查看: 3288|回复: 9
CAD安装过程提示出错
发表于 2012-5-2 20:55:31 | 显示全部楼层 |阅读模式
CAD安装过程提示出错   如下  向高手求教如何解决
  [) F1 z9 v6 O
2 W6 m3 m; C9 e$ H1 M[5/2/2012 20:39:43] === Installation started on XL-986618363503 by Administrator ===
" F5 |% `: j  J1 H: ~4 u[5/2/2012 20:39:44] [Info] Windows Installer upgrade is not required$ `! j: l6 q& l( w1 A' @1 a, E& o8 g. \
[5/2/2012 20:39:44]   System Version = 4.5.6001.22159
8 n" D1 ~/ _. z4 D; v[5/2/2012 20:39:44] Installation skipped: MSI Runtime 3.06 |5 L, R# ]" p% Z* l, H( t
[5/2/2012 20:39:44] [Info] .NET Framework Runtime upgrade is not required7 M3 \" l& B; q6 H! d* h' `+ I
[5/2/2012 20:39:44]   System Version = 2.0.50727.14330 u6 c& n/ X6 f: g. V1 V6 j
[5/2/2012 20:39:44] Installation skipped: .NET Framework Runtime 1.1
$ m4 a7 b; G& U: f3 F2 {2 t2 C[5/2/2012 20:39:44] Installation started: .NET Framework Runtime 1.1 Language Pack
; V; ?1 l( k# Z5 ?, R, m2 h[5/2/2012 20:39:44]   Command = "F:\AutoCAD 2006 chs (G)\Bin\AcadFEUI\support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
, P. |! L! f& B" M; i[5/2/2012 20:39:44] [Error: 1603] 安装时发生严重错误
; X1 I" F" ^! y. Z: R[5/2/2012 20:39:44] Installation failed: .NET Framework Runtime 1.1 Language Pack. Z* H: Z$ V4 }5 X0 Y( e  @
[5/2/2012 20:39:44] Installation aborted4 G  |  s; G' J0 i
[5/2/2012 20:40:04] === Installation ended ===
4 x; P5 m: `0 n( c
+ F: x, d  j& Z  p1 M7 ]+ W
) W) t* |  c4 R% m3 H0 q
发表于 2012-5-2 20:59:06 | 显示全部楼层
具体一条一条解释,恐怕没几人能说出来........{:soso_e144:}
发表于 2012-5-2 21:07:49 | 显示全部楼层
Installation failed: .NET Framework Runtime 1.1 Language Pack去微软官网找建议NET2.0 或者3.5 框架 并且卸载NET1.1,下个QQ电脑管家有下载或者到这个网站http://www.microsoft.com/downloads/zh-cn/resultsForCategory.aspx?nr=50&sortOrder=Ascending&sortCriteria=Popularity&stype=ss_pd&sterm=%E6%89%80%E6%9C%89%E7%B1%BB%E5%88%AB也有下载
 楼主| 发表于 2012-5-2 21:19:45 | 显示全部楼层
sniper2006 发表于 2012-5-2 21:07 9 j* d' `) C; Z& [
Installation failed: .NET Framework Runtime 1.1 Language Pack去微软官网找建议NET2.0 或者3.5 框架 并且 ...
% @' U/ H$ S6 V
我下的就是3.5的啊  大虾   新下的  还是提示出错
 楼主| 发表于 2012-5-2 21:20:49 | 显示全部楼层
林の屋 发表于 2012-5-2 20:59 % M; r9 _5 [# T( s8 [
6 x  t/ ^3 S3 L9 _那这位高手能指点一二吗 7 {, _( I2 ^! }4 G4 R
发表于 2012-5-2 21:37:26 | 显示全部楼层
先看你的CAD版本什么地方来的? 电脑城里的有80%装不上.   也有可能你系统上有点问题,你可以把系统重新装一遍再来安装; 再看你CAD版本要求使用什么系统 ?   这些地方先要弄清楚.
发表于 2012-5-2 21:58:41 | 显示全部楼层
这个是操作系统的问题吧,很多盗版的系统在更新时NET Framework都会出错,试试别的版本的系统吧
发表于 2012-5-2 22:31:47 | 显示全部楼层
到微软官网下Microsoft .NET Framework 4(独立安装程序)试试,我的是32位的Windows 7旗舰版,电脑里就装了这个也安装成功
发表于 2012-5-3 09:41:16 | 显示全部楼层
你试试以下方法:
( ^# B4 t  V+ k7 }$ _% v# Q1.不要直接双击setup.exe, X2 u+ q* q0 q' u3 m) G
2.找一下安装程序下Bin\acadFeui\acad.msi 并双击安装
发表于 2012-5-3 09:43:54 | 显示全部楼层
如果没有上述文件夹的话,就找一下acad.msi 。
0 N) @% b. n6 `0 j# e" U% \5 c如果还不行的话再看看其他社友的方法吧。
GMT+8, 2025-4-30 15:34 , Processed in 0.082286 second(s), 14 queries , Gzip On.
