我是一名autolisp初学者,刚编了一段程序是关于常用渗沟球轴承的参数化几何建模的,但是运行不出来,怎么也找不出错误。请各位前辈指点一下。。。
9 i7 X2 {+ j9 |4 r(defun c:zhoucheng()
6 Z n- M& s, S% ]8 }/ ~8 i(setq p0(getpint "请输入基准点:"))
* A$ {% S; W0 F0 a4 w& l(setq d(getreal "内径d=:"))" G& e1 U' C8 Q( @- ~4 _2 k
(setq D(getreal "外径D=:"))$ q' m3 T/ x c7 o0 b, @
(setq B(getreal "轴承宽B=:"))
0 ?% W) \2 }7 V5 z" E9 t(setq r(getreal "滚子半径r=:")) j2 q" P) L$ t7 P$ ?
(if(<r(*(-D d)0.5)) (princ"ok")
5 T2 L2 u* L" X' D(setq p1(polar p0 (*0.5 pi)(*0.5 B)))
! g9 n K6 J4 F8 L5 {(setq p8(polar p0 (*-0.5 pi)(*0.5 B)))
/ b6 j6 |( K& m$ L! V' r! B(setq p2(polar p1 0(/(-D d)3)))( X' O3 K; ^$ I
(setq p3(polar p2 0(/(-D d)3)))
3 ]! t5 Q( j8 ^; o, v, V(setq p4(polar p1 0(-D d)))
0 P6 p2 |3 D! n/ b; Y% R7 b. j2 q+ }(setq p7(polar p8 0(/(-D d)3)))
X' x8 y! ]1 X% Y0 l& K- A(setq p6(polar p7 0(/(-D d)3))). Q* ~. O3 q2 @/ \) _! X- E
(setq p5(polar p8 0(-D d)))- \8 @6 w7 w/ n. F7 R- T
(setq p12(polar p4 0 d))9 X, f+ v' y p/ Z! O* a& T$ s
(setq p11(polar p1 0 D))3 Y9 Y- A! j; b% ~
(setq p9(polar p5 0 d))) i: S& @2 [2 A: W3 L
(setq p10(polar p8 0 D))
! N5 T: `2 u+ m4 T5 J: d(setq pt(polar p0 0(*0.5(-D d))))) K+ m* D1 u/ l3 y" J
(setq p14(polar p0 pi(*0.5 B)))
0 |' S7 `" N+ ]. }5 O& R(setq p15(polar p0 0(+D(*0.5 B))))
. s% Y8 @* V$ V3 r(command "layer" "s" "draw" "")# L8 ^3 u6 Y0 B3 O! N1 b
(command "line" p1 p11 p10 p8 p1 "")5 y% I8 v) P6 k; k( f, h4 L* C; G
(command "line" p2 p7 "")- y; l/ ?( [6 a0 w
(command "line" p3 p6 "")
/ i2 f6 n* F. H% f(command "line" p4 p5 "")* ~/ Q3 m( W3 C
(command "line" p9 p12 "")
, C2 z1 v' T9 }5 g2 X(command "line" p12 p10 "")
- U/ s+ A1 L. P) [$ @ _(command "line" p9 p11 "")# j' t! W/ P- N9 U2 y [
(command "circle" pt r)
. B" i' E6 m' q0 V+ W u(command "trim" "all" "list(0 (/(-D d)3))")' R+ j0 B$ D, z, @
(command "trim" "all" "list(0 (*(/(-D d)3)2))")5 X7 q/ t. b2 ]
(command "bhatch" "p" "ansi31" 1 0,0 list(0 (/(-D d)5)) "")
P! _( _2 S" Y5 C% C" t g! \. h(command "bhatch" "p" "ansi31" 1 0,0 list(0 (*(/(-D d)5)4)) "")1 B3 g% i' I2 U9 W4 ^7 P& k
(command "layer" "s" "center" "")
5 x2 B3 a6 H3 V3 A) ]! V8 x(command "line" p14 p15 "")7 x9 a" J& R' y
: W2 W8 U5 u o8 d7 _4 d
9 ^8 a$ N! r% E ~) d
