下面菜鸟小弟的config也挺烂的,凑合着用吧,呵呵,希望能有用,{:soso_e100:}9 k7 U& J0 d( [+ z) V) p
drawing_text_height 5.000000
7 f5 |1 c. k& e, o8 S" r3 g. y2 O. Utext_thickness 0.000000+ f9 `) m7 ?6 R. g
text_width_factor 0.800000# |, R1 |# L' \! D6 C
broken_view_offset 1.0000008 t4 G0 F8 h" J
create_area_unfold_segmented YES
3 F. _1 M; _7 ]- H$ X6 sdef_view_text_height 0.000000" _) S8 k% W \. o$ N) {
def_view_text_thickness 0.000000
" _& x* X9 s5 u/ h( fdefault_view_label_placement BOTTOM_center
4 K: P: e' x1 idetail_circle_line_style SOLIDFONT
- Z! Y' R5 x/ r# d" ldetail_circle_note_text DEFAULT
8 h0 ?9 g% F. V1 X m- `& Zdetail_view_boundary_type CIRCLE
' R- t" [/ E& c/ j5 j6 l4 Ddetail_view_circle ON
1 \: A& [. G1 q8 z! `detail_view_scale_factor 2.0000002 b' x3 ?( Y0 s% k6 K& }9 O) n. P
half_view_line SOLID
' k: k" n$ y/ g8 K6 S9 a. I2 Wmodel_display_for_new_views FOLLOW_ENVIRONMENT9 N, D! g9 ~; E; I5 p' n
projection_type THIRD_ANGLE8 h% {6 v! B' u/ a
show_total_unfold_seam YES
- X1 q# L! [. g9 T3 Ytan_edge_display_for_new_views DEFAULT
; t5 @, |9 J# Y) ^' I' w9 d* h( ]view_note STD_ANSI1 E6 H* \& r# s
view_scale_denominator 03 h# B# e& ^* i9 d6 f. U2 @- @
view_scale_format DECIMAL
6 m' l% ^2 e# r& t) |! g5 {& Ecrossec_arrow_length 3.0000006 ]& S) M w! j0 l' X0 f
crossec_arrow_style TAIL_ONLINE+ b) B4 p* P7 V0 a
crossec_arrow_width 3.000000
1 C# V# l* e& j8 m( n4 U) r5 wcrossec_text_place ABOVE_LINE6 G+ j' t% i7 e; U
crossec_type OLD_STYLE6 U0 b0 z, J. ^
cutting_line STD_ANSI
1 x9 H- w: A7 C" N; W( k2 V+ qcutting_line_adapt NO
/ G+ r$ Y) \0 F" a! Q: ?2 Ncutting_line_segment 0.000000& n! e4 w/ i" [0 a7 p- P
def_xhatch_break_around_text NO# H# T& N0 G! M E4 G$ s5 s
def_xhatch_break_margin_size 0.1500007 q# N% `( T3 X, W( T3 c; h: G
default_show_2d_section_xhatch ASSEMBLY_AND_PART1 }! p0 V6 A Y: g2 {6 e2 m" `
default_show_3d_section_xhatch YES( |* D2 u. v# R8 o5 _! R
draw_cosms_in_area_xsec NO/ I7 O5 N9 M* o3 v, E4 Y
remove_cosms_from_xsecs TOTAL! ~; h7 ]) d! E& |3 ^5 N4 Y8 Z8 b6 g
show_quilts_in_total_xsecs NO
( D1 j, w7 b( [6 _8 R) jdatum_point_shape CROSS
( B5 G6 G, P, B C$ pdatum_point_size 0.312500
. [3 D' ^9 n8 F# ^, e! M# \2 ^3 nhidden_tangent_edges DEFAULT
3 s" j. k% d8 p' }. r" v/ ahlr_for_datum_curves YES
% e) [! g& d# v4 Q. O- Uhlr_for_pipe_solid_cl NO4 I9 T6 o" K7 F, R/ N4 v: s0 I7 n
hlr_for_threads YES# Y; g0 E3 ^; x
location_radius DEFAULT(2.)/ g) ^% D' K! E! M5 E
mesh_surface_lines ON
0 H5 @3 R) `: v; B6 Wpipe_insulation_solid_xsec NO9 Y; i* ~1 r) J0 ], k
ref_des_display NO2 Z* o( f5 H4 E
show_sym_of_suppressed_weld NO9 V _ P: O& j, q+ o3 v6 `4 X
thread_standard STD_ANSI
4 w* u! ?- s1 t% Yweld_light_xsec NO
) G- C+ w; ^9 L" s' c+ ?. Uweld_solid_xsec NO \$ P" N5 N8 o. i: S( y% F
allow_3d_dimensions NO+ w; M- `( I" Q+ t! s, R& N
angdim_text_orientation HORIZONTAL9 f Q/ R8 \( ?2 y4 V- n
associative_dimensioning YES
' W! i N4 [8 Z; e gchamfer_45deg_leader_style STD_ASME_ANSI- b+ r3 J) H2 [# M4 s) j0 x
chamfer_45deg_dim_text JIS$ Y, H2 Q+ M' d. Z4 S9 z' A
clip_diam_dimensions YES7 K% H" l, F8 I4 W9 J
clip_dimensions YES
: w3 T2 M' q, N2 m: r; E: Wclip_dim_arrow_style ARROWHEAD
# ]' E- n1 |7 g# edefault_dim_elbows YES8 D1 k3 Y# Q9 |& p: \- u' ^
dim_fraction_format DEFAULT
& r+ b5 E# {4 I3 Adim_leader_length 0.500000/ z- j, M$ z w3 u
dim_text_gap 0.500000
" d3 S2 c( }$ X& C a, ddim_trail_zero_max_places same_as_dim& g% _8 F6 K2 d. d
draft_scale 1.000000( Y- R( P4 }( \3 L# A5 I4 u
draw_ang_units ANG_DEG h- q* \9 \/ a7 K4 o
draw_ang_unit_trail_zeros YES" y- z' T7 _( O2 `' |# w
dual_digits_diff -1! `6 u8 }3 g+ @: r* [4 B+ n/ X
dual_dimensioning NO& q1 W' w2 |0 y1 ]
dual_dimension_brackets YES( S& l- \' b! g/ P' S7 V3 Z
dual_metric_dim_show_fractions NO
a, N* V% j8 `! y. O+ |, n4 |! idual_secondary_units MM
* \% D% w4 j# ~ [6 J+ {iso_ordinate_delta NO
8 A' G- @+ {' Q) ?lead_trail_zeros STD_DEFAULT* Z. u7 o" u6 I" x( y1 l {
lead_trail_zeros_scope DIMS- }7 X# V0 G8 h+ }6 W
orddim_text_orientation PARALLEL5 J. V; a- s0 g3 w' {: u
ord_dim_standard STD_ANSI- D, x. |! m# j
parallel_dim_placement ABOVE" L- ]% y) D, |5 r- {6 [
radial_dimension_display STD_ASME
9 Z- H0 \( p+ Lshrinkage_value_display PERCENT_SHRINK5 P" Y/ x% }' g. |" m1 a4 }
text_orientation ISO_PARALLEL. ~/ n [5 s$ t; L& I: ]1 v3 X
use_major_units NO9 ^% g* j) \) n8 m, E
witness_line_delta 0.125000
; r" ]6 v* p, O$ @$ \witness_line_offset 0.062500/ ]7 X0 H8 R/ ~, c
default_font simfang
* x) B# ?5 V$ Y5 m' R8 y, m0 Idim_dot_box_style DEFAULT
: f$ V% s) }0 N v3 a# a% Mdraw_arrow_length 5.000000* [. W6 V6 {( ?1 P
draw_arrow_style FILLED4 g5 [- ^: N% l+ x7 |7 Z
draw_arrow_width 1.500000! t) d5 S) A; O1 z: I/ i. d
draw_attach_sym_height DEFAULT! q$ M; K5 t- e( b
draw_attach_sym_width DEFAULT+ F8 o$ H: ~! C2 A/ `3 I& Q
draw_dot_diameter DEFAULT L& y( g |: r; Y! T) k
leader_elbow_length 0.250000
3 }* E/ q8 l* P3 [) S) P7 h! ^leader_extension_font SOLIDFONT
* L6 h8 B4 P6 Lset_datum_leader_length 0.375000
0 S- i& S& w$ @1 f# W3 g/ t0 r R0 Aaxis_interior_clipping NO
5 t& ~; J' G# H* G ]- i7 w4 }axis_line_offset 0.100000
$ l8 Z6 ~* v, Wcircle_axis_offset 0.100000 l+ x* v- O. B7 b
radial_pattern_axis_circle NO
8 C+ y- Q3 C, o6 z. x" V- Hasme_dtm_on_dia_dim_gtol ON_GTOL5 ?' H; e5 E+ `
gtol_datum_placement_default ON_BOTTOM8 h# _" G# f+ n) g6 h- n0 q
gtol_datums STD_ANSI) M! _2 U3 r! o# p9 B" _
gtol_dim_placement ON_BOTTOM
* A K2 J! _8 Y3 h# X/ g) ]3 L3 J( ^gtol_display_style STD( |0 r" b' y& b5 k' r
gtol_lead_trail_zeros SAME_AS_LEAD_TRAIL_ZEROS7 P9 Y- Q/ z a1 r& p: U
new_iso_set_datums YES9 e' I. M! k& U0 P
set_datum_triangle_display FILLED w$ l5 r! v0 G3 [6 x9 v
stacked_gtol_align YES8 N* K) T: V' P5 n6 Z/ b
2d_region_columns_fit_text NO$ j/ B5 q& O5 d6 G# b" b
all_holes_in_hole_table YES7 G/ X/ D* N1 n
dash_supp_dims_in_region YES
. Q4 |/ N) {' l. g9 Qdef_bom_balloons_attachment EDGE$ M+ m) z. V, u* B$ |! h% s$ v1 A6 `
def_bom_balloons_snap_lines NO6 A. K5 l$ m3 G: H5 A+ t
def_bom_balloons_stagger NO5 Q( s, M" m5 X: ~0 C$ n
def_bom_balloons_stagger_value 0.600000
v! g! p( [# G# V" J$ a' ydef_bom_balloons_view_offset 0.8000009 `# `, ^" f. B$ N+ l$ V9 Y
def_bom_balloons_edge_att_sym ARROWHEAD$ F/ U" H' l& t/ T1 Z
def_bom_balloons_surf_att_sym INTEGRAL
0 B; h8 N5 k& X+ }( I' `2 omin_dist_between_bom_balloons 0.800000
. {* }" r* | Mmodel_digits_in_region YES* W) p. e& P$ }# s: \; E
reference_bom_balloon_text "DEFAULT"0 [1 v4 k, J* e3 X3 P5 z
show_cbl_term_in_region YES* d W( S3 ]8 n7 `' o' t; N! P
show_dim_sign_in_tables YES
1 }. S+ }! U4 V$ Q" r% w5 qsort_method_in_region DELIMITED
1 E% Y( R0 H" H" jzero_quantity_cell_format EMPTY! Z6 }# [9 b' d
draw_layer_overrides_model NO
2 j0 W+ O, f7 j( V c) Kignore_model_layer_status YES
/ P( y8 A; L/ G0 ?model_grid_balloon_display YES
. A4 M1 z4 B' n( K) {* k% M _model_grid_balloon_size 0.200000
/ K- C5 h* R) O" [model_grid_neg_prefix -
* h" _/ [) Q% T3 H; zmodel_grid_num_dig_display 0( B3 u( |3 n; @( } l S9 c* `! ^( e
model_grid_offset DEFAULT
* z& R' A! D6 n6 ]model_grid_text_orientation HORIZONTAL! H) k* z0 H1 Q
model_grid_text_position CENTERED
6 S& x, B5 c! L; ~pipe_pt_line_style DEFAULT" y, B% g1 N+ F. ~
pipe_pt_shape CROSS. l: L4 V9 b3 N$ r+ O
pipe_pt_size DEFAULT
0 D# S1 ]( U: L9 fshow_pipe_theor_cl_pts BEND_CL9 ~6 y: e; N' i1 t1 E8 l- ?, h
blank_zero_tolerance NO) G, H S {, ?4 b8 B/ [
display_tol_by_1000 NO- y' w" z2 W, R/ H- f' I
symmetric_tol_display_standard STD_ASME
! o9 A- y* T" ?tol_display YES8 l; U) {- \/ s$ r' ~; c
tol_text_height_factor STANDARD) t! ^' s* Q5 z( ~7 S% b3 F
tol_text_width_factor STANDARD/ ]5 [: Z/ B7 n% ~' }, P
decimal_marker COMMA_FOR_METRIC_DUAL4 L+ Z. V2 b& @% b* s+ u7 Y. b; n2 f
default_pipe_bend_note NO3 |0 F' v% N- ^0 N: V$ [
drawing_units MM2 |- w% x. g O$ p/ D- K# I6 i
harn_tang_line_display NO
. r( _" F9 F/ F8 ^/ R' i# hline_style_standard STD_ANSI' t4 e0 g2 S. L) J5 l
max_balloon_radius 0.000000; k( N% \+ g8 e7 q) m
min_balloon_radius 0.000000* X3 c* |+ b( {0 K+ D) e6 e6 _
node_radius DEFAULT( X$ i! v3 s) ^) H$ P
pos_loc_format %s%x%y, %r
7 F: O) _* a, y& Csym_flip_rotated_text NO% d! v. V2 E; d+ m2 |; V
weld_symbol_standard STD_ANSI; R) p% x W9 Q1 o4 V& X3 `9 n% K2 P
weld_spot_side_significant YES |* z0 n2 A( t8 f" a
yes_no_parameter_display TRUE_FALSE
I1 R( d( C9 ^! I' U6 @1 `mapkey x ~ Command `ProCmdFtRevolve`;
. N5 K% w3 \, B# T7 }mapkey b ~ Command `ProCmdSketDimension` 1;" p4 d- A, z. S6 |+ K" }7 B. d/ \
mapkey b ~ Command `ProCmdSketDimension` 1;" Q2 H& ~; z* d) z% ]/ L
mapkey c ~ Command `ProCmdDatumSketCurve` ;\
$ \6 T q$ c2 B# s zmapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree`1 `node6`;\
/ A/ @- w# ^. d: d6 ]mapkey(continued) ~ Activate `Odui_Dlg_00` `stdbtn_1`;' N! V7 m* m8 _9 u' X: a e5 w
mapkey l ~ Command `ProCmdFtExtrude`;
4 K0 W6 R9 d$ qmapkey s ~ Command `ProCmdEditDelSeg` 1;- |- a3 S u+ M# @
mapkey d ~ Command `ProCmdSketCenterPoint` 1;
/ f0 c8 L3 G) M/ Bmapkey q ~ Command `ProCmdSketRectangle` 1;
9 E( d$ `" |+ U$ W; [# P% ~mapkey y ~ Command `ProCmdSketConstrain` 1; D' X0 s6 o& l8 @/ u
mapkey z ~ Command `ProCmdSketLine` 1;
- r' N7 G3 R" ^! C- Qmapkey w ~ Command `ProCmdSketCircular` 1;
6 \5 H# A6 y- ?( amapkey k ~ Command `ProCmdHole`;
7 Y+ T* a, _2 { c7 L% w; umapkey a ~ Activate `main_dlg_cur` `tbLines` `ProCmdSketCenterline.tbLine`;\+ P( V1 Z) d: c% ?& ^ F* W
mapkey(continued) ~ Command `ProCmdSketCenterline` 1;
; Q" p F Z# P* cmapkey q ~ Command `ProCmdSketRectangle` 1;: n2 c# E; c; u# n) t
/ v Q* o1 E% `3 zmapkey b ~ Command `ProCmdSketDimension` 1;
* @9 `& O7 h" Q: tmapkey c ~ Command `ProCmdDatumSketCurve` ;\# Y9 {5 r( T. _1 k
7 H( w5 u1 M m# A6 Q/ ymapkey(continued) ~ Activate `Odui_Dlg_00` `stdbtn_1`;
/ G6 n8 m' f0 r( |mapkey l ~ Command `ProCmdFtExtrude`;) [& |0 a0 K% x. O0 C
' i# O9 W4 r/ C' l5 Lmapkey d ~ Command `ProCmdSketCenterPoint` 1;
9 L0 e6 h7 Q9 K2 h$ l5 rmapkey q ~ Command `ProCmdSketRectangle` 1;
z* X4 X# ~1 X4 E( @- ^mapkey y ~ Command `ProCmdSketConstrain` 1;* t. ^. h& F I; @3 M' i
5 e' l+ b% O4 [& Zmapkey w ~ Command `ProCmdSketCircular` 1;
2 V/ c* ^# b5 L' q* }mapkey k ~ Command `ProCmdHole`;
' O3 e# R- u/ F! _7 @mapkey a ~ Command `ProCmdDwgCrStdNewRefDim`;
/ H4 J1 O/ } f% ]$ qmapkey e ~ Command `ProCmdDwgCrSymInstCust` ;\
: A1 {5 R0 V& F. _! f# L2 _& x6 |4 Nmapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;
/ M* H, g) B* Smapkey a ~ Command `ProCmdDwgCrStdNewRefDim`;
$ P! q0 S2 I4 N9 [: f$ q* ^ [mapkey q ~ Command `ProCmdDwgShowErase`;
( Q5 m' D4 I9 W) K+ e& u4 f5 v!背景色% C$ k0 ?9 X1 t- ~
use_pre_wildfire_color_scheme YES
1 L/ P9 J5 ^! q& Hsystem_background_color 0.000000 7.058824 19.607843+ @, h+ r+ d: T
BLENDED_BACKGROUND yes
; A# Q5 {- ^; f$ `3 XSYSTEM_TOP_BLENDING_COLOR 0.000000 36.470588 60.784314/ ], I P+ Q' t# \ ?% R+ v* q
SYSTEM_BOTTOM_BLENDING_COLOR 0.000000 6.666667 19.607843$ v/ u, H3 H% h6 j
0 k: `& x) u) J- }mapkey c ~ Command `ProCmdDatumSketCurve`;4 H- o3 V' b, Y* ?
ref_des_display NO. q6 Y+ }* v9 r" W5 V. m
! O' ~8 M1 V$ K6 Jshrinkage_value_display PERCENT_SHRINK. R; b; k. y& b3 h; _ I* l1 G. u
use_major_units NO
) C. q1 B9 I+ Qdefault_font simfang) a* u" t M; p& O
M2 @! N* l% Y, X/ E. @model_grid_balloon_display YES7 Y7 U0 b- H$ ~# J+ l4 O2 J$ L) [
model_grid_neg_prefix -7 ~) D# s- q3 [: ^) m* t
. n b! \ a4 }+ F, s. a6 itol_display yes
" ]. N6 R8 U( X) d/ W zharn_tang_line_display NO3 I* [5 i- E4 v% I
display_axes no
& ]3 _. `8 c& |* Fdisplay_coord_sys no
9 w+ k6 \# L; P2 t( E+ H, n* u( {display_planes no
4 j" q) }; F. G( ]( [5 zdisplay_point_tags no0 m* K. N' w5 e) S
display_points no
4 t6 }( v: M. imodel_note_display no7 s* i, U# }& c2 o6 V# ^
pro_unit_length unit_mm
5 X5 g, X1 ]& H. Mpro_unit_mass unit_kilogram" l* u# _ `# A7 C% F8 v1 j& k
dxf_out_drawing_scale yes' B& V0 v4 M. s
fix_autocad_iges_text_scale yes( \8 K) m' b' y1 y/ U
default_draw_scale 1:1
2 v- g- k% e1 j8 t3 q6 gdrawing_setup_file D:\Pr\proe-system\CNS-china.dtl
4 b0 X8 Q! x: L; T; f3 Y& qangular_tol_0.0 0 0
7 X7 A6 z5 G! g9 P- ftol_mode nominal
+ x8 Q! X" T ?1 vsystem_colors_file D:\Pr\proe-system\config.pro\syscol.scl- @# A/ T6 C) e# g* X8 \
allow_confirm_window no
# G) ~- m& b, @retain_display_memory no5 @0 { {! s* o7 e7 q: x: ]
prompt_on_exit no0 V9 f3 e! |$ K9 q+ ~7 g6 e! m
template_drawing D:\Pr\proe-system\format_dir7 J, ~( r6 F" |
template_solidpart D:\Pr\proe-system\es_solidpart.prt.96 C3 D: g: ~' T% P: o
template_designasm D:\Pr\proe-system\es-designasm.asm.5
( ~" m3 b% I0 T6 S6 gtemplate_sheetmetalpart D:\Pr\proe-system\es_sheetmetalprt.prt.3& `7 Q+ ]' s4 U9 Z9 W8 j" f
pro_format_dir D:\Pr\proe-system\format_dir, g5 s, Q6 q u& B+ P$ L
pen_table_file D:\Pr\proe-system\table.pnt6 Y3 k) s' I* p9 P7 T
pro_font_dir C:\Pr\proeWildfire 4.0\text\fonts\chinese_cn( I" t# c& l) L' m3 _$ P
pdf_use_pentable yes
/ P ~2 T7 j# n9 W# Xmapkey $F2 @MAPKEY_LABEL关 闭;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\( _7 s4 \# l- U- M
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
* ] z: F. d" a: jmapkey(continued) ~ Activate `main_dlg_cur` `File.psh_close_win`;
$ q: O9 n2 Y* O3 L! p* emapkey $F3 @MAPKEY_LABEL打 开;\
' w. e. E; k5 x2 gmapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelOpen.file`;
& Y1 S/ ~6 b; F: R) E6 i5 amapkey $F4 @MAPKEY_LABEL保 存;\
6 [1 X9 l& W# x+ w/ i( K2 |mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelSave.file`;\3 P7 |- v0 ]4 P3 U
mapkey(continued) ~ Activate `file_saveas` `OK`;# N) s$ { Z( Y1 L
mapkey $F5 @MAPKEY_LABEL设 置;~ Select `main_dlg_cur` `MenuBar1`1 `View`;\& B t) {9 H% @5 {" @ j
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Edit`;\: T. q* J% r$ o( }9 c( @
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;~ Activate `main_dlg_cur` `Edit.pshSetup`;* M1 r2 z; ^0 P9 I U! c" d0 T
mapkey $F6 @MAPKEY_LABEL测质量;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\7 @6 [/ ]$ m& B! B$ T: n8 ?
mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_geometry`;\1 p v9 p, Y- O: J4 T
mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_geometry`;\/ O+ c& m+ y4 \. d$ a
mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_model`;\
@, m T+ [9 i# I/ ^6 c: b3 vmapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_model`;\
! |$ Y0 X0 m! a' t1 amapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_measure`;\
' o( z F: `: O* J. H- h# I8 K0 \mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_measure`;\
) A( R( N: z( ^2 g1 }mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_model`;\/ V2 V4 o, d3 z( Z! c4 q
3 V* n6 {1 p, U$ omapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_model`;\3 l% A& l2 W$ O5 l
mapkey(continued) ~ Activate `main_dlg_cur` `psh_na_model_mass_properties`; S# s3 L- }: V1 h8 S7 z4 j4 @ ^# m% }) H3 O
mapkey $F7 @MAPKEY_LABEL测直径;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
0 R3 i! q" ~& `2 Bmapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_measure`;\# |- ~: g8 m& X- f% j. X& M
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\, {# Y; r' N8 g7 C* ^
( J8 i4 K7 A9 _; w$ @+ lmapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_diameter`;$ C- V! D: B8 C( |2 ~, r
mapkey $F8 @MAPKEY_LABEL测距离;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\- h5 H0 e+ P: V! P
6 W. k! X7 U9 {. w b# v9 ]mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\, }3 B; E0 E f: H) w
: _: N( I# U. W/ ~mapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_distance`;
" \% b: Y& y% Nmapkey $F9 @MAPKEY_LABEL设目录;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\ P3 ]* K$ D1 E7 A3 b
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\# ^6 ?- m! J+ q G- z- U
mapkey(continued) ~ Activate `main_dlg_cur` `File.psh_working_dir`;% A, c( W! P, M! {& w
mapkey $F10 @MAPKEY_LABEL拭 除;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\; ^% e) s& q* \6 i% t6 J/ ^
mapkey(continued) ~ Select `main_dlg_cur` `File.cb_file_erase`;\3 @& _- x/ r3 q2 Z
* ]- U7 x2 o, ? Dmapkey(continued) ~ Close `main_dlg_cur` `File.cb_file_erase`;\# N( Z* m7 o! u; @
mapkey(continued) ~ Activate `main_dlg_cur` `psh_erase_not_disp`;\
) V- ^( ? l( Smapkey(continued) ~ Activate `file_erase_nd` `ok_pb`;
% V$ S0 m! J/ k. L9 mmapkey $F11 @MAPKEY_LABEL删 除;~ Enter `main_dlg_cur` `EMBED_BROWSER PRINT`;\
& V2 x- B1 f$ ^' c, pmapkey(continued) ~ Exit `main_dlg_cur` `EMBED_BROWSER PRINT`;\
% l m' _4 z- S& i) C: Emapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `File`;\$ c6 e7 k4 {: ?# u) C8 y0 O/ M a
mapkey(continued) ~ Select `main_dlg_cur` `File.cb_file_delete`;\
" [8 y9 D7 s2 p! ]: o6 ]mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
|% G z& L8 m8 e; Z1 P% O8 amapkey(continued) ~ Close `main_dlg_cur` `File.cb_file_delete`;\
( ]$ r" Z5 z) z. _+ qmapkey(continued) ~ Activate `main_dlg_cur` `psh_purge`;;
( u% C: g0 W5 Lmapkey 1 @MAPKEY_LABELPurge;% c; z$ ^$ X4 D! P
mapkey $F1 @MAPKEY_LABEL新 建;~ Activate `main_dlg_cur` `ProCmdModelNew.file`;
9 M9 d, y+ T( {( `+ s1 o& Oauto_regen_views yes
2 o! l4 V& G4 C8 h4 T! ]force_wireframe_in_drawings no5 a3 |' R1 r5 D2 x% Y# \, A
linear_tol 4 0
- z7 R3 C1 [" w6 k% qshaded_postscript_background no( c. t, M" w2 D+ P
use_software_linefonts yes. B% d/ @9 f9 I( B* o
plotter HP1055CM; @' C W0 X0 Z/ x( b0 O. m
plotter_command WINDOWS_PRINT_MANAGER
& c5 m+ ^- M! d2 [2 Zuse_8_plotter_pens YES
1 Y) B: E# {& [save_objects changed
1 H: X3 o/ y+ a* _& R6 J' r* s7 I) wspin_center_display no
4 N" M, @( v: m3 V1 ^" I& \menu_translation both
. q0 v9 v$ A" b, s: _mass_property_calculate automatic
# \, Y. c# x1 S5 y/ j( [" huse_pre_wildfire_color_scheme YES5 ?: U4 c, K6 S( C2 ?
system_background_color 0.000000 7.058824 19.607843! R- _; B8 O" `8 [, |0 t
dxf_out_comments no- D4 {: t+ _( W$ c8 j- x
dwg_export_format 2004
& i( w. W" t3 J3 ^: ]" H- }mapkey r ~ Activate `main_dlg_cur` `tbLines` `ProCmdSketCenterline.tbLine`;\6 O6 O, N" e& p4 I1 b+ ^0 G; R; N- r" ?
mapkey(continued) ~ Command `ProCmdSketCenterline` 1;) M& P. R! Y4 l
mapkey v ~ Command `ProCmdSketReferences`;" u b/ ]) M/ P3 R1 Z+ ]+ J+ |$ i
mapkey m ~ Activate `main_dlg_cur` `chkbn.package_odui.0`1 ;\0 ~1 b" `9 ^7 e" L/ M
mapkey(continued) ~ Open `package_odui.0.0` `PH.motion_type_opt`;\
! d/ @; R: u$ I! O! c+ Tmapkey(continued) ~ Close `package_odui.0.0` `PH.motion_type_opt`;\
& f- G% M3 M: c. u# O/ N3 O2 Vmapkey(continued) ~ Select `package_odui.0.0` `PH.motion_type_opt`1 `Translate`;
" U: o1 e) q2 t. `mapkey x ~ Command `ProCmdFtRevolve`;
; ?; |: T& I7 f. k: [mapkey b ~ Command `ProCmdSketDimension` 1;
4 G8 |. M/ Z: F: Ymapkey c ~ Command `ProCmdDatumSketCurve`;
3 ?+ {; R9 e5 O! l8 _5 x7 }mapkey l ~ Command `ProCmdFtExtrude`;
& T2 j; I7 |7 z& D# |4 Zmapkey s ~ Command `ProCmdEditDelSeg` 1;) d' @3 n" g5 {& r
mapkey d ~ Command `ProCmdSketCenterPoint` 1;+ ~; u# b( {7 x, f
mapkey q ~ Command `ProCmdDwgShowErase`;9 }! k* J( w; H- h# A$ D
mapkey y ~ Command `ProCmdSketConstrain` 1;% x3 X9 \' x/ g1 g
% u8 v' i8 J5 jmapkey w ~ Command `ProCmdSketCircular` 1;# p: h- g: r q- h+ D7 w
1 r$ |: {3 T5 e, {4 b+ _- K# Smapkey a ~ Command `ProCmdDwgCrStdNewRefDim`;
/ ], t3 M5 e8 N& w& A. A) vmapkey e ~ Command `ProCmdDwgCrSymInstCust` ;\
" l8 ?0 d( K" j8 {( ?2 c! rmapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;
2 G, K5 R5 U5 umapkey $F2 @MAPKEY_LABEL关 闭;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\5 F5 m! A2 D5 v5 D( |: m+ u/ V
" F5 v6 f$ q; ]: \. e1 Z# h7 Vmapkey(continued) ~ Activate `main_dlg_cur` `File.psh_close_win`;
1 ~# U' Z' J( A6 D: Fmapkey $F3 @MAPKEY_LABEL打 开;\* T9 m6 c$ b9 t# Q3 D
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelOpen.file`;: d6 U( j1 d7 a4 ]' Z
" z& }5 J, A' O. w" b) E( G+ ^3 bmapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelSave.file`;\
0 _0 Z3 r& a' l8 cmapkey(continued) ~ Activate `file_saveas` `OK`;0 d* ~0 W1 d6 y! ?# \6 Z7 F& Y
mapkey $F5 @MAPKEY_LABEL设 置;~ Select `main_dlg_cur` `MenuBar1`1 `View`;\* ?% k% N# \4 j" v9 _
! [% h7 i" @- E* c# ~/ d& omapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;~ Activate `main_dlg_cur` `Edit.pshSetup`;
6 E' r, g7 V) V5 {5 Q2 Kmapkey $F6 @MAPKEY_LABEL测质量;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
+ K$ n, K [+ ~6 E- q b. a+ Cmapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_geometry`;\& ]- n" U3 D+ b% E `
- ~& p1 ]* a' E( d4 a4 _- zmapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_model`;\4 ^; [% B' W" O7 ?; ~4 p6 |; I
mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_model`;\5 I9 S" Z: }4 e# ]2 c
) {6 f+ e" _+ `+ U. ?& a, o; g3 P# Amapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_measure`;\/ { C& e- N# g) ~
) ?. U* z3 T j& o% E1 }/ {mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\; a7 l( o5 P9 }. \. H' ?, g
7 ?. K! ]% R, n7 H( Omapkey(continued) ~ Activate `main_dlg_cur` `psh_na_model_mass_properties`;( l# D! d% B& G5 }4 u) ^# z
' @0 h' o0 Z% r2 O) ~mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_measure`;\) H* k8 {( V% E" f0 e/ s3 a8 G
! m, x0 L6 F! f' ]9 x1 ymapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_measure`;\
. f$ A# {+ R; d; Z- Q3 J) |/ Y% bmapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_diameter`;
, I" R1 p C8 c ], y3 tmapkey $F8 @MAPKEY_LABEL测距离;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\7 q. v8 M+ G* L/ Z" N
3 j5 H; I/ h. {mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\5 d5 \5 W6 r. B8 l2 R
, F: c# X% c- _mapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_distance`;( L$ c, G2 r/ B0 @3 P$ {( n+ N' O
mapkey $F9 @MAPKEY_LABEL设目录;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\3 V$ p( T: R3 |0 U# O
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\: c) [) M# t% Q" f
mapkey(continued) ~ Activate `main_dlg_cur` `File.psh_working_dir`;2 B7 Z4 V$ ?8 |9 b
mapkey $F10 @MAPKEY_LABEL拭 除;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\! p4 K' E/ G+ Q3 g
7 @' H5 s3 w: emapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\* Z0 c |0 W" B
, n. w! L" m& a9 j9 Xmapkey(continued) ~ Activate `main_dlg_cur` `psh_erase_not_disp`;\+ D4 K% R2 A' y6 D
9 J4 i5 w1 K, x, j: Jmapkey $F11 @MAPKEY_LABEL删 除;~ Enter `main_dlg_cur` `EMBED_BROWSER PRINT`;\% x, n$ O/ q4 g$ Z* @
4 K) Z5 o( E8 l0 c( j" _mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `File`;\
! I4 i0 D5 ]$ R/ S( ?) |. xmapkey(continued) ~ Select `main_dlg_cur` `File.cb_file_delete`;\% B7 @8 U* P6 R. C
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\/ o! k( D- N! n+ D
mapkey(continued) ~ Close `main_dlg_cur` `File.cb_file_delete`;\7 a5 w9 D; A/ W$ s: s+ R2 z$ `
3 R; P3 J3 D' J7 Ymapkey 1 @MAPKEY_LABELPurge;
: M; J3 [& P8 j% @/ emapkey $F1 @MAPKEY_LABEL新 建;~ Activate `main_dlg_cur` `ProCmdModelNew.file`;1 a' ]- r$ B% T9 z5 F/ b
4 ` V0 ^$ ^ N4 b% K: D2 umapkey(continued) ~ Command `ProCmdSketCenterline` 1;, b/ t) Z. m8 }( D
. a* ^" L, m2 {; omapkey m ~ Activate `main_dlg_cur` `chkbn.package_odui.0`1 ;\
) }4 m4 _+ o& G: l8 Mmapkey(continued) ~ Open `package_odui.0.0` `PH.motion_type_opt`;\
4 {0 L% X1 i; |0 `7 i3 S0 ^mapkey(continued) ~ Close `package_odui.0.0` `PH.motion_type_opt`;\
" r) Z3 {7 m Y* b8 }* Mmapkey(continued) ~ Select `package_odui.0.0` `PH.motion_type_opt`1 `Translate`;% N* s n1 V+ l& E* D
+ l( g8 ?9 Z0 h0 w" bpro_material_dir D:\pr\MONLibs\Materials
8 _& d; F t L2 {pro_library_dir D:\pr\MONLibs\- @+ g- X4 o% r: y& K4 r
pro_catalog_dir D:\pr\MONLibs\
, c6 O2 L9 W: l1 R" ~8 |PROTKDAT D:\pr\MONLibs\protk.dat7 ~) G8 n- Q. c# S
save_objects changedmapkey f ~ Command `ProCmdSketRectangle` 1;* R7 ^& ~: ?5 W# k, {" j. z
6 T6 [0 n$ U/ p. Y5 Z+ Fmapkey b ~ Command `ProCmdSketDimension` 1;
+ x! Z8 c; N3 \mapkey c ~ Command `ProCmdDatumSketCurve`;
1 g G: s% p4 vmapkey l ~ Command `ProCmdFtExtrude`;
0 D2 T) V2 s" {, c! P. N% `/ P& fmapkey s ~ Command `ProCmdEditDelSeg` 1;
9 i- W% \) C: m1 z# p# Omapkey d ~ Command `ProCmdSketCenterPoint` 1;7 Z0 {9 D2 _0 A$ Y
mapkey q ~ Command `ProCmdDwgShowErase`;5 j% q6 M1 g" k N
2 u, G. y [) Y: c. q# ?mapkey z ~ Command `ProCmdSketLine` 1;
2 c* L2 n% k- j Y" }mapkey w ~ Command `ProCmdSketCircular` 1;
9 ^7 |& X& a0 u- w* O- P. K' O' Gmapkey k ~ Command `ProCmdHole`;
9 c6 ~2 {, b3 g5 t1 xmapkey a ~ Command `ProCmdDwgCrStdNewRefDim`;
+ V( u6 K7 _! E" c, Z' p! {6 m6 dmapkey e ~ Command `ProCmdDwgCrSymInstCust` ;\
1 E4 |: J1 H1 Omapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`; w2 a% {% {" o: v, y. @
mapkey $F2 @MAPKEY_LABEL关 闭;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\1 i2 v- U+ ?# q; }6 u g* O$ m' L
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\' A1 g. { u$ Y! d8 p
mapkey(continued) ~ Activate `main_dlg_cur` `File.psh_close_win`;! R" z; y$ \* g
3 `/ N- e' Q, _+ W# [mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelOpen.file`; l1 N- c- J3 H/ o% r0 i& `- b
5 w2 X. _8 r6 z1 dmapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelSave.file`;\, t9 P" q* X! @4 i
2 [4 ?" K9 z! [6 j+ Y+ g' O8 Qmapkey $F5 @MAPKEY_LABEL设 置;~ Select `main_dlg_cur` `MenuBar1`1 `View`;\$ m2 H8 X# k) ^; c# Y. h4 p
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Edit`;\6 k9 z2 F$ c9 c) ?$ l
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;~ Activate `main_dlg_cur` `Edit.pshSetup`;, `; |) K: _6 x1 A( ]/ z! k
: ]% E4 _( p6 e+ _; r0 V) \0 rmapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_geometry`;\
# i m0 G ?! a9 Ymapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_geometry`;\
. b2 L& z- B! a3 Vmapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_model`;\+ k: B. {: o( ~! O. j
9 S) [# v: N% @& z- t& @; {mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_measure`;\ e7 f* h$ d2 m J' @( Z
mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_measure`;\# w$ H5 |4 j# t% b ?* v: y
mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_model`;\& I; G* g. J$ h8 m4 e0 t2 Y
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\, v/ ~: e ^& P
7 c* B0 [6 z/ `mapkey(continued) ~ Activate `main_dlg_cur` `psh_na_model_mass_properties`;( J4 @( Q6 V/ a
mapkey $F7 @MAPKEY_LABEL测直径;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\. Q2 M: \& r2 k0 q e
# Q- v6 t' ?) T/ Fmapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\+ I8 f* g x+ l# h0 r
mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_measure`;\4 Y+ N9 \# _/ M3 {: `$ F2 V5 v2 N
& e" b2 O* w( h* e* q3 emapkey $F8 @MAPKEY_LABEL测距离;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
4 ]9 v) t5 ^. Z, E8 @$ b0 L6 {mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_measure`;\) w5 p: v/ \( S) \7 c; i* j
2 q7 X1 ]) l2 a' ^, x. G# l, F9 ?$ \mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_measure`;\
. d/ A$ [5 E5 n- cmapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_distance`;5 R: I: a& X# j
mapkey $F9 @MAPKEY_LABEL设目录;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\ F9 M( }7 y7 H% C
4 k" ]$ m' a7 \" q, P1 s A; \( V# mmapkey(continued) ~ Activate `main_dlg_cur` `File.psh_working_dir`;. p8 i9 c+ \9 ]( | }
6 e0 Y# Z9 u, F) v) t# D! i. e) |mapkey(continued) ~ Select `main_dlg_cur` `File.cb_file_erase`;\9 l% t* n! ~# H1 o
, j B$ A" t6 j; y0 l, m* Ymapkey(continued) ~ Close `main_dlg_cur` `File.cb_file_erase`;\
W$ z* F$ K7 m4 hmapkey(continued) ~ Activate `main_dlg_cur` `psh_erase_not_disp`;\
) F! c% \4 p& cmapkey(continued) ~ Activate `file_erase_nd` `ok_pb`;
1 M' Q4 y/ A' r/ r6 M7 Wmapkey $F11 @MAPKEY_LABEL删 除;~ Enter `main_dlg_cur` `EMBED_BROWSER PRINT`;\/ g) M; X4 l$ D, X) ~5 ?- I
mapkey(continued) ~ Exit `main_dlg_cur` `EMBED_BROWSER PRINT`;\9 C# w' o& N; \! a! {$ g
: F5 R! e+ u* U" x9 n& bmapkey(continued) ~ Select `main_dlg_cur` `File.cb_file_delete`;\
, S* J8 e: X9 H u" b3 d8 `9 \# h" Pmapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\& K: t2 R& \ {8 b" N& k
& D# i, S; H. ?/ p. Y x) {& F9 Tmapkey(continued) ~ Activate `main_dlg_cur` `psh_purge`;;* W, d* \) W* R/ ]& t) Z( e$ P
% ^5 X9 `2 ^' @, o- O$ S3 v) O2 S* ^mapkey $F1 @MAPKEY_LABEL新 建;~ Activate `main_dlg_cur` `ProCmdModelNew.file`;! }3 y# R8 C( k* p1 {0 t* r8 ^
mapkey r ~ Activate `main_dlg_cur` `tbLines` `ProCmdSketCenterline.tbLine`;\# G* C2 s! H3 X7 S" E. L
6 }9 G' C+ X$ @" w. V. {mapkey v ~ Command `ProCmdSketReferences`;1 g# R" K6 S% n! U9 }
mapkey m ~ Activate `main_dlg_cur` `chkbn.package_odui.0`1 ;\! x$ z. Z/ g; C8 w) e6 J
mapkey(continued) ~ Open `package_odui.0.0` `PH.motion_type_opt`;\! e0 ^. u& L3 e) F
mapkey(continued) ~ Close `package_odui.0.0` `PH.motion_type_opt`;\- M+ @$ M3 X. b) f' z% a
' F% w q. w& u: M4 v1 R# Fmapkey f ~ Command `ProCmdSketRectangle` 1;9 Y: D: h8 @3 \. o; c% z3 ~
mapkey x ~ Command `ProCmdFtRevolve`;0 T# x# |5 D$ g4 O; i
, A- o3 o: [0 d7 N" v/ {) vmapkey c ~ Command `ProCmdDatumSketCurve`;
) i( Q/ p- A5 i, L1 ~mapkey l ~ Command `ProCmdFtExtrude`;
: x4 R5 K9 `1 h6 G1 X! |mapkey s ~ Command `ProCmdEditDelSeg` 1;8 c7 f2 b1 s y" r8 ]
mapkey d ~ Command `ProCmdSketCenterPoint` 1;0 v! p4 ^( o! x* @3 F/ Q. q
mapkey q ~ Command `ProCmdDwgShowErase`;# y8 k& D7 r, @8 C5 l
mapkey y ~ Command `ProCmdSketConstrain` 1;! x3 g# w7 S8 M4 [ x
mapkey z ~ Command `ProCmdSketLine` 1;. k9 H! j) P1 M8 ~6 }
mapkey w ~ Command `ProCmdSketCircular` 1;! f8 {. Q5 T# h3 Y+ u$ R
mapkey k ~ Command `ProCmdHole`; S0 g. b: T+ \: ^3 D, r
# N: B! `3 y) wmapkey e ~ Command `ProCmdDwgCrSymInstCust` ;\
9 O* q. f; m, A0 x) b9 O4 D" fmapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;: z/ t2 y3 @" [
mapkey $F2 @MAPKEY_LABEL关 闭;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\+ ^* k5 d' Q1 e+ Z" s5 R7 X
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\# l; ^8 W1 r/ j
mapkey(continued) ~ Activate `main_dlg_cur` `File.psh_close_win`;9 A! s p' X8 X+ |
& F0 `( @ F- @. J( w4 `mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelOpen.file`;3 S, Z, B) R! r
mapkey $F4 @MAPKEY_LABEL保 存;\7 d- D( {4 Z7 X9 p- i! Z9 a1 J8 \
1 n1 }/ e# ~! y$ ^mapkey(continued) ~ Activate `file_saveas` `OK`;8 T2 C# X. F3 M9 }; `$ x
mapkey $F5 @MAPKEY_LABEL设 置;~ Select `main_dlg_cur` `MenuBar1`1 `View`;\) t( A _6 {& r/ u5 M3 C
$ ]/ c8 l( h6 ~3 u' Dmapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;~ Activate `main_dlg_cur` `Edit.pshSetup`;- n6 C4 y. {) i
2 O) b& k/ Q) |' P2 B* K; o" ~mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_geometry`;\
3 L* y C' L. Y0 ]( I0 i5 k# Umapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_geometry`;\# n+ m, P3 d4 f" N! `
mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_model`;\4 h3 L$ q7 J0 M
% n' O D5 ]& B, ~/ Fmapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_measure`;\' E5 q/ }4 E7 V7 z
mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_measure`;\3 d! a' a) O4 S8 ]: f, W# l
mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_model`;\0 D7 ~0 H% X* ]+ K# c, t
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\ _" f7 _; V. ^ w
mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_model`;\4 K8 B/ n* ^; S" o Z( _
9 B6 z7 Z" q5 Xmapkey $F7 @MAPKEY_LABEL测直径;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\# I3 Z# O. `5 Z: z
mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_measure`;\$ o" a$ [" E& e. }. f
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\, z5 X+ I5 G# j
mapkey(continued) ~ Close `main_dlg_cur` `Analysis.cas_na_measure`;\/ l; i1 G1 y' P/ n. {" ]- K* Y
; N k- M+ s2 E/ ~mapkey $F8 @MAPKEY_LABEL测距离;~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
8 x5 z2 G P* G' `mapkey(continued) ~ Select `main_dlg_cur` `Analysis.cas_na_measure`;\' C! ^- L0 O- y' e% w- a
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\" X/ Z( d& @, `: Q+ _
j7 \7 `( ] J8 ?" f$ Cmapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_distance`;$ H& W: G1 X; H
: S) w/ @2 R" j+ pmapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
- g+ \( t; ?1 E" v S7 C4 }2 ~mapkey(continued) ~ Activate `main_dlg_cur` `File.psh_working_dir`;2 D" {2 N, O- E2 ?( Q
mapkey $F10 @MAPKEY_LABEL拭 除;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\, _' `5 a2 d9 R) V
6 r" Q) t" s1 ]" K$ O/ u0 P: ^4 Smapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\( {' H1 e( N, S5 ~/ c/ A
2 ~2 v' Z5 _% t4 c$ A: k; c4 `1 jmapkey(continued) ~ Activate `main_dlg_cur` `psh_erase_not_disp`;\
' W" E& D5 p4 y- ~! n2 ]mapkey(continued) ~ Activate `file_erase_nd` `ok_pb`;
' H1 h; O- q" ?3 u5 P, zmapkey $F11 @MAPKEY_LABEL删 除;~ Enter `main_dlg_cur` `EMBED_BROWSER PRINT`;\/ s/ M. x* A* S( w
mapkey(continued) ~ Exit `main_dlg_cur` `EMBED_BROWSER PRINT`;\, [/ p$ y# j* l/ b) B( s5 K2 b! u
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `File`;\2 w! c6 d* A7 N. T
mapkey(continued) ~ Select `main_dlg_cur` `File.cb_file_delete`;\! z1 w7 P: M! ^/ b! Q4 D: d
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\- z. g" r& P4 E
( E6 S6 K: a, d! cmapkey(continued) ~ Activate `main_dlg_cur` `psh_purge`;;
) n; K- R [5 I$ C4 o( wmapkey 1 @MAPKEY_LABELPurge;
8 I( U( n7 ?8 _# N0 K2 @ A/ imapkey $F1 @MAPKEY_LABEL新 建;~ Activate `main_dlg_cur` `ProCmdModelNew.file`;
- | h( ]3 r! a4 \( c# c5 l4 t; tmapkey r ~ Activate `main_dlg_cur` `tbLines` `ProCmdSketCenterline.tbLine`;\
- O: v9 U, x) h# K9 v) [mapkey(continued) ~ Command `ProCmdSketCenterline` 1;
% t* o+ h8 c$ M; _mapkey v ~ Command `ProCmdSketReferences`;
6 e$ ?0 Z( g, j; P+ G4 jmapkey m ~ Activate `main_dlg_cur` `chkbn.package_odui.0`1 ;\
5 q+ @+ e' [6 x1 t0 `# o. m8 c/ Smapkey(continued) ~ Open `package_odui.0.0` `PH.motion_type_opt`;\8 p3 R+ D' e4 j
9 o4 n [+ x: d5 o0 ?mapkey(continued) ~ Select `package_odui.0.0` `PH.motion_type_opt`1 `Translate`;& e& R* }8 R. Z8 Z3 G3 Q* v
mapkey f ~ Command `ProCmdSketRectangle` 1; |
