查看: 7301|回复: 10
苏州某外资企业招聘工艺工程师
发表于 2011-9-27 13:59:38 | 显示全部楼层 |阅读模式
1.Engineering 工程技术
, @* a3 I' f% |9 g) |2 eFamiliar with heavy duty casting machining process3 [7 x7 L. E, m: b6 J/ V7 ?
精通大型铸铁件、铸钢件的金属切削加工工艺;
4 R/ R+ |5 L# NHave good understanding of engineering drawings.1 `$ d. Y' u8 m% |
能够识别Auto CAD工程图纸,熟悉工程图纸公差配合等。7 v) s) ^9 L$ S$ f4 c, x2 O+ M0 ?
Familiar with Fanuc 18i and Siemens 840D system and machining program writing
7 K' S, o0 q5 U. O" U+ c- U+ ]熟悉Fanuc18i和 西门子840D操作系统, 依据图纸能进行金属切削编程;9 J7 A/ t  a5 }! t) U" I" x
Responsible for new product introduction,and design fixture and select machining tools according to engineering drawings.  T3 t( H2 d; n+ H
负责新品的开发,根据加工图纸和工艺选择合适刀具,并进行夹具设计,和加工工艺的编制工作;5 Q# K2 ?6 ^8 }3 R  [
Release process method instruction and SOP procedures2 X+ B) T! a& ?0 k! S
发行工艺卡和相关操作标准书,监督首件的制作,并进行现场指导。
5 h& q& `( H& g  B' nCheck first workpiece sample.
& z0 i# L3 @" ~& P% y负责样品或首件的测试工作# E+ @& Y' q, t
Track and improve the existing work methods, reduce machining time and tool cost2 P  D: b. Z" o5 |, j, C
追踪和改进现有的工作方法,降低加工时间和生产刀具制造成本。0 H) W# r9 q" |. M+ I- L# w8 }. y; v
     8 }, y: `" y- Z) B4 ~; [4 v0 [
2.  Participate in and support Ceiko quality and productivity improvement activities, reduce machining time and save tooling cost.* b: }9 C7 p' e6 c+ Q
参与并支持公司各类的品质改良、生产力提升等活动,进行持续不断的改善:减少加工时间和节省刀具费用。0 T. ?0 l/ T- |
1 p  b; u0 i$ {0 H' d8 Z3.Work with QA people to contact clients for technical and quality issues
7 i* t( M( M3 T- r配合质量人员联系客户有关于技术和质量加工方面的问题
7 b$ f5 l; F& I/ a% t
" W; d9 ]. h- l- ], d+ @8 y& s4.Collect and provide technical basic knowledge for engineering, such as estimated machining time, tooling and fixture setup cost.
* P. s- `8 C! B+ _$ k对新产品,收集并提供基本技术信息,如:预估的加工时间、刀具和工装投资费用等。
$ c2 Q- ~3 x4 Y+ y) A: E5 ?
9 p  G( p+ C; [! i5.Plan training schedule and prepare  training documents for new products
: G, ~, z0 i) Y4 ]  J针对新产品,提供培训资料和培训计划
3 c0 U( V/ ~3 [3 W! l* V( r      4 V2 g% ^; G3 m( G% F
6.  Accomplish assignments by production supervisors# n0 ?. G& I- X+ e$ W: W
完成主管指派的任务
- ^3 Z$ H4 P/ O# b' \
0 D, o! L' H0 m9 bNote: Ceiko can provide opportunity to promote high level as engineering department head4 x8 C5 P. N  X& V6 t* C
本职位公司提供机会,作工程部门负责人来培养。
2 D8 ]" G- k- _0 c+ K
! f8 n' M# d" G7 K4 _7 T0 W$ pJob Requirements(要求):
& W  t" a! M  L5 p/ |2 ~; h
* P3 ^5 M; d' z0 M  y6 [7 P9 Z& ^Education:  Minimum of a Bachelor’s Degree-大学以上学历
+ q+ o0 N3 P7 s         Industrial or Mechanical Engineering preferred-工业工程或机械工程专业& g. }, @: z- ]% Y, E' Y3 z
                                    7 ?% j6 s; _+ Z( ?
" c) x2 n! T5 a0 w, g) c8 p0 NPersonal          Must be an excellent communicator.  Must demonstrate working0 a+ N1 ]% f' t( k
Characteristics:knowledge in all disciplines of World Class Manufacturing Field.
2 w6 }1 d/ a: ^) |, M) O& B                    Good initiative and strong sense of urgency. Team approach to problem solving.
. z7 n) k0 x, T( i: q                    Individual must be a motivated self-starter with the ability to work' D" |; K% K3 D
                     independently and/or in a cross-functional work team environment.* j6 h" ?& u; V% y
                      优秀的沟通者,具备团队合作精神,工作有紧迫感,能够弹性地工作,能够独立解决问题的能力。8 T# |9 V8 m0 M4 j8 m7 S; _4 L
9 b3 G& e+ g8 p! P; Z; @# C
Work             Minimum of 8 years related experience in technical job in the high / {" `" m0 r& W* @2 v
Experience:     precision CNC machining environment.至少8年CNC金属加工经验
' t- q7 Q! |; y# ]0 f' n, T1 o: ?: l( e5 {' x
Have the skill of fixture design, tooling selections, processing method and processing timing, CNC programming and parts' measurement.
& n8 P+ M1 m7 ]& G! K6 ^4 A精通工装设计、刀具选型、加工方法制订、CNC 编程和量具选择&测量.
4 _( B& [0 D, z7 E! ]! h
5 N3 |1 F+ T9 C0 n" E' Y# z) @Skills:                         Know and work with metals field (products / raw material)
4 j' r, x! @" A' ?1 u8 W( T必须熟悉金属产品制造加工. c7 ^3 y0 ?; R
                        Computer skills – Auto CAD, MS Office required( t0 I8 N7 V) ]9 O
熟练使用CAD制图软件和办公室软件,会3D三维软件者优先考虑6 C" M) ]; T/ {5 m8 l
                        3 b0 {0 t* z( R' _
Qualification:1.   至少5年实际操作CNC立车或者龙门铣的工作经验
# Q( ~" t+ a2 P0 c) b          Minimum of 5 years working experience in CNC machining operation-required
9 M( ?( d3 x$ M' g6 ^& h/ U                          2.能够读懂图纸,根据图纸进行编程等 3 M8 G6 q5 g. \, ?1 ^
                                Can read engineering drawing and write CNC machining program-required: P; A* u3 C0 W' ?
                          3.必须熟悉法兰克和西门子操作系统7 F$ y& H# N0 w7 l
                                Familiar with Fanuc 18i and Siemens 840D system-required7 N9 O) l" N3 k$ _& ?
                          4.精通CNC程式编写/修改或加工参数的设定。
  x2 t: k! Q% a                                Machining program writing -required6 F1 @8 N. _5 _/ w! k
                          5.能进行简单的英语交流,可以优先考虑。
9 V- K7 k6 s# F* r# C                                Language skill: Good command of English spoken-preferred
2 g! Q/ n, ]2 C  R2 [5 h
+ k. P" y- G, x# G7 v$ D/ E
" m6 c, o  H+ J, r有意者请将简历发送至:xiaowei.yu@gigroup.com 联系电话:18662523193
 楼主| 发表于 2011-9-27 14:02:06 | 显示全部楼层
我先沙发。。。上面的职位待遇五位数。。英语能力要好。。。
发表于 2011-9-27 15:06:00 | 显示全部楼层
待遇不错,可惜没有金刚钻 {:soso_e110:}
发表于 2011-9-27 15:41:52 | 显示全部楼层
vito_yu 发表于 2011-9-27 14:02 - Y$ {4 {9 Q9 }, @" _9 I' _
+ ]% g) \0 U% ~6 I! c; C
是月薪还是?呵呵,你的要求挺高的吗?
1 S) Q  [8 _  R9 O
我觉得干得了这个差事的 五位数 不高吧  发表于 2012-2-24 23:15
发表于 2011-9-27 16:26:25 | 显示全部楼层
英语难住不少人,否则我可以推荐几个人选
发表于 2011-9-27 16:42:34 | 显示全部楼层
都是英语惹得祸,为啥非要英语啊,痛苦。
发表于 2011-9-27 16:48:42 | 显示全部楼层
如果这么多年一直都勤奋钻研、善于学习总结的话,现在的我应该可以试试,可惜假设不成立啊
发表于 2011-10-3 11:44:08 | 显示全部楼层
月薪没有3到5万没人有那个实力,从铸造到金属加工,到车床维修,产品设计,客户维护,一个人当4个人用了,楼主应该招个职业经理人去,把公司托管
发表于 2011-10-3 11:45:01 | 显示全部楼层
发表于 2011-10-3 11:45:58 | 显示全部楼层
GMT+8, 2025-2-20 17:50 , Processed in 0.061261 second(s), 19 queries , Gzip On.
