需要加工的图纸上有一个关于齿加工的参数表,看不太懂,有哪位高手帮忙翻译一下,感谢! % M* Y. f% r: K
INVOLUTE SPLINE DATA: TYPE OF FIT--------------FLAT ROOT SIDE FIT EXTERANL NUMBER OF TEECH ----------110 PITCH----------16/32 PRESSURE ANGLE----------3O° BASE DIAMETER---------------5.9539 REF PITCH DIAMETER---------6.875 REF MAJOR DIAMETER---------6.9375/6.9155 FORM DIAMETER---------6.8019 FORM CLARANCE (RADIAL) ---------0.007 MINOR DIAMTER---------6.771 CIRCULAR TOOTH THICKNESS CLASS---------5 MAX. EFECTIVE ---------0.0982 MIN. ACUTAL---------0.0937 MAX. ACURAL---------0.0956 |
