1 | GB 4806.1-1994 | Hygienic standard for foodstuff rubber products | 食品用橡胶制品卫生标准 |
2 | GB 5083-1999 | General rules for designing the production facilities in accordance with safety and health requirements | 生产设备安全卫生设计总则 |
3 | GB 12073-89 | Security and sanitary standard for dairy equipment | 乳品设备安全卫生 |
4 | GB 16798-1997 | Requirements of safety and sanitation for food machinery | 食品机械安全卫生国家标准 |
5 | GB/T 14211-2010 | Test method of mechanical seals | 机械密封试验方法 |
6 | JB/T 2934-2006 | Carbon material and carbon products for mechanical engineering | 机械用炭材料及制品 |
7 | JB/T 4127.1-1999 | Specification for mechanical seals | 机械密封技术条件 |
8 | JB/T 4127.2-1999 | Classification method for mechanical seal | 机械密封分类方法 |
9 | JB/T 6629-1993 | circulating system of Protecting mechanical seals | 机械密封循环保护系统 |
10 | JB/T 7369-1994 | Inspection method of mechanical sealing surface flatness | 机械密封端面平面度检验方法 |
11 | JB/T 7401-1994 | Optical flat | 平面平晶 |
12 | JB/T 7757.1-1995 | Coil Springs used in mechanical seals | 机械密封用圆柱螺旋弹簧 |
13 | JB/T 7757.2-2006 | The rubber O-Ring for mechanical seal | 机械密封用O型橡胶圈 |
14 | JB/T 8872-2002 | Specification for carbon-graphite sealing ring for mechanical seal | 机械密封用碳石墨 |
15 | JB/T 10706-2007 | Rubber O-ring coated fluoride plastic for mechanical seal | 机械密封用氟塑料全包覆橡胶O形圈 |
16 | JB/T6619.1-1999 | Specification for light mechanical seals | 轻型机械密封技术条件 |
17 | JJG 28-2000 | Optical flat | 平晶检定规程 |
18 | SB/T 222-2007 | General speciafication for food machinery-basic technical requirements | 食品机械通用技术条件 基本技术要求 |
19 | SB/T 223-2007 | General speciafication for food machinery-technical requirements for machining | 食品机械通用技术条件 机械加工技术要求 |
20 | SB/T 224-2007 | General speciafication for food machinery-technical requirements for assembling | 食品机械通用技术条件 装配技术要求 |
21 | SB/T 225-2007 | General speciafication for food machinery-technical requirements for casting | 食品机械通用技术条件 铸件技术要求 |
22 | SB/T 226-2007 | General speciafication for food machinery-technical requirements for welded and riveted components | 食品机械通用技术条件 焊接、铆接件技术要求 |
23 | SB/T 227-2007 | General speciafication for food machinery-technical requirements for electrical installations | 食品机械通用技术条件 电气装置技术要求 |
24 | SB/T 228-2007 | General speciafication for food machinery-technical requirements for paintings | 食品机械通用技术条件 表面涂漆 |
25 | SB/T 229-2007 | General speciafication for food machinery-technical requirements for product packing | 食品机械通用技术条件 产品包装技术要求 |
26 | SB/T 230-2007 | General speciafication for food machinery-Rules for product quality inspection | 食品机械通用技术条件 产品检验规则 |
27 | SB-T 231-2007 | General speciafication for food machinery-Rules for product labeling, transporting and storing | 食品机械通用技术条件 产品的标志、运输* y. G8 h/ x! g8 H7 l3 ~0 t
与贮存 |
