查看: 2754|回复: 1
美国密尔沃基牌充电式冲击扳手700牛.米扭矩Milwaukee M18 18V 1/2 Inch Impact Wrenc
发表于 2011-7-30 13:47:32 | 显示全部楼层 |阅读模式
, c; n$ U' [% z/ H$ X
1 v/ p* g  X8 t5 X- t! `. gM18™充电的1 / 2“高扭矩冲击扳手提供业界领先的紧凑尺寸的权力。与密尔沃基® 4极电机,具有强大的影响机制为基础,在2662-22和2663-22提供450英尺-磅扭矩。变速触发器之间提供0-1900 0-2200 RPM及IPM的速度控制。2662-22有1 / 2“制动针插座保留,以实现卓越的砧,而2663-22有1 / 2 “砧与摩擦可快速方便地单手环插座的变化。
    * z$ \: P. N: g7 X  D6 }
    米沃奇 重载高效能电动工具 之
    0 D2 }5 h* v3 ]& W& A2662-20 M18 充电式冲击扳手
    / V5 q4 f7 [  y此型号为光机,一个充电器、带2个电池包
    ( G* N& X" m  g7 s" z1/2″方头 (12.5毫米)
    ) Q5 B  x. x; h8 S, Y扭矩450 ft-lbs(英尺磅)约合700多牛米,并且无反作用力,即使未成年人单手持也可以拆卸大型机械螺丝,
    & Z. }4 }! S' D9 ]0-1900RPM  电子无级调速4 f- g  A7 O5 a" N* B- _5 E. @
    0-2200 IPM 打击频率0 Y; w( h6 C# ^6 K
    6.7lbs 约合3.05公斤
    / Q! ~" f. w) n( R& H& g
  • Milwaukee® Designed Impact Mechanism: Delivers 450 ft- lbs of torque密尔沃基®设计的影响机制:提供450英尺的扭矩磅
  • Compact Size Light Weight: 8-7/8” Length and 6.7 lbs体积小巧重量轻:8-7/8“长度和6.7磅
  • Milwaukee® 4-Pole Frameless Motor: Delivers maximum run-time密尔沃基® 4极无框电机:提供最大的运行时间
  • 1/2” Anvil w/Friction Ring: Provides quick and easy, one-handed socket changes 1 / 2“铁砧W /摩擦环:提供快捷,方便,单手插座的变化4 N6 o  R3 q5 J3 U+ T4 b- C2 A# y
Model: 2663-22, u( V: q, H4 v) r" X; m, j
Overview The M18™ Cordless 1/2" High Torque Impact Wrenches provide industry leading power in a compact size. Built with a Milwaukee® 4-pole motor and a powerful impact mechanism, the 2662-22 and 2663-22 deliver 450 ft-lbs of torque. A variable speed trigger provides speed control between 0-1900 RPM & 0-2200 IPM. The 2662-22 has a 1/2” anvil with detent pin to achieve superior socket retention, while the 2663-22 has a 1/2”anvil with friction ring for quick and easy one-handed socket changes.. H! ?- a6 G* T+ G- E
( X; x+ x8 n" ]3 x* P+ m( Y, ~
    1 I, S# L( b# I& X' O: p5 L: L: r) f0 |% Y' k% j6 p: K
    7 ^% }; c0 i1 d  d9 z9 m0 z" u
  • 1/2” Anvil w/Friction Ring: Provides quick and easy, one-handed socket changes6 y7 {* r  o5 S; x2 a5 W
Our Buying Guides are Here to Help Drills
Whether you're a novice do-it-yourselfer or a seasoned pro, a reliable drill is one of the most versatile and practical tools to have in your home, garage or workshop. Today's drills offer multifunctional power in both lightweight and compact designs. With a drill by your side,...Read more
( S0 Y! Z5 b8 G0 |- n
5 q( W1 Y' o! m% v# s0 T1 f/ R" q6 L% {% i
Warranty Information 5yr Tool Warranty, For more details on this warranty, please call 1-800-SAWDUST
$ ^: p( H8 m4 M5 `! G3 h4 G5 p0 V
3 Q: ~! d( |$ [& H, w+ Q. K! n! y$ [/ R! Q7 |
Specifications
Assembled Depth (In Inches)17.32
Assembled Height (In Inches)13.58
Assembled Weight (In LBS)13.93 Lbs.
Assembled Width (In Inches)5.32
Country of OriginChina
CSA CertifiedYes
Item Depth17.32 In.
Item Height13.58 In.
Item Weight13.93 Lbs.
Item Width5.32 In.
3 h2 I. C4 l# |' ~2 z0 X
 楼主| 发表于 2011-8-6 19:17:20 | 显示全部楼层
顶一下
GMT+8, 2025-2-25 20:15 , Processed in 0.051087 second(s), 15 queries , Gzip On.
