查看: 18668|回复: 23
钢的热处理工艺代号及标注示例
发表于 2006-5-8 09:54:34 | 显示全部楼层 |阅读模式
6 a$ o$ B& z5 J6 Z S) o( A. m; a" [4 c+ A/ ]; O) }) G; c3 v( x5 [% _4 P6 [" L! V) K0 U+ n% G2 @, F( c! S Q9 y$ }0 Z$ F8 X9 @% R1 ]- P6 W- X% d# H" Q: w8 z) k, j0 `8 [2 G0 L- |& R3 y: e$ i$ j u ^, U: q9 `) [& Z, C( f5 z/ W: {8 ?4 V$ f+ Y2 S: F. _9 `5 w, A7 o7 M! R+ V+ v7 {. @' u7 Q/ l0 u; Z6 K$ ?2 k7 u# ?8 m3 }3 X! v, ~7 Q$ r3 u) P) S! W1 H/ j1 p" L9 x6 M! U7 Q9 r! V3 G* d7 n# Y; m' e% D ^- {7 W: f5 P$ w: B. R2 r r: K# o- ?3 Y' e8 k+ l0 C& R0 J% v2 \$ L5 B/ \. K9 w/ X+ G. {& ^4 \6 k9 k/ j2 V+ f& m7 H" u3 C, D* c/ w% W& i# b2 G% B/ X, y: W+ M$ w+ b2 f L6 u4 g$ W2 b; R9 w3 ~7 J R# O2 ]& [+ z4 M: X% g3 I/ V$ m% p3 Q) F* r3 T! U, |1 K7 A$ U$ w! S# Y2 \4 v: @( H1 u% }/ F0 s- g6 S, ` C% r$ P- {6 t! b) B. U$ m+ s* d% M- z: c7 D% ]6 i+ }8 L8 s" f( Q* a8 A" B# h+ b. n- O# f+ `& I3 e' S2 Y2 Y# ]; m) H& p& y$ Z4 Q: l B2 F ^' ]$ Y% ~# p' Y9 o. c$ K0 W/ {& a) h% d M! k" e8 K+ { g6 ^+ q* X) C% K: A; U3 s+ }7 t8 F& W, [, C$ L: S u: l" J. D7 \: i: y+ I- `, {4 ?: v. A; ~4 F9 P1 o7 P4 K. [* X( y6 C& ^4 c6 ]+ R# B; [- B4 z3 i: c1 `# L u+ O1 |4 W1 V) h% u* g# q5 Y! l( M1 L2 d* s- A. v6 }. G' t! Z1 U& f9 R( ?* w, T6 S; d6 t% Q& J# C' P2 K9 f/ z% Q7 u; [. |* ~( e- g+ O3 t5 Z+ H; F5 j! S1 R$ ^ v" m/ ~( S0 @* l' n# S- F( [9 N, ^3 [% N& I3 t. J0 T, t: ^" y9 i, d& A
3 }5 j2 H1 x8 }
热处理方法fficeffice" />
6 \: _3 g9 }* l4 H6 Y/ G
代号
0 y" M& P9 g* G6 L$ o" B$ j
标注示例
3 _+ p) S$ X7 }) L; y1 L0 S
退火
8 P% ~9 d% v0 J5 Y
Th
. T3 Z; N) m% T( x' c
; d- E0 n v; A8 M% M
正火
! B ~: N2 ~& _" S
Z
, p: P! e5 M; ~" l8 D! h7 \0 Y
0 E9 I1 y1 O8 F( c! E* X4 H' y6 j
调质
^! m8 T- B& f: W @7 [: g
T
& f. Q' |& `- w- V# c
T235——调质至220-250HB
" C" v d$ D T9 d/ r% G/ l+ T. P( X
淬火
5 h6 W# J7 Y6 B0 X+ `
C
! U B# }& w3 N7 d8 A' b
C48——淬火回火45-50HRC
1 P3 F* E( e4 x7 @
油冷淬火
9 {" {4 I3 ~2 S8 ~ j9 ?$ u
Y
, d* I; e2 b/ D B' k' } j
Y35——油冷淬火回火30-40HRC
0 e. [) E+ H% O' g$ H4 G
高频淬火
5 J4 h* P: S1 p5 n/ Q l" p* v
G
' C0 y# ?5 V6 \" ^" A" l$ w
G52——高频淬火回火50-55HRC
0 n% f N: U6 a
调质高频淬火
2 U( A' z, v# m, `- E! C
T-G
% m7 [* D" h$ V' t1 @' G2 O
T-G54——调质后高频淬火回火52-58HRC
8 x' f- Q* E$ V- d
火焰淬火
" ~8 K1 `, S" S" s
H
) _; \, g; R; r
H54——火焰加热淬火回火52-58HRC
) V* Y0 s: g- C* ^
氰化
$ I4 n& J. w* L/ ?) P k
O
* Z0 Y7 y8 k4 u; f! g
O59——氰化淬火回火56-62HRC
/ L; H4 i% n! I# A+ s3 [" ?$ u1 ~
氮化
$ n) w! N4 @" t d
D
/ N( I1 _& k" I, | c3 ~% w% ?/ U
D0.3-900——氮化深度0.3,硬度≥850
9 h7 ?. n8 O3 M
渗碳淬火
4 d/ u, o1 s5 O+ Q, O
S-C
) t+ b6 g! y/ D8 t
S0.5-C59——渗碳层深0.5,淬火回火56-62HRC
" P: p X/ J6 A% O1 W7 Y
渗碳高频淬火
5 {4 F* U5 e4 u9 W' {5 y
S-G
) f( O1 s4 j, V- u" T- X
S0.8-G59渗碳层深0.8,高频淬火回火56-62HRC
发表于 2006-5-8 10:21:19 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
谢谢
发表于 2006-5-8 11:37:47 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
非常感谢
发表于 2006-5-8 22:25:49 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
謝謝樓主﹗
发表于 2006-5-10 13:05:50 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
  謝謝樓主﹗
发表于 2006-5-16 18:04:34 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
谢谢楼主!
发表于 2006-5-16 19:31:46 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
谢谢指教
发表于 2006-5-17 11:24:37 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
先谢谢了!
发表于 2006-5-18 19:50:38 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
谢谢了
发表于 2006-6-6 08:43:32 | 显示全部楼层
Re: 钢的热处理工艺代号及标注示例
谢谢楼主
GMT+8, 2024-11-25 19:32 , Processed in 0.059634 second(s), 16 queries , Gzip On.
