楼主: 西北风zlh
材质为Q345B锻件正火工艺---[求助]
发表于 2007-9-18 18:24:38 | 显示全部楼层
Re: 材质为Q345B锻件正火工艺---[求助]
890-930保温,保温时间1.8分/mm(有效厚度)
发表于 2007-11-23 11:37:48 | 显示全部楼层
招聘热处理工程师
百瑞福机械加工(昆山)有限公司是一家先进的欧洲高新技术企业,专营石油工业机械锻造加工。) {8 G3 D2 o% C7 q+ j2 X8 g
我公司现欲招聘一名热处理工程师,详细情况如下:
  f% x! N5 x  P9 R( [9 U 4 x( k$ O' e& |/ |6 ^' b7 k
职位描述:
; ~* v8 y* T7 X* e. w-为供应商提供专业技术咨询
$ Y# x. k+ `5 d: B+ T-对供应商的工作进行跟踪服务  n6 Y) m$ x$ X' j1 Y; x7 W" j
-进行调研,测试以及质量监控7 Y. m5 ]) I3 ^/ l' W
-与总公司技术部门进行沟通( d2 I! P/ z9 d) O$ M0 r
-此职位工作地点在江苏昆山
3 B( p/ B. F9 ?, e, e) c) w , l, x3 |$ [' T- h- e
职位要求:
. ?/ _" n; Z8 F; `( h! p-大学学历,机械工程、冶金或相关专业
7 Y  _. t- I3 \5 [; {-具有钢铁锻造加工的实践经验
" l( |8 a$ P/ ?3 Q7 ]# `-具有热加工相关经验; w7 [6 r' ^- `7 p
-具有机床厂工作相关经验者优先: ?/ H: f7 U2 g  ^8 w4 [
-3-5工作经验,有更多经验者优先
$ k; h# s$ M! O: G1 G! o$ l) G  {) t-能运用英语进行简单交流
' e" Q( y, X: y
) V. D& Q- U6 g$ \) E开始工作时间:200712
. C5 v0 ~$ a" F6 B2 I! z ! R1 E- A' f" U& C* h) Q1 }
有意者请将简历发送至
, y8 J* N9 t3 [7 A
leona.li@Scandicsourcing.com
7 D# V4 v: T: v0 c3 L6 u
请注明应聘求职。
4 P( Y0 Q8 Y8 W5 x' W + R( U4 a9 w  B* c2 v2 H, f
Bridgeforth Engineering is a technology leading European manufacturer of forged and machined steel components used in the Oil industry.
% {/ H( G, r8 |0 `
8 @5 z) B5 d8 \For their new plant in Kunshan they seek an experienced material planner. * f5 t2 S( q  ]) m2 k
. r& t& U4 |* P$ c3 e. m/ }( l* E( w
Responsibilities:
3 }5 J' @$ G$ Y2 G7 A7 M-/ Z9 R, n4 K1 }0 P% a6 E$ K
Provide technical specifications to suppliers
: V* R6 a" d$ y5 F# z3 K-8 y( Y# N# w! M* l2 o0 J
Follow supplier orders in progress
  Q) i/ _! N( N+ Y, a0 x! t7 _
/ P9 W- M4 B  n! `2 W3 m
Do inspections, measurements and quality control
3 o: ]* Y$ F3 G( U: q, ^$ A-6 C: t; s0 Z  ]' e, A
Communicate with head office technical department
) V1 ~2 H' ~; b
2 _6 O. D2 ]; Z. c8 \
Requirements:
0 `1 _7 R# J& y* i" ~Degree in metallurgy, or equivalent practical experience working with steel forgings. V# y3 `7 p4 n# K# h4 N* A5 w
Experience of heat treatment valuable. u. v5 ]1 j* R( c+ h6 n
Machine shop experience is an advantage% ]: I  u+ v  v  d! ^
Minimum 3-5 years working experience. More is an advantage.
1 h- y& a3 V% A8 r; }Able to communicate in basic English
发表于 2008-1-7 21:57:38 | 显示全部楼层
可以根据客户的要求啊!一般是870—920就可以拉
发表于 2008-7-18 14:38:55 | 显示全部楼层
Q345B是碳钢中的保证力学性能钢,供货时可以直接使用,锻打压力加工后产生了应力,及内部组织不均匀,可以采用正火出来提高硬度,改善切削加工性能.
GMT+8, 2025-2-24 00:05 , Processed in 0.051863 second(s), 12 queries , Gzip On.
