Automotive汽车出行! M/ k0 o2 R) V" p2 @
1. Handle a blowout 处理爆胎& l6 q' [: e, q/ Z' {
2. Drive in snow在雪中驾驶6 C0 E9 X* k; p% @8 q: F/ o5 N
3. Check trouble codes检查故障' Q/ x8 ?6 p( v$ V8 J2 `8 N
4. Replace fan belt更换风扇皮带
( S3 w& F! d! `8 e5. Wax a car给汽车打蜡& z K6 B E5 A8 W- O
6. Conquer an off-road obstacle克服路面的障碍
) y9 R* {8 u9 A7. Use a stick welder会焊接
" k! P+ y1 c) r( V5 B; r: [1 l2 @8. Hitch up a trailer会拉拖车$ v8 H, p( C7 E# y( I7 _' T! L, K
9. Jump start a car会发动汽车
3 J% X( x0 j6 \, {6 U/ m
& _! u+ R7 A# p' f8 T6 {4 AHandling Emergencies紧急事项
" P7 d2 p/ k6 a' d, Q10. Perform the Heimlich会海姆利克氏操作
1 t) u5 Y7 Q+ ?, f" y" l3 n5 v11. Reverse hypothermia懂得如何退烧! h0 ]' `9 }0 E* S# `9 z6 @
12. Perform hands-only CPR会做徒手的心肺复苏术$ ?' ?+ ^% B/ E# [( b9 o; d3 p
13. Escape a sinking car知道怎么从沉没的汽车中逃生8 \2 H7 O2 s9 Q1 M% L! d+ [# G4 D
+ l) O/ d( T tHome家务活
* f/ x; F+ n6 L: L5 l( d0 h14. Carve a turkey会切火鸡7 J8 r8 X# ~3 }& V2 w
15. Use a sewing machine会用锁线装订机
- ?) Y% F! @5 r* r9 r( ?16. Put out a fire会灭火 `! N3 h: r1 Q1 E3 q4 ]; t9 J7 z
17. Home brew beer会自酿啤酒
6 U5 P+ \& V( J18. Remove bloodstains from fabric知道怎么除衣物上的血迹0 ]' U- S0 {/ x6 k6 m' t
19. Move heavy stuff能搬重物
( Q) ^7 A$ w. @- \0 { ]" ^# L20. Grow food种植食物1 f( }' |* g6 a1 O
21. Read an electric meter会读电表
& X& n' e, H5 z* v- L22. Shovel the right way正确的使用铲子
# h! Q. v& Z/ v4 |/ O; ]! C% X23. Solder wire焊接电线! }5 ]4 J8 Y: Y
24. Tape drywall粉刷墙面
8 n, V0 E) q( r/ i) d9 W9 q" D25. Split firewood会劈柴火) O1 B. s% s! p K/ z2 I
26. Replace a faucet washer会换水龙头; O& Z& M! C: `+ } T$ Q& t$ c
27. Mix concrete搅匀混凝土0 H9 O2 K7 }" u( K. T' u
28. Paint a straight line可以油漆出笔直的线
+ ~% H5 s' }/ _* s4 s/ M' z9 s29. Use a French knife会用法国刀
9 K9 k2 i) W% R" V. j! Q% D30. Prune bushes and small trees修剪树枝和小树
! S/ \3 y1 l0 _; B$ F$ M31. Iron a shirt会熨烫衬衫
4 y( j2 C% @" C `1 ~6 I32. Fix a toilet tank flapper固定浴池! {- Y& H3 ~7 Y o( p; Y4 e
33. Change a single-pole switch转变单项开关/ j3 t6 ~: Q: a
34. Fell a tree会砍树
y% B7 W: L; v/ D6 s35. Replace a broken windowpane更换打破的窗玻璃% G+ P4 ]4 [. D) _& ^4 Q2 t
36. Set up a ladder, safely架起安全的梯子
# u0 P" l4 A8 S) Q" a; i Q/ `37. Fix a faucet cartridge安装水龙头- ?: }' s3 e7 b+ ]4 I k
38. Sweat copper tubing使铜管出汗
8 Q. V8 O$ {% s# g' b' V39. Change a diaper换尿布
) E. p9 K7 l4 E40. Grill with charcoal 木炭烧烤
! d. Y% v2 G6 s- |5 g; G: Q41. Sew a button on a shirt缝衬衫纽扣1 k2 F4 Y9 u9 x0 k+ {1 a
42. Fold a flag折叠旗
$ h6 g/ C; m) m
0 o6 b. ]# S- f E! AMedical Myths医药方面
: \& L% g8 c* D3 ?4 M, ]: j43. Treat frostbite治疗冻伤, F' O: ?) z# F+ ^4 n! z$ Z
44. Treat a burn治疗烧伤2 p6 Z* I3 e, I* C. e( ?# k) ~
45. Help a seizure victim能抢救伤员
/ S c3 B+ j3 B. U46. Treat a snakebite治疗毒蛇咬伤
- p! [7 O: n8 \; ]+ H0 J47. Remove a tick驱赶扁虱
+ \) d0 A* q0 \: v- k. T5 @& `- M
* r5 R" H4 [; `9 N- i; _5 S2 g! QMilitary Know-How军队技术诀窍
( W: R# g) _8 w {! R0 y2 ^48. Shine shoes擦亮鞋子# o6 ~' }& o* G: M4 F/ @
49. Make a drum-tight bed叠饱满紧凑的被子' E$ u/ x, }( R9 m" c
50. Drop and give the perfect pushup下跌和来一个漂亮的伏地挺身
# H5 J b9 s, a2 x$ n$ j( W5 v) K j' m, F
Outdoors野外技巧* T7 y/ t0 s, p+ ^ a2 D
51. Run rapids in a canoe能在独木舟上快速跑# A7 C& D9 c4 c% P) ^ b
52. Hang food in the wild在野外找找到食物
x- N! d7 f% M3 E: b3 [6 {( Q53. Skipper a boat划船8 i9 @& ]! Q5 l+ z8 @1 i
54. Shoot straight打猎瞄得准
: h( i% Z. t# f# m55. Tackle steep drops on a mountain bike能推着山地车下陡峭的坡- y+ b% m# E9 E7 k" N \# v* Z
56. Escape a rip current能避开激流
+ I( ~ N5 ~' z8 h% {+ s; X2 v; ^1 e8 T+ H* J+ @$ b
Primitive Skills原始技术) h, ?% t( B4 U6 O% H+ f
57. Build a fire in the wilderness在野外生火; I2 E# |" M7 C/ c8 ^
58. Build a shelter会搭建庇护所2 ?1 A5 W1 [ _
59. Find potable water会找可饮用的水
_5 u! ~3 f* g& h9 z( B$ K; N& J( S- v- I
Surviving Extremes在极端环境生存
$ q2 q, _1 L3 u" \0 Y, z$ j60. Floods洪水
{; e: N j, o- G2 y- f61. Tornados龙卷风
9 _$ [8 i* q7 f' }: @62. Cold寒冷/ t& e, z# k i8 l+ A- p
63. Heat酷热
: r% \9 e: r5 a& k$ s# a' B, H# I64. Lightning闪电雷鸣9 y% q/ l2 z* e2 z
) Q1 w+ r1 D+ \ YTeach Your Kids教你家小孩的事情
: b) S0 {, K/ X9 ^65. Cast a line (钓鱼)抛线( e" m; m) T- w( C6 m' d% K7 E a0 ~
66. Lend a hand给别人帮助) G8 D F) \* j. n# S$ n* f
67. Change a tire换头饰
5 p a: g9 @/ }. z5 X* I68. Throw a spiral掷螺旋飞盘) @# J: ?4 g* j( d8 ?' w
69. Fly a stunt kite放风筝
|: z# j3 v; w% @2 [70. Drive a stick shift驾驶木棍转向?. b K9 d! W4 [' X' W0 p2 v# y5 q8 g
71. Parallel park并排的停放(车辆等)/ b/ A8 h; k5 g2 M/ f4 j6 t
72. Tie a bowline打称人结/ |& k( R2 e0 X: k/ M; P/ D
73. Tie a necktie打领带
+ g7 g8 H1 _/ y0 y# C/ L74. Whittle削(水果等)
5 l* C) g, o! \5 }6 @( h$ L& c75. Ride a bike骑自行车
7 D1 z- ^' s+ ?8 K
' T8 w4 W$ M7 Y1 zTechnology技艺
$ V+ b- a& V# ?7 H$ x5 S8 D76. Install a graphics card安装视频采集卡
& a" x: b( z7 h8 Q+ n# `; P& V77. Take the perfect portrait能拍得完美的肖像. m& B" w' B8 n/ G3 u3 r6 b* g
78. Calibrate HDTV settings校准高清晰电视的设置
. ~$ D5 A4 ^' q6 o! k79. Shoot a home movie播放家庭影院" a0 a8 x" ?+ b& i" C% k, n
80. Ditch your hard drive刻录光盘
2 N3 ^* z( [: B& b* J/ L7 B
1 b% q6 K$ |. c, e# GMaster Key Workshop Tools会用车间重要工具5 M3 ^, c! y" Q- g- j
81. Drill driver 钻孔机* D. [8 y* @3 ]# Y7 k' ? [4 Z; n- {
82. Grease gun注油枪
6 S+ W. N. d1 v83. Coolant hydrometer 冷却剂浮称, u, N5 d7 ?7 c. e- t
84. Socket wrench管钳子
; J% ~; s4 Z8 }" [85. Test light测光仪) w, i; v1 o* T1 W' g; \9 [
86. Brick trowel砖刀3 \7 z; v3 t) F9 S
87. Framing hammer 锤子
: _2 r5 x! T3 z. u$ x6 j88. Wood chisel 木凿子- O8 ?1 M \! e1 d
89. Spade bit 铲型钻头
( t* i3 R& L' Y! L90. Circular saw 圆锯6 j( X! `8 V' D
91. Sledge hammer大锤5 {' w( @ C* v, H N/ ~% ^( H
92. Hacksaw钢锯
7 o/ j4 r5 Y6 ~/ A3 U93. Torque wrench 转矩扳手
' q) a" E/ _4 H2 Z94. Air wrench气动扳手. X H3 y% B- t$ w3 T
95. Infrared thermometer 红外线体温计
# j* |9 J) d9 N; ]$ P% w96. Sand blaster喷砂设备
+ a# G8 K+ Q) E2 L; U/ P& ^& p8 j97. Crosscut saw 横锯木料的锯
$ @8 V/ y' ]. d1 E5 C5 R98. Hand plane手刨子
' r; \! e' w, U% E1 u/ J99. Multimeter万用表9 N6 U }6 v& v/ x
100. Feeler gauges塞规
$ C, \5 D1 g# @# z V) ~
( h- D4 M t- n% U' e. b6 H' ^2 t2 D$ e9 w9 n1 D' i
东方版4 Y3 U- _5 E1 s# K* ?; W# P( Z
中国男人应该会的100项技能+ }2 u Z5 p1 z- P
/ u" T M# Y/ @. d7 ]+ t交通
$ z. y" ]4 C% f% e; G1 能熟练骑自行车、三轮车、电动自行车、摩托车5 ?& B5 E" Z8 G( p$ Y
2 能修理自行车故障
3 M. Y* Y( e& G% O$ w t0 I: g3 能同时骑两辆自行车(牵车)$ e# d# i8 c: ~! S* K( V/ u
4 熟练使用自行车搭载数人或者相当数量的物品
" i& k% o" e- T4 G5 看懂交通信号并遵守交通规则& e; n- n, `9 c6 w/ g4 I
6 看懂地图、公交车牌、地铁指示牌
. g* ?" A3 T, p2 U# r7 会抢座、让座& y% n# \- u# b! b, R& P: c
8 能在春运期间弄到火车票
' W3 w- f3 |$ `2 U" J, ~& K! E9 会驾驶手动档、自动档汽车3 S! `( |- B/ @
10 能处理爆胎、更换轮胎
) S r* s, P5 y$ r11 在冰雪路、泥路、沙土路上或无路的地方驾驶
, n- L* q& R- j+ e% l( }12 汽车保养及检查汽车故障5 `) d ^, \# i6 D
13 会拖车! m/ N. y8 O: L5 e# g" ]7 C
14 能利用汽车后备箱、车厢、车顶尽可能运送多物品/ d, W* Y& |6 f( A( Y
15 会交车险、车船税、养路费、过路过桥费、停车费、上网查违章信息并交罚款
+ {4 _& E6 p+ J+ K" ]* v- L- s
1 n4 ?0 q: E2 M% | r家务活- L$ u+ {8 u7 L4 s* {8 I6 E
16 熟练正确的使用筷子
! M+ [* B+ W" h6 q/ [7 e17 会买菜、择菜、蔬菜保鲜# V# f& T2 u# B( O5 E. }# \
18 会炒菜4 `' u# u- k7 p) y3 }# G8 D e
19 会腌咸菜、制作泡菜
$ U& W0 _$ A! S5 \: Y8 H3 ~8 u20 会杀鸡、收拾鱼、剁冻肉
* w6 z X- n- P% h. Z7 p; @21 会包饺子、包包子、包汤圆、包粽子
; D6 m1 K4 t5 ?( {22 会和面并擀面条、面片、烙饼3 B8 x& i% O7 R" Q2 w
23 会煲各种汤和粥* x' z9 u+ a! @
24 会使用高压锅、炒菜锅、蒸锅、汤锅、砂锅等厨具
! X% r) c t" K25 会灭火5 I7 p2 o9 U5 J6 v5 k
26 会砍价& u% q$ x1 H' K
27 能搬重物& k* F7 _ L% U5 _, P
28 会种植花草、制作盆景
- m% y' L, \$ k* j& n2 `29 会养猫、狗、鱼、鸟等宠物. X7 ~* ^ u) u
30 会读电表、水表、煤气表
0 g/ K: a# r, q0 @' L) R& Y31 会更换保险丝和灯泡/ Q3 C# y& F' o9 J, f. C) h
32 会连接电线、电话线、有线电视线、网线, ? B: _ Q+ t
33 会修理家中的开关和插座7 t+ k/ g. C5 E; G0 s. v
34 会换窗玻璃
/ |. d/ ^- \7 W" i1 |7 ?4 ~, h3 M2 Q35 会用试电笔、万用表
* p0 d g; E. Z$ q7 N36 会用改锥、钳子、扳手、锯、电钻、冲击钻
8 I1 ~: `' Z( Y) R3 P* d37 会粉刷墙面、油漆家具
! o4 x' B4 v8 l, J38 会劈柴火、生炉子、连接烟囱
, P1 M9 @ d' ~6 |9 v6 Y5 \39 会修理水管子、换水龙头! R4 h, N5 I2 J4 ~: `2 I' r
40 搅匀混凝土、修补墙面和地面8 T9 G& I9 ^6 L( {
41 知道怎么除去衣物上的污渍
6 \# @% {3 a7 I* j1 h3 S42 会熨烫、折叠衬衫6 i9 E5 P' b" ^. V6 O# a
43 会整理换季衣物,并进行防虫防霉处理0 s9 |7 ~& G6 b2 X/ T# C( H& ~
44 会擦亮皮鞋、会打领带
( B7 N, m% a# Z# d* Z45 会安慰、逗乐女人
) w9 u" y1 M. G+ R46 知道女人的敏感区域并能让女人达到高潮
6 e) }9 F; d0 V! q8 T47 换尿布、喂奶和哄孩子
+ z {& p f8 v {, R$ o! w
" O% A$ G4 Q; M( ^, A% M' d医疗与卫生方面/ V. }: y# J' a
48 能正确区分中医与西医
6 S* n$ x; J1 `, w0 z2 S+ p4 ?7 _49 能处理常见的疾病, p6 F* C# \4 ~; {( D6 \
50 在医院会看病、挂号、拿药、住院、陪床
: x. y( j# | y6 ]# N51 会识别医院中主任、大夫、护士、护工
" n& S8 Q; F R2 N2 p52 会在药店买来正确的、廉价的药* h2 g9 }& j3 o0 U; V
53 会熬中药9 |: E* k1 u4 V i2 x$ z+ n
54 会基本的按摩*作9 H; v3 H; t1 c% S' s" ^
55 准确找到常见穴位
1 G" T1 O( @! x$ ^! g; F9 d56 会刮痧、拔火罐
3 L, g2 t$ ]' B# J; h+ A57 会量体温和血压
& i/ u2 w7 Y) ^5 D5 |1 y6 M! J58 驱赶苍蝇、蚊子、虱子、跳蚤
$ V3 E+ f+ h3 v' ^7 O, O59 会捕鼠' ?. s& D+ A' q3 k2 j
60 能够安全保存和使用毒药、农药、杀虫剂等。+ C) R3 u9 K: x
6 e3 T8 p, ?, H
家庭与文化/ m: D0 J j% `% Y9 q/ b8 o8 z; Z
61 知道中国传统的节日及过节习俗
K2 e1 p! q. p0 d62 会使用毛笔( P/ O$ U1 r* ^; r" U
63 认识繁体、简体字
, o5 @3 f/ O- V) i0 e64 能读懂文言文' N! U( K1 l+ w
65 会布置祭祀供桌
, k y/ S! \- L: q7 U1 y66 能快速叫出五服内任意两个亲戚之间的称呼
& K& S& U' b) ] @, Q* ^67 了解中国人的喜好与禁忌" f; B# _# f+ O- l
68 能区分各地方言
0 j8 E1 ?* S2 G; r, f. C, G- k" A69 知道各地的风俗习惯
' U3 z8 _! q7 m1 N70 会欣赏至少一种戏曲" y+ O" [" D ]
71 会至少一种武术9 B: ^. h w, v
% h: S7 M& q) @9 O9 @* i0 [# w, ?军队和野外生存技术
. h, y$ B; J# n$ ^/ a72 叠豆腐块的被子
2 U2 r8 b0 ]$ b' T4 J) C73 会打背包、行李装箱$ O3 |' q8 M4 R) i/ H; I$ K
74 会打各种绳结
5 i4 O# p0 z( {& h- T7 ~$ {3 ~75 会敬礼、正步、立正等基本队列动作3 |! ] n; T% k5 L4 Y+ A! m# N
76 会匍匐前进、亻府臣卜扌掌、引体向上、仰卧起坐9 X; ~# H9 b# |# m6 d2 D, E& z9 F
77 会射击
! j" j5 X9 Z" p, x$ x78 会钓鱼、捕鸟
s$ ~8 X4 {4 Z2 b79 会划船、游泳
/ t( p" W' `" @0 e" v7 ]5 U7 O1 u# ]80 会野外露营4 ]' `# H; F+ V% ^$ K
81 会包扎、骨折固定、止血、人工呼吸$ y% b, l2 `" \
82 会处理中暑、冻伤
4 Q. [1 w, K/ k% f! _- I83 治疗毒蛇、蝎子、蜈蚣伤- }: G% |! Q% F5 m: ~
84 掌握地震、火灾、水灾、山洪、闪电、台风中的生存技能
5 k/ }! P* M# n" k% G# S* U工作技巧4 L$ O8 E% \2 @$ J
85 会汉字输入法- X* @; S4 _. ]( H! h! ~$ f
86 能拆装家用台式计算机# u0 G1 j& ]. t, w9 ]! i
87 能安装*作系统和常用软件) g. O J) s. p* v% ^3 G
88 会使用相机和摄像机
" b) ^. a+ Q7 S/ q8 G6 W$ O; G89 能设置家庭影院、高清电视
. ^9 U: K. D0 ]! z90 会使用传真机、打印机、复印机、扫描仪、投影仪. W# U1 ?- `2 ]
91 会刻录光盘、数据备份
0 c L8 n/ j- ~( i E92 会使用网银
6 ~2 D+ @1 \; X' u' m0 B7 g93 会使用淘宝和支付宝购买物品
5 w) }3 X1 B2 z4 f$ f/ G% Z94 会保护计算机信息安全
' ?. s" Z. c; G& @. E95 会网络发帖并避开敏感话题, H' S$ z0 M; {- S" L9 m2 S+ [
' H: ~ s) B( L. M7 D
社交技巧
" }: F/ I3 q- B' D96 会敬烟与敬酒
& q8 T8 X( r+ D- t' Z5 P97 会恭维长辈与领导
* B0 x v1 X$ I6 \6 k- o2 \98 会分析单位中的派别并站队$ ]* z2 E! D& [$ p, k( h/ Q3 Q
99 会写官样文章、发言
) P, t2 t2 `; N$ A. } A100 会送礼、红包,行/受贿
- N! @' e8 i8 I" ?5 [8 F, v' @) V; h) j: n9 s. e
