:17:01 | 显示全部楼层
ttlegyq 发表于 2013-4-6 18:36
& a$ ^) G0 l5 P什么是重力?就是万有引力。
% H* M5 P4 ]- c7 i那么当你在地心时,你就时个点,没有质量,那么你对地球没有引力,那这个时候 ...
0 h# N. e# B3 l& H- p谢谢以上各位的指点!8 h5 @: v+ f, z
  我还是认为,要计算没有问题,关键是如何界定。. O3 S8 n2 Y) s! H8 _3 u2 C# `. T
     看做是水球没错,看做是太空的卫星也没错。- u8 p; Q* K; K- M) }0 G0 e" l
         地球也是一大球,也是漂浮在太空的,不妨我们缩小事物来观察下: 放到太空的水球,中间是什么压力呢?  $ Q0 S  l8 N" \+ u! n
还是我二楼时候的那句话。也许你们不爱听。想搞明白这个,别画什么图了,去搞量子物理,理论物理,实验物理去。拿着经典力学的这些东西,你得不到一个正确的因果关系。  发表于 2013-4-8 04:13
既然中心无质量,那么按照地球坐地日行三万里的速度,早都甩干净了。  发表于 2013-4-8 04:07
另外,跟据目前天体科学理论,宇宙中任何旋转的中心都必须存在一个奇点,拥有极大的质量并因此产生足够大的引力才能使得周围的星体围绕其转动。同样,地球也可以看作周围物质围绕中心的转动。  发表于 2013-4-8 04:06
另外,还有那个中心点理论也是伪命题。你设定中心点为一个点,并因此判断其没有质量,那么这个点周围的物质不是由点组成的?为什么周围的点有质量?记住,微积分的应用前提是微元,不是点。  发表于 2013-4-8 04:03
楼上,那太阳光压力算什么?引力平衡压力? 推荐楼主去看看《与摩根佛里曼一起穿越虫洞》,看看科技前沿对质量和物质的重新定义。  发表于 2013-4-8 04:01
中间是引力平衡引起的压力。  发表于 2013-4-6 19:28
发表于 2013-4-16 12:06:35 | 显示全部楼层
有点害怕了,都搞上这层面了。
GMT+8, 2025-10-23 10:16 , Processed in 0.077581 second(s), 23 queries , Gzip On.
