刚开始学SolidWorks.版本为2006SP4.1的.在跟它的帮助教学课程学习到(指导教程 输入 AutoCAD 文件展示如何输入 AutoCAD 工程图并进行修改)这一课程时候发现这一小段课程是E文的.无法继续学习操作.求哪位能帮助指导一下.我现在连这一步都进行不下去了.不知道如何去做.谢谢. ! h2 J( c# H2 J; m
! K) P/ u" n* c+ s' C7 F' b
1 \: g" q4 `6 `/ m5 v3 y
- In the dialog box:
+ V( d8 v8 m1 g% d7 g
( p" v/ _, i6 e) p( e" Q2 B' @
Make sure that Create new SolidWorks drawing and Convert to SolidWorks entities are selected. 0 R' u+ B m7 q! ^" F' r; z/ ^ E
3 h/ r* C$ T; j2 C& j3 T8 R
Click Next.
4 U0 i E; }4 m" d -
1 Q! j* ~& y/ ~+ K1 k+ n( M' i
Click Next to accept the defaults on the Drawing Layer Mapping screen.
, E4 c6 [( h* t8 ~' i) P& t: { - # r% i. b; Y+ k, \
Under Geometry positioning, select Center in sheet to center the imported drawing on the drawing sheet. & }; D. b5 R/ F- K
# S1 U I2 e/ @1 M- u6 M# N
Click Finish. |
