jiangssli 发表于 2012-4-2 14:57 6 l" s H# j" C4 q: g. P: a; \6 \
最理想的编程就是G32加宏程序....
+ f6 ^1 k4 F m* C6 n% \$ B7 Y一生大师!我把参数带入你发的程序里面。请你指点一下哪里有问题,帮忙修正一下。
; }% w# z, y0 t0 I4 F0 C%! k* d# h, h; G) E, j) l
O01029
5 D% r$ O; i% m1 ]& hG00 X150. Z50.
% b8 i0 c# c6 VM03 S200 T101
7 c* U- M: m1 }4 J, d2 CG00 Z10.
5 T5 b; s7 r6 H1 s8 xX90. 1 B5 j8 V2 V- h1 s
G65 P1050 A20. B5.29 I0.5 J0.1 K17.8T4. U0.15 V20.W3.0 X44.4. Z-100. F75.36 ( y% h7 H. {. L& ?
G00 X150. M05 + E% x4 g7 D3 _& k: d
Z6. 4 Z: q! Z4 g L( |
M30 ' r+ R% u" ^ B1 h
O1050
4 d& m$ v+ f; i7 J% A) u/ O" z#100=#6
# ? l# Y' z) I% V4 g#101=#24 \4 C6 j9 e2 ?/ F1 D* t
#102=#24+#6*3
! c1 O. g) i+ T+ C+ ~+ i#6=#6+#21/2& e. s. x. J' U( m: n$ s7 x
#15=0
4 I9 x( f* N0 _- u+ O$ }- @WHILE[#15NE1]DO1! a) j6 F) |3 E! I& W
#6=#6-#44 X. F6 h. b. U) P# t
#25=#24+#6*2/ n) @+ t# y5 s+ W/ Y/ Z/ s# Z0 a
IF [#25LE[#24+#21]] THEN#25=#24+#21$ N7 a" m* J1 x" H# L
#10=TAN[#1]*#6
3 W1 U! g! M( @ D#11=TAN[#22]*#61 n: ^" \5 A, r8 y P: Y$ R
#110=[#2-#20]/2$ }( B5 k' M* _. y
#111=#10+#110- Z- A, [$ _% A5 ^: d& `
#112=#11+#110
5 G* X Y, r( C#12=#111+#112. H" }. ?; A2 w) r7 @; U9 o
#13=FIX[[#12+#20]/[#20*#23]]/ M C* S/ q" S w2 W
#14=#12/#139 F; ?5 G* a3 y& j
IF [#2EQ#20]THEN#14=#1125 b ]' d& R- K* l% d& Y7 ]% ^/ K
IF [#2EQ#20]THEN#14=#111
; o8 H& x3 l; h9 L7 U5 U$ ~6 x9 nWHILE[#112GE0]DO2
/ T/ K2 f0 v6 i9 ~0 U& eG00 Z#111
; x, v7 b1 A9 eG00 X#102
3 _, |1 D7 y: n I6 }, y$ @9 cG92 X#25 Z#26 F#9 Q0& i3 I3 r2 C' E% ]0 }; V( @+ _
G92 X#25 Z#26 F#9 Q120000; u3 E# q- k8 X$ U9 ^6 u
G92 X#25 Z#26 F#9 Q240000) N0 S$ H7 v) {7 ]
G00 Z-#112 z7 r& U6 {; `2 u) V# p V* D
G92 X#25 Z#26 F#9 Q0! I2 t3 ^4 D. {8 {2 W
G92 X#25 Z#26 F#9 Q1200005 g- d, U! u1 c( l& k
) M; N/ ^, o+ s$ t, \. o; b! d#111=#111-#14- u. N0 E" P4 e2 d% t8 N
#112=#112-#141 K( h8 p k7 n" B2 H, T: b
END2
$ a* g; A1 i1 L& ?% }( Y' _: GIF [#25EQ[#24+#21]]THEN#15=1
" y: B; ?6 |* Y. u+ \END1
6 Y9 B) B8 p: l) e* \/ O& l5 ^#6=#100
( d; X$ _* `" F#24=#1019 \' k, ]$ C) i e, ?
WHILE[#15NE2]DO1
) t! s2 B6 g( e. j) A9 O5 ]( F: n$ c#27=TAN[#1]*#6
4 C! G: k+ {& W# ~( Y9 W- X$ }" C: n#28=TAN[#22]*#6
; o* V2 s( w4 f" `* x/ r+ v#113=[#2-#20]/25 i5 K2 d5 D& c
#114=#27+#113
7 J M- ]9 S4 |3 R9 f' ]4 z#115=#28+#113
0 ?: U# G5 b1 L$ J; R) f4 U* [#30=#24+#6*29 L' |/ y' x" v1 a* u4 Q
IF [#30LT#24]THEN#30=#248 o, x9 o; _( ]" [3 _9 u% m! ~
G00 Z#114/ R4 R8 Z% i! t
G92 X#30 Z#26 F#9 Q0
( a6 E; ~. ^8 `( z( NG92 X#30 Z#26 F#9 Q120000
6 r4 b& v0 B- L! G$ vG92 X#30 Z#26 F#9 Q240000. y S! [' S. M& w+ k4 l
G00 Z-#115
$ W8 f) X0 G4 T6 t6 y5 }" {+ EG92 X#30 Z#26 F#9 Q0
3 x1 R$ {, |+ KG92 X#30 Z#26 F#9 Q120000
8 F8 k) ]' g7 }5 dG92 X#30 Z#26 F#9 Q240000
( B0 A1 u+ N# ?" P6 \& G- O#6=#6-#5; Y* }" Y: [, f7 @2 S3 e
IF [#30EQ#24]THEN#15=2
1 K8 _5 i @0 ^: L& A8 JEND 1
, Q. A. c% y. X8 c3 |; _& g" gIF [#2EQ#20]GOTO2' F1 T1 E& \# c7 J
#31=[#2-#20]/2
6 E3 B5 a9 R O#32=FIX[[#31+#20]/#20]& K% P4 ~ \0 }0 ?8 A
#33=#31/#32
0 {7 j5 |! ~* @2 g# @# TWHILE[#31GE0]DO2. }) b1 G- K; P
G00 Z#31
" _% j# q' P/ G+ A4 k3 PG92 X#30 Z#26 F#9 Q08 c+ m" r) L; i0 u, g' D& m. | }
" C$ Y( P4 o7 T8 [% s' hG92 X#30 Z#26 F#9 Q240000
3 s6 [% F* j. i# e# V% y8 qG00 Z-#31 I2 X) d* k; R' t' m: v
4 E# N' ?6 g2 \1 xG92 X#30 Z#26 F#9 Q120000
& G/ P; c* q3 }' k; ?7 |G92 X#30 Z#26 F#9 Q240000
& ^' O- `. [0 `' Q1 p$ i#31=#31-#333 L+ F/ M U( s! F
END2
* x7 R: }- b1 {; ]8 v6 r5 W. qN2 G0X100Z50, N* ~ l( k% h3 L& x3 i
M99
7 C: Z4 R( S j6 _ |
