Responsibility: · Design mechanical products of Flow Meter system and sub-parts · Follow Marketing specification and define engineering ME spec. · Generate Design Concept and pass design reviews; Conduct engineering calculation and flow/stress simulation independently; · Make drawings, solid expertise in drafting skills and GD&T · Design Documentation generation and sustaining · Work with global and local engineering teams · Co-work with cross functional teams(Marketing, Sales, Sourcing and Quality, etc) · Test prototype to verify design, handle venders and do inspection Requirements: · At least 5 years work experience in Mechanical design Domain; · Good English skill, both written and oral; Handle global T-con skills · Strong communication skills · Experience of Die casting, CNC machining, Plastic injecting modeling, sheet metal is required · Capability of Solidworks( or similar); ANSYS workbench is required; CFX/Fluent is preferred; · Experience of explosion proof design experience in hazardous environment is preferred; · Good knowledge of GB, ISO standard is required; ASME and IEC system + · Bachelor; Master +
- y- j3 }: W$ J( ?8 v有兴趣的可以回帖或发站内短信PM |
