查看: 2136|回复: 1
招聘设备主管
发表于 2012-8-30 11:48:54 | 显示全部楼层 |阅读模式
Job Summary工作概要
Edit the equipment management standard and operating process, also edit the equipment maintenance plan and put them into use. Solve the problem and improve the equipment running situation to enhance the reliability of the machine.
制定设备管理标准和操作规程,制定设备保养计划并实施;解决设备疑难故障,改善设备状况,提高设备的可靠性和稳定性。
Job Responsibilities岗位职责
1. Develop the certain area equipment management to assure the management system carrying out perfectly. 开展指定区域/领域设备管理工作,确保设备管理体系运转良好。
2. Organize and edit the equipment management standard and process. Also responsible for the equipment operating edition. Do the equipment maintenance plan and assure the implementation of the plan. 组织制定设备管理标准和程序,牵头制定设备操作规程,制定设备保养计划并确保按计划实施。
3. According to the machine running situation record, make the related improving plan in order to enhance the stability and reliability, also lower the shut down time. 根据设备运行状态统计表,制定相应的改进计划,改善设备状况,提高设备的可靠性和稳定,减少故障停机时间。
4. Do the management of the special equipment according to the government regulation, to accomplish the first/second inspection. Also do the daily inspection. 管理各类特种设备按政府规定完成初检、复检,并进行日常监督检查。
5. Assure the new equipment, especially the special equipment to meet the regulation and standard of the safety, occupational health and fire fighting. 确保新进设备特别是特种设备要符合安全技术、职业卫生、消防等相关规定和技术标准。
6. Choose the proper supplier to assure the best service and products. 选择合适的供应商以确保提供优良的服务或产品。
7. Complete other tasks assigned by superior. 主管交待的其他任务 RECRUITING JD 招聘工作说明书 Metso Paper Technology (Shanghai) Co., Ltd
Requirements岗位要求
1.Vocational degree or above, mechanical or maintenance or other related major, 10+ years related working experience, 3+ year management working experience. 中专或以上学历,机械类或者维修类相关专业毕业,相关工作经验10年以上,其中管理经验3年以上
2. Sufficient experience of mechanical and electrical experience, capable to solve the machine tool problems. 具有丰富的机械/电气知识,能分析解决机床设备的故障。(落地镗铣床、龙门刨铣床、车床、钻床等设备)
3. Good command of the machine tool's driving construction and electrical control. 熟练掌握机床机械传动结构/电气控制。
4. Having the knowledge and experience of the equipment general management. Also capable of editing the equipment management standard and management process. 具有设备综合管理知识和经验。能够制定机床设备管理标准和管理程序
5. Good communicating with other dept and choosing the right supplier with good relationship. 有效进行跨部门交流,能够正确选择供应商并保持良好合作关系
6.Control and enhance the team working efficiency and quality. 能控制和提升团队工作效率和工作质量
7.Have awareness of ISO14001 & OHSAS18001 具有ISO14001 & OHSAS18001意识
发表于 2012-9-9 09:24:07 | 显示全部楼层
您的联系都没有 别人就是想去 也找不到您啊
GMT+8, 2025-4-12 20:54 , Processed in 0.055553 second(s), 19 queries , Gzip On.
