查看: 2951|回复: 2
“容腔”如何翻译?---[请教]
发表于 2006-12-25 14:40:10 | 显示全部楼层 |阅读模式
大家好啊,有谁知道容腔这个单词怎么翻译啊? 查了好多资料都没有查到?,原文如下:
3 H' |+ |6 a. f- O# X
每个撬装式循环罐根据工作性能需要又分隔成不同的容腔,并配备有不同的净化设备、辅助设备。
0 S* ]$ T% T% z; Q) v F% v
) u* }' u7 Y. H
谢谢啊!!!
发表于 2006-12-25 16:39:23 | 显示全部楼层
Re: “容腔”如何翻译?---[请教]
如果楼主实在找不到这个专有名词怎样译,可以采取一种笨办法:将其翻译为普通名词,然后加上一个定于从句解释其功用。例:9 x% q8 c- d' O; X7 l1 \6 C
Every "撬装式循环罐" can be devided into different cavities per their function, which ... , and is equipped with  different type of purifying as well as accessorial devices.
& q( L5 o& K5 [! P# k/ s* W
' y, B3 m: x/ Kor,7 N) Z- F4 G$ Q9 T' Q
' K' I! r0 v' `9 M9 w# V7 DEvery "撬装式循环罐" can be devided into different rooms per the function, and is equipped with  different type of purifying as well as accessorial devices. The cavities can be used to ( accomodate sth. or ... ).9 y- R* d2 Q* d! Q. [3 B  N& a6 z3 _
发表于 2006-12-26 16:07:56 | 显示全部楼层
stage
GMT+8, 2025-2-21 21:27 , Processed in 0.061880 second(s), 15 queries , Gzip On.
