本帖最后由 林霸赫 于 2012-11-13 10:56 编辑 5 q. J/ _( L7 u; Y% V# J$ ^# w# q4 J
饿狼小军 发表于 2012-11-12 22:43
7 o s/ E5 S6 R! I+ s不知道这个是不是通过动重心来转向的
& A3 j( X; B; o P
L8 U9 d, T, _; c6 B) {8 C实物的照片应是这张。Mosquito_Helicopter5 r1 h" Z$ k8 I* C. T
Length: Frame 16 ft., Overall 20 ft. Width: 72 in., Height: 83 in.
: K8 p; J Z9 C9 ?! D) A6 \4 v U8 _: _6 R# V5 D% I
Rotor Diameter: Main 18 ft., Tail 40 in. , ~" r0 ]& `" d% g7 A8 u
Empty Weight: 254 lb.
: ?5 L4 Q& x6 G' Q+ F4 h; [Gross Weight: 530 lbs., Useful (Pilot) Load: 250 lbs.9 P1 u3 ^# s7 T: U6 C
Fuel Capacity: 5 US gallons (as required by FAA Part 103, Ultralight Regulations)
3 y/ k6 B$ Z. d8 ?! ~Engine: Compact Radial Engines MZ202, 2 cylinder, 2 stroke, rated 60 HP (45kW)5 V8 N7 f) |8 x! L7 g* b
Electrical System: 12 volt DC battery, starter, 180 watt alternator * `( T- o5 z# v* J
Rotor Speeds: Main 540 rpm, Tail 2500 rpm / I" e @5 ]) W8 P j( A
Fuel Flow at Cruise: Approximately 4.5 U.S. Gallons per hour " ?; P0 w! l3 K: q0 w f
Flight Duration Time: Approx. 60 minutes depending on conditions, loading, speed, etc.: d+ J. ?/ `& U" z
Performance: Hover in ground effect: 8,000 ft. (estimated) , [2 ?( a) k" D
Hover out of ground effect: 6,500 ft. (estimated) + J7 G- i9 y! A' x0 a( @: ^
Max Speed: 70 MPH
4 t0 s m$ U `7 e; N( S" B+ }The FAA has ruled that the maximum speed of 63 mph normally applied to fixed wing ultralights does not apply to helicopters due to their unique power curve. 2 L+ s2 \* y! q' z$ r V/ X5 N# ^8 M: Z
