+ T9 R0 _8 v: G2 i4 E
FURIA 自制式直升机" d1 B9 F0 d3 b. _. B8 }
( R& g: P& F) z. {2 ?) K, ~1 J9 `# e
$ A* k: |' O3 `& ^" f8 \
FURIA ULTRALIGHT HELICOPTER Plans ; X6 j7 F' B- W/ c! b1 d8 G
FuriaHelicopter Specifications 7 N2 \: W! k6 [( Y* u3 ^8 B# Y
Main Rotor Diameter :
; L. D' p& ^. J( b# V9 r! j# j Main Rotor Blade Chord % L% [1 P% X+ u9 b2 {3 r- V
Main Rotor Speeds:
$ m r6 T2 k6 T. _8 H3 h
$ \+ U3 r( {$ h1 h2 U Tail Rotor Diameter : . y. I2 _9 D$ f0 g
Tail Rotor Chord : $ D3 p5 m4 o1 j6 z9 D7 T. b
Tail Rotor Speeds: * n+ U0 \/ Y' |8 W7 I
# M2 ~. S, p9 M5 N% f8 G) s Length : % i) X. w+ K1 a8 M& ?6 Q6 w* d7 p
Height :
7 p, X1 [& `6 a. `5 H( \ Width :
4 H! Y9 F) `( I5 @7 h, e Empty Weight :
0 H9 K0 s' L8 @; O/ s, H Gross Weight :
( n( }) ^9 z# x& _$ N/ S# u Payload ( w / full fuel ) :
, D; h" O; a" {1 T
: z% _: Y" C* V Rotax 582UL DCDI Engine : * O" S+ p" N, ^' [) x* {
Engine Weight : ' J! a# W( A% h6 Y0 \* h7 B
GearBox out :
, C; ~" o; H" _: M( W/ t1 \' y Fuel Capacity : 2 v& a/ n9 ~( K k" J/ l# S+ N: X
& C0 V3 a5 Q" Q6 ^' m/ M3 G
Performance :
3 x, F9 }- O0 p1 H& r Range : 4 U4 W8 m# O0 {# ?4 `% K+ K; `
Vmax :
2 O. J, L( S$ _" ^7 P. J Cruise speed :
, H% t+ L' e4 l* H2 U, a/ R Climb rate (msl) : 7 v9 J6 h9 e+ u1 y; Q
Service Ceiling : 2 ^6 m& j6 P, Y4 f2 ~. k. n3 D% q
Hover in ground effect:
, Z5 Q) W b5 n" H1 ` Hover out of ground effect: 7 y2 [7 {4 T2 F- w2 G* a& o3 l
Max. Endurance + c9 F, `4 [. Z
& E) C' L% k% U3 ?6 k+ c2 K. ]
Design Load Factor :
7 b* B9 S, V; J+ N; I" s7 l0 t9 @ 3 G9 H/ R5 Z- c1 Z
Seats : & @/ n/ u: Y: L }
Price: 18’500.00$ 9 L S0 z1 ~5 E* } F
2 S+ q. L3 r1 l6 P, I7 d Complete set of plans with incredible clarity! (as required by FAA Part 103, Ultralight Regulations) 5 `6 @; X/ U7 H9 }. p1 w; L6 E
The FAA has ruled that the maximum speed of 63 mph normally applied to fixed wing ultralights does not apply to helicopters due to their unique power curve.
9 E* i. i8 x% O0 G4 f" O
) v( e* Q$ c" Z) \* x8 A* y1 c- l: ]6 B# y
