模具述语 " K2 w! Q3 ]* o1 x! E4 d2 i
一、入水:gate
5 J5 U3 {1 V0 h, r( [( _进入位: gate location . |! `. L" J- P
水口形式:gate type
8 r+ o- [5 y' Z. B大水口:edge gate
, t T+ \( h6 D# o8 {; O( K细水口: pin-point gate ) S" w# |% `# O1 w o% R( Z
水口大小:gate size
; k& j% L9 `% X3 { N& U( q" ]% m1 B转水口: switching runner/gate
8 U' k s7 a! i8 e2 q% [0 Y唧嘴口径: sprue diameter # U" |- P+ D2 `9 P
二、流道: runner
! y5 p/ f; y! z* q8 x8 Q7 ~热流道:4 |7 v. w8 m9 n6 [( U* d/ ^, r/ R7 a
hot runner,hot manifold
; {2 C; N0 p1 C4 d热嘴冷流道:
5 D3 ^* c2 \- g# d8 u2 D$ a4 Y4 g2 Zhot sprue/cold runner
0 D- ?& y! m/ r. t! \5 Z7 J, t8 r唧嘴直流: direct sprue gate
! J% u" Z, c3 Y3 k! h& X圆形流道:round(full/half runner 2 D% U* p% R- G: U
流道电脑分析:mold flow analysis H2 ~- a5 X; C3 G# v/ g9 W
流道平衡:runner balance
* i2 e8 F! a# ]+ E热嘴: hot sprue
4 N# _' ~! I0 `3 K4 s* S4 V* U热流道板:hot manifold " _/ l# L$ t2 q: A5 ?$ j
发热管:cartridge heater
$ O e7 X6 } O' n' q探针: thermocouples , a% [9 w _8 w! U
插头: connector plug
+ j: \( d4 d% m. Y8 S! h插座: connector socket ' _$ c X6 ^5 E4 t- h/ I, E
密封/封料: seal 8 G/ L- F( _3 E+ ], Y3 a
三、运水:water line
1 R( Q& j# d8 M喉塞:line lpug # i4 m9 v7 f1 X5 x; g2 Z4 c* V: L
喉管:tube
+ E, b5 V' L+ k# V7 L塑胶管:plastic tube 3 |) F: c- j1 b: v" N2 v
快速接头:jiffy quick connector plug/socker , T2 n6 l+ X2 v0 Y
四、模具零件: mold components
$ z; I0 H& g3 c s% T3 N( x三板模:3-plate mold 7 e' _: y: Z4 P3 i( _
二板模:2-plate mold
4 j" @ [! M( h" J; C/ _边钉/导边:leader pin/guide pin
5 L& ^: z* ]0 k3 [+ a边司/导套:
# n, b& X& K, ~" ^. T+ nbushing/guide bushing
1 D4 r2 p7 O( |中托司:shoulder guide bushing $ n5 k, O6 f; r' \5 H+ A
中托边L:guide pin
! h/ S: m0 N' o! K4 k顶针板:ejector retainner plate 6 j3 T: B6 S- U5 r# y4 }
托板: support plate & c* K/ p: R% R7 X6 B. p. I. O! _
螺丝: screw 3 w0 s1 H' q2 ?( s8 V* p
管钉:dowel pin 2 t( m! l+ O! f7 z/ a) c
开模槽:ply bar scot + O2 L2 q3 b/ m+ _, j4 L, {
内模管位:core/cavity inter-lock 9 ^5 ~1 f! N$ {* c
顶针: ejector pin
; s$ g) m+ ]3 k9 L7 A( W模具专业英语6 r2 E; M+ `7 J3 C
司筒:ejector sleeve
. h4 y2 ~% r; W司筒针:ejector pin V, \0 [2 @4 ^# ?3 ~
推板:stripper plate 8 u* [+ b) S! _- W7 S. D' ~6 x
缩呵:movable core,return core core puller
7 ]5 p; G4 G+ j扣机(尼龙拉勾):nylon latch lock
# b3 z0 |# ~# V/ {0 d2 P, y5 R1 l斜顶:lifter + n. I% k# h7 B9 K
模胚(架): mold base 7 l( G9 Q7 g: A6 ?$ E- ]2 S
上内模:cavity insert
5 r3 C) K6 u! A. ^下内模:core insert
9 Q9 V- a7 e2 @- Z- i行位(滑块): slide + E+ J, O j8 }% x; `
镶件:insert
3 P) [ H9 G1 E$ ^+ M压座/斜鸡:wedge
# V) P+ S3 }# C+ Z/ }2 z% f耐磨板/油板:wedge wear plate . R$ d! M- P4 q" {8 [) ~: x) u
压条:plate k$ q3 N% K' H, A) {/ q0 X
撑头: support pillar
1 N6 R# a2 K. n) k& U; Z- Y; Y& z8 `唧嘴: sprue bushing
V Q" b4 i( n5 J" u1 v挡板:stop plate [' `5 ]3 ^4 Y8 }( {
定位圈:locating ring
7 A- x l; h0 t* p4 Z锁扣:latch
% J& ^, k$ w# p% r3 D( z; k) ^: b扣鸡:parting lock set ' H: p: O) _! a' s- Z* c
推杆:push bar 1 H* l" f8 k. n2 B4 \% r/ I
栓打螺丝:S.H.S.B / b% i9 b6 J+ N! e- z" ^
顶板:eracuretun
4 W# Q% ?: j4 q0 Y3 ^活动臂:lever arm 2 a! x: {: n# @" U; r, L
分流锥:spure sperader
3 {" L# g8 _% C, Z水口司:bush , `6 y8 |6 _( c( `$ [: M
垃圾钉:stop pin 4 x, n- g# v; C$ g" c$ o* N) s% \
隔片:buffle 3 y4 o# D3 J; c) z$ S
弹弓柱:spring rod
# N5 Y; n6 E& C5 E& A* @: B弹弓:die spring
8 Y& y! u1 a' J: c" ~中托司:ejector guide bush
* A3 m1 W& U, @ S中托边:ejector guide pin
4 s' F/ P/ F- Z镶针:pin ' ?6 M3 j1 c6 K) h( g
销子:dowel pin
/ ]1 V8 m3 X. I t; e$ [6 G/ @2 B波子弹弓:ball catch
: Y) y! O2 X1 i喉塞: pipe plug ! Q; A( n$ K+ a7 y" V0 _
锁模块:lock plate + c2 Y/ Z+ r7 t( P6 p
斜顶:angle from pin 7 V& L- N1 W: w# D; |3 d9 _
斜顶杆:angle ejector rod ( u, t( S* b" m- m
尼龙拉勾:parting locks ' [9 T) L$ P0 H0 h- o I0 ^. W
活动臂:lever arm 5 u/ B0 I4 |5 [7 c1 h0 [) e
复位键、提前回杆:+ p3 ~: J7 ?% O# a: |4 q- u
early return bar
+ s2 u4 U& b. g' t/ K; G气阀:valves ; X6 L* a" n1 a
斜导边:angle pin - n# u! p: q* U: i+ Y" U S5 V: Q7 U
% U! G8 _; S. B/ P8 D, E
- E! P0 q9 d2 n, h5 P3 |术语:terms
; p3 K4 H% }. }, G Y9 G3 a# t* T承压平面平衡:parting surface support balance % o0 x; m8 V$ c5 D% K
模排气:parting line venting
% m3 g* i, ~9 D; |回针碰料位:return pin and cavity interference
) j R+ U5 z( H3 @, F; l* S; s模总高超出啤机规格:mold base shut hight / _+ b- v$ j1 A1 d7 p) k v8 B
顶针碰运水:water line interferes withejector pin
) m( X9 v2 P8 J# C: s }# @料位出上/下模:part from cavith (core) side . L: \/ d3 }; D( O7 p
模胚原身出料位:cavity direct cut on A-plate,core direct cut on B-plate.
6 | k6 `: T: V* T) D' h不准用镶件: Do not use (core/cavity) insert
2 @: M/ `2 }$ z5 @5 c用铍铜做镶件: use beryllium copper insert
! q+ Z$ g7 ~% ~; x4 |+ i初步(正式)模图设计:preliinary (final) mold design 5 O% B; K5 k) ~ p8 k, u0 C; b9 `
反呵:reverse core & P8 x8 C' F1 s# T
弹弓压缩量:spring compressed length $ {$ O7 K% Z! y
稳定性好:good stability,stable 0 `! P, a% B+ u2 Z: C# t
强度不够:insufficient rigidity 6 H) j6 S8 v# c
均匀冷却:even cooling : H+ g5 N+ s! i( ]. F5 g9 s/ N
扣模:sticking
) k3 o3 E0 j7 T4 n i; d, P热膨胀:thero expansion & c* i# e" g6 |1 `
公差:tolorance ; p& ]8 D, J4 a0 M& d
铜公(电极):copper electrode
7 F6 f1 ]- ^# K9 b2 s9 I志远翻译社
2 z7 W, _+ g# j. z, N' D |
