查看: 2615|回复: 8
在安装proe时出现的情况,求解
发表于 2012-5-10 09:57:22 | 显示全部楼层 |阅读模式
在安装proe时出现的情况,求解
( n8 B" W3 ]3 j$ R( M9 H
发表于 2012-5-10 10:13:00 | 显示全部楼层
这个好像是  证书  出问题
4 m* S7 j# i7 a! B0 }; T/ ?- Y重新 打开 那个用TXT打开的文件  + Z, H4 t( G7 @2 I# I
输入电脑 名字
7 Q# b" K; h; l% U6 k保存
发表于 2012-5-10 10:31:53 | 显示全部楼层
明显证书问题,你上网搜安装教程啊,一步一步很简单的,论坛上也有啊
发表于 2012-5-10 22:55:00 | 显示全部楼层
证书里边的那一串数字改成你的ID之后,再锁定一遍就好
发表于 2012-6-9 18:45:41 | 显示全部楼层
把证书上的那个ID改成你电脑的ID就可以了,我是昨天刚安装好的,在网上看的视频,按步骤一步一步来挺简单的
发表于 2012-6-12 15:05:22 | 显示全部楼层
许可证制作是否正确?   正确的话就是补丁程序没打好     按安装信息里把补丁程序重新打好   就ok了   我的就是这问题 按文件里的这个 步骤
' q) h+ z$ o5 ^2 u* d9 i1) Start pro/e setup
* K/ _+ H) j: |! e# S8 J
/ p+ B, Y, f8 u+ g% K2) Open license.dat with any  txt-editor and replace every occurance of 00-00-00-00-00-00 with your computer real HOST_D (same one shown in the bottom left corner of the Pro/e setup). Save the ptc_licfile.dat
( d9 w2 w' C7 S" C2 s0 ~# t' g: t1 j$ t# r  F/ r2 \6 ~1 m
3) Install proe - proe_mech -ptc_distributed_services (optional). On license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
) R; N$ m$ u. p$ U: K8 f4 H
) a( t% D9 p# K: k5 s% nNext  apply a patches (if u didn't install the complete package, you will get "File not found" errors, accept or bleed)' \0 g2 c* P0 @/ S# C& s
, ~6 n0 t0 b5 P1 W
for pro/engineer:6 Q$ J& k/ h# \- d, {
Copy "proe_WF5_Win64_crk.exe" to folder <proeWildfire 5.0 progdir>\i486_nt\obj and click "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK"* T- P* h" C9 H$ A
. s) k- y% M, Z4 a4 ^9 c* _
for pro/mechanica
3 ^' V; S0 p$ m, X" v7 wCopy "proe_mech_WF5_Win64_#1_crk.exe" to folder <proeWildfire 5.0 progdir>\mech\i486_nt\obj and click "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK"  l, r* _; B2 S3 x" k
Copy "proe_mech_WF5_Win64_#2_crk.exe" to folder <proe mech WF5 progdir>\mech\i486_nt\ptc and click "Start > OK"0 ^) q. B0 T  e
* q" S9 x' J4 U# a, u
for ptc distributed services+ n7 a/ \. n2 e) A" `$ `& C
Copy "ptc_distributed_services_WF5_Win64_crk.exe" to folder <ptc_distributed_services WF5 Win64 progdir>\i486_nt\obj and click "Next > OK > Finish > OK"
1 N4 O& W% X' Z$ a" N
( A, P, N6 i* e; nThat's all.. Enjoy
3 V# D+ v' t& z: t, d1 I" Y4 x0 u8 EOK    刚刚解决掉
发表于 2012-6-26 14:03:18 | 显示全部楼层
这个软件的安装和其他的不同  百度一下安装方法 按着方法来很简单的
发表于 2012-7-15 14:20:10 | 显示全部楼层
哪有PROE安装教程啊?
发表于 2012-9-28 21:51:00 | 显示全部楼层
许可证制作是否正确?
GMT+8, 2025-2-24 21:37 , Processed in 0.061285 second(s), 21 queries , Gzip On.
