查看: 1402|回复: 0
急聘 齿轮热处理主管
发表于 2012-4-25 14:55:37 | 显示全部楼层 |阅读模式
[tr][/tr]
客户公司名称
江苏某新建德资企业
职位名称
热处理工程师主管
网上发布名称
热处理工程师主管
工作地点
江苏常州
招聘人数
2
预发时长
2个月
年龄
27周岁以上
语言要求 英语
学历
本科以上
工作经验时长
3年以上
简历转发邮箱
其他要求
Responsibility:
1、Drive optimization across such areas as: equipment installations, product/tooling DFM, and process/transformation modeling.
2、Approve/document modifications to reduce scrap, set up times, run times, machine or production system malfunctions.
3、Oversee plant laboratory functions (documentation reviewed、parts inspection and draw up test plans etc.
4、According to production plan, analyzing master schedule, organizing and monitoring the production of workshop together with Manufacturing Planning Department
5、According to master schedule, organizing and assigning resources of workshop in order, monitoring progress of workshop weekly plan.
6、Cooperating QMM Department to execute normal quality control procedure in the workshop, improving & perfecting the quality control procedure.
7、In cooperation with the maintenance department and drawn up the system-specific check lists.
8、Supervise Senior and Lead Engineer to answer questions, develop their understanding, provide direction and team building, and ensure process optimization.
9、Control all kinds of cost; reduce the cost of manufacture and quality.
10、Assist operation of new production plan, and testing for new production
11、Play a lead role during customer heat treat and metallurgy audit.
12、Implementation and organization of staff training(Security、Plant operation、Plant Maintenance、Process、Organization etc.)
Requirements:
1、Metal material or heat treatment engineering bachelor degree
2、Above 5 years heat treating experiences.
3、Good knowledge of heat treatment equipment.
4、Knowledge of quality control tools, such as PFMEA, SPC, PFD, etc.
5、Ability to work independently and in team
6、Good command English both in written and verbal.
7、Good continuous improvement and cost control awareness
Skilled with Microsoft based software.
GMT+8, 2024-11-23 15:41 , Processed in 0.059017 second(s), 23 queries , Gzip On.
