产品的性能参数,求教各位老大啊.....
" S+ _2 a+ ]( jMEASUREMENTS | Weight (incl rotator and hanger) | 1,250 kg (2,756 lbs) | Length | 1,470 mm (58 in) | Height without rotator | 1,680 mm (66 in) | Width | 1,540 mm (61 in) | Power consumption | 90–130 kW | Operating pressure | 28 Mpa (4,060 psi) | Oil flow requirement | 240–300l/min | (53–66 gal/min) '(53–66 gal/min) | | | | SAW | Saw bar length | 750 mm (29.5 in) | Cutting diameter | 640 mm (25 in) | Chain speed | 40m/s (131 ft/s) | | | FEED | Feed system | 3 feed rollers | Largest opening | 630 mm (25 in) | Feed power | 25–30 kN | Feed speed | 0–5.8 m/s (0–18 ft/s) | | | DELIMBING | Largest opening | 620/730 mm | | (24.4/28.7 in) | Knives | 2 stationary | | +4 movable |
% B0 K' o( q O* }0 ~, ~ |
