查看: 4556|回复: 5
工业内窥镜是用什么方式遥控弯曲的?
发表于 2012-8-10 11:28:22 | 显示全部楼层 |阅读模式
% A) p$ P) I9 P在液压分厂见过一次检测油缸内部的,对前段遥控部分很好奇?不知有高人知道不?0 X* F9 [  q9 Z
发表于 2012-8-10 13:36:11 | 显示全部楼层
会不会是里面有一根筋的东西?
我猜猜跟你差不多类似吊线木偶一样的!但是五六米总不能扯那么长的牵引线吧而且不止一条  发表于 2012-8-10 17:22
发表于 2012-8-10 14:16:13 | 显示全部楼层
真是高科技,哪里产的,什么原理。
发表于 2012-8-13 10:47:27 | 显示全部楼层
五毫米直径内放这些,却是够小的  发表于 2012-8-13 11:26
发表于 2012-8-13 11:38:24 | 显示全部楼层
本帖最后由 动静之机 于 2012-8-13 11:58 编辑 3 }: W. a9 F) p; L5 C. p, v
( B! B' h; }% ~, NThe articulating tip, called a "bending section", consists of a series of hinged, ) y, l0 d& u2 t# X8 c7 r
metal, hollow discs, each set 90 degrees to its adjacent disc. This component 2 S& Q' m  g% `' r, a6 \
is made by hand under a microscope. ( M; |- g% L  h, |  w# U
该关节式梢头,俗称“可弯曲的部分”,由一系列空心盘状金属部件互成90度铰
4 e( w6 {9 Q) m. w; O9 Z. v9 z接而成。该部件在显微镜下由手工组装。
4 {( `2 K* h& j- \* W
( v; \$ b3 |" J  S/ c9 a; mThe bending section is manipulated by 4 guide wires, each of which is housed
  d( W+ n' H0 c+ N. b/ I4 Swithin its own sheath. The sheath is called a  "coil pipe", and a set of 4 sheaths
7 B7 U: T. X! M: G: ]with 4 guide wires, fully assembled, is called a "coil pipe assembly".
( v  G  a9 {  I" z& R) c弯曲的部分靠4根线操控,每根线外都有鞘。鞘为卷管,4鞘连同4根线一起组成4 u" R7 e2 X+ Q  b. A
一套“卷管组件”(即“微型”自行车闸线)。
! q! m: K( J& d/ D; l. n% L/ q/ T- q
The four control wires are connected to the joystick mechanism at four different
1 n( ^8 g" P- Y* v1 }9 V7 jpoints. When the joystick is moved in a certain  direction, the appropriate control
, G; Z* r" r1 h3 A! kwire is pulled (and tension on its opposite wire is relieved) and the bending section
+ h6 t1 h8 G9 n  r. U4 e* |8 ]5 qbends.
2 C/ L0 @. h: b: S四根控制线连接到遥控手柄机构的四个端子。当遥控手柄朝某方向移动时,牵拉相应
: b6 U; J4 g+ E1 r, o5 `  w, m的控制线(对边的线则放松)产生相应的弯曲动作。. L2 i: j- `2 S5 M  i- q# T
% n1 {( w6 m: y1 {, U. i0 }0 v0 R
% v- E1 \+ W, H) R9 x) y
发表于 2012-8-14 21:00:26 | 显示全部楼层
机械真是太神奇了
GMT+8, 2025-10-20 00:00 , Processed in 0.097622 second(s), 22 queries , Gzip On.
