楼主 |
发表于 2012-5-12 10:37:08
显示全部楼层
再来一个:
/ e2 i, J3 ^5 [+ b: z5 Y+ f# L9 m2 J n5 A2 {+ {
Opening for Mechanical Engineer responsible for the design and packaging of rugged laptop, tablet and handheld computer systems.
4 E% `7 O0 m" i9 r4 s5 U# l Candidate will participate as an active member of project design teams. Design activities include the creation of detailed engineering drawings, assembly drawings and bills of material.7 [: Y2 b6 `2 r1 q w2 c1 X" c
Candidate will also support the development of concept designs and analysis for proposal efforts.The candidate will need to support manufacturing in the resolution of manufacturing issues. q+ k# m9 h9 K6 a4 S- W6 P; C
The candidate should have a strong background in 3D computer modeling, manufacturing techniques, and environmental testing. Requires good analytical capability and current technical knowledge.
% k% |( z4 c: x0 k, W3 mThe candidate is required to hold a BS Degree in mechanical engineering with 10 or more years of demonstrated results, or equivalent experience. The candidate must be experienced with Pro/Engineer.
6 m" N; {/ x3 U K4 BCandidate will have regular contact with senior levels of internal work groups within a project and across a single engineering dept. Travel to customers/suppliers may be required. Candidate must be able to participate well in team projects and interact well with others to produce positive group results.
m1 P. C, _6 w/ r* d, V
2 h- L6 T: _3 gEducation and Experience
6 i$ ] Z# v P1 f! r# A3 F$ }Bachelor’s degree in mechanical engineering, a related technical field or the equivalent experience is required. Advanced degree preferred. In addition, a minimum of 12 years of relevant experience is required, 15 years of relevant experience preferred.
, Q: d; L0 ?$ ^( ~4 p
$ c! s& \2 U5 x# d- i6 ]! DApplicant must be a US Citizen.& W: V/ E5 G7 A4 j5 ~7 G+ N
! Y, Z m5 C" C( C' B$ t N- [
The position requires working with:
* f1 ?$ t; F5 N' t• Project Management on scheduling, task breakdown, and project reporting,; O, P+ @0 S4 C) y# M) @$ ? w# O
• Design Engineering on all issues of project design and analysis,* ?' {; w$ X: u) G! v" f
• Purchasing on vendor surveys and parts procurement, and
6 e" S$ g( U" |2 J0 t7 ^$ T: T• Production on all aspects of product production lifecycle$ x" l+ s* h+ R0 b6 S; k
) H2 `* e9 }. a& ~
$ ?5 z! I7 U1 w7 E" _7 k1 E* B, _& r' [( V
