The executable d:\SIMULIA\Abaqus\6.11-PR3\exec\explicit.exe aborted with system error code 5. The executable d:\SIMULIA\Abaqus\6.11-PR3\exec\explicit.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
6 J) l B4 {& R+ O* m6 d- C仿真中遇到该问题,重启电脑之后也一直出现该问题。后来我重新装了一下软件和系统,但是结果还是一样,请教高手这是什么原因造成的,该如何解决。麻烦了,谢谢大家!!! |
