![](static/image/common/ico_lz.png)
楼主 |
发表于 2012-4-27 21:24:59
显示全部楼层
%5 m1 {- \1 x |5 Q! Y
2 W) ? a# Y- N# |! x
O6200([A-00]GUN DRILL DRILLING CYCLE)
; l7 p9 v. P }5 |/ ~% J0 W3 e# }9 s# q2 i' Z
IF[#9EQ#0]GOTO9001
4 e8 K! a5 V2 `( M$ Q/ v
! \7 B5 }* J3 O) j0 v8 p9 TIF[#9GT100.]GOTO9001 * U7 u5 i( X4 Q% t H$ v1 j I
4 y$ L' N% {" ]3 p0 M4 c" bIF[#18EQ#0]GOTO9001
7 T0 q& s5 g9 Y. C* O5 }! m4 S f( ?5 ^& |# L8 `
IF[#26EQ#0]GOTO9001
2 I U$ v1 \- U! ], u' d
# @/ S3 a5 m2 B% Y0 G$ L) UIF[#26GT0.]GOTO9001. z9 I7 h' g, \
# I" Q, K8 {; |
IF[#26GE#18]GOTO9001
* x* r+ E5 `$ v" u( c
& a' @7 H+ [+ s sIF[#8EQ#0]THEN#8=0.4
- O0 V+ @( r7 X+ ~( f9 w7 R7 d6 d% U6 L7 B: J7 k
IF[#8GE1.]GOTO9004
) J3 I7 n0 L: }" M, g% \
) e: T7 v4 i2 ^& a/ u( pIF[#17EQ#0]THEN#17=7.
) M- v; o- z6 W b4 f' ^6 c
; r+ B3 W" D! @. i: Z. G3 c7 mIF[#17LT7.]GOTO9004
4 @6 r$ X4 X' w' T- K4 N; z/ X% K, ?" y" N
#24=#50011 a1 M9 k6 o; b4 O
; u* u) g* a/ K+ d/ V
#25=#5002 B( w7 ?5 m) D7 W8 e9 X8 ^
, q% U& |0 j( V2 v) ^+ h#27=#185 U% o5 c2 [9 y- Y# d( v( ^) Y2 {" j
. I1 r& y; x; _$ G
WHILE[#101EQ0]DO1) F& e3 _- C' }. }# Z) e
4 s: J c/ G5 r+ x& d. f8 q
G4X1.5 F, K1 P; Y: D) t! U
5 j4 H9 C6 K3 Y8 b6 N; nGOTO99 * {1 ~7 A5 u5 U4 H; z; k5 t- C. I
. I1 [7 Y& ^' h4 [) t$ XEND1
9 T; x2 _7 u" ?6 D- Z( m/ U/ o$ T2 o8 u
#1=#5003 " ~3 L G4 U3 K& {* m
$ U) F: | {/ P- \" G6 P
WHILE[#101EQ2.]DO2 ' e! t( _. n6 S) {+ P5 W6 V' l
; u% P: \" |2 f) E
#26=-#1103 k/ ~# L' S" f( S/ |6 Q
6 F' R$ J2 f7 H$ F7 Y1 t6 I* ~0 p, ]#18=3.
& J8 B& c7 q% j8 } X# {" q, k( ^ t' A: H( u& _0 Q; B8 X
M103 \' z( ~4 v! i" V) D
- c2 l' H9 I: dM8 ; u, {. Q* p0 H& X
4 _2 d/ r& o4 v- J- jM3 * `+ V3 t, f2 J. o2 a
$ l1 h+ r% d/ y$ n4 o
G90G1Z#18F500
/ J V5 F# i! a+ c* z
& Z. [1 |+ v( d( T, t; P/ \6 F# UG1Z#26F#9
6 a/ v: h! D2 p( o/ U# I# ~- S$ }& l9 ? n. e. ^
GOTO11 5 a3 s+ B. T4 V7 W3 c. p, G. H u
7 W9 N9 o7 m" ?8 t7 t5 i9 z4 p
END2 5 y2 X" e; W# p% r ]! w
7 b4 c8 S9 D \, r- j
M10
7 f/ d7 b! Q6 c7 x) p
- } I3 x e' |5 L; I& m lM8
$ F4 H4 x8 P% i& i5 G) @& U6 w5 Z5 t5 x( N
M03S300! r5 u T- B& S/ d' t7 k
# A2 {8 n1 b. s0 K* A
WHILE[#18LT0.]DO3& B; C1 Y6 R4 I E6 T
' [# d' m! k" ]0 h
G90G1Z#18F1500
4 n* v. j- x8 D" s
8 Z4 \# i, e0 l) ?M03S2000
# V2 Z8 }! a1 y; p. v, \, F
' m* j1 B( Q+ R- N( yG1Z[#18-10.]F[#9*0.5]
4 c2 z* r8 H3 w6 E4 ~8 c4 W9 F
9 D j) U4 L# @GOTO10
6 S( o0 v8 M; H' c8 H
; N- z1 t# _& o) w# E, x- s* }& yEND3
! c7 V$ N+ l; f& b! B, w
. T# J% p' k. X4 w, h3 }6 |9 }WHILE[#18GT0.]DO1! S# l+ i `. P: v
5 v# B$ ]6 {" P3 `" ]$ x
M03
/ P- J. R% Z2 L% Z% ?6 r/ |" ~, b2 }
G90G1Z#18F500! a5 `1 _8 H; L7 t
" p3 I0 A9 i, u8 M; x8 B, _IF[ABS[#26]LT7.]GOTO10 " V4 V0 ?( Z, d. y+ k {( F; j+ f& |, P
) g- R5 K9 E# k8 ~! EG1Z[#18-2.]F#9 ! _ A/ Q+ D0 B" @
; f; t2 w6 p4 }* `
G1Z-#17F[#9*#8]2 F R* h( h9 o
( W% |( T/ y3 h; ~0 K% d. A6 V
GOTO10
6 J3 ?) x0 F4 z0 f2 d- p: V4 _6 ^* [& o8 |
END1 0 {8 `. i* X) k0 K4 x
* c( R! d, x2 z# i
N10
" L& n2 k# x2 ]9 G& }- r5 N/ u" Q1 j! u3 [' B# L
G1Z#26F#9
5 j0 Q9 B. B+ L! w* k: v, l9 a D: O3 u
N11
- H% S' ?. S% S6 j$ ]. k
! ] h5 g4 g3 IM5 + X( Q3 w* D7 q! F9 I6 P
2 t( a; \% F( m% o s5 lM9
8 f) L, |& N8 e- @, I/ ]( S
6 |2 d& q0 O1 P3 k1 ?# ]/M11
' O& |; P1 |9 d: V0 \7 m
. }( G. h6 D: t9 ]* k6 WG0G90Z#1 + d; N# q1 p% Q ]6 C
8 V2 ~$ R( `3 D2 D
M11# t5 s! b2 w$ f: Q) `6 u$ v+ l
& r3 S) q+ j1 r
G4X1.: l7 d$ p* n# \" M4 @, \
" w4 m8 h/ M- U) \8 e B
N99: x% Y. L6 d7 b
% q3 A* G# a& J$ Z0 U- ~2 _
M992 Y# j# m# V7 U+ o
/ y; R( T0 b4 ^( HN90014 Z2 K- j( U, n" Y0 }
7 I j' Q; E! g! L1 L#3000=1(ARGUMENT HAD NOT BEEN SPECIFIED) 3 E8 |5 Z1 Y" A- m4 m
. _7 k% _+ k! ~% p' c0 TN9004+ @$ Q( a) `' [; G! Y# W
2 R% j) @/ ~& a; ?#3000=4(UNSUITABLE RANGE/CYCLE DEFINED). Y, X0 q1 |. L6 e( p- p. N r
+ ]3 Y* E l a2 u# Y% |
