楼主: 孤酒
水压试验台2MPa,油压试验台200MPa,求报价
 楼主| 发表于 2011-7-29 18:05:54 | 显示全部楼层
本帖最后由 孤酒 于 2011-7-30 08:07 编辑 6 _, ]9 I6 k( m8 v! {- D( P' q
! |% k& T& q: T- I( o从网上搜到如下设备:1 S* D9 p5 x: b/ h
7 Y# B2 e5 d1 @1 Q$ v1 a( ?
6 ?" z! W: s, H# }! ]名称:共轨喷油器试验台% U2 y( w6 r& I  z( o
& O- r5 q3 Y# ~
Name:Common Rail Injector Test Bench5 m* Q; B) C8 X% f
$ h* h  f" _9 W5 |0 G
规格:XBD-CRI/ b+ s4 [+ B; A0 |2 ^/ c- x
0 e* }$ r8 F" e% ESpec:XBD-CRI
' V$ W- j. f. R3 A4 I$ A$ Q% X7 c' a2 ^+ e% |
一、喷油器试验台主要特点:2 ]1 [# N+ H' v
8 L$ A. {7 V- `% w3 A- T1、本试验台用于BOSCH、DENSO、DELPHI等高压共轨喷油器的单次、多次喷油雾化检测试验,亦可用于柴油发动机普通轴针式喷油器、孔板式喷油器和双弹簧喷油器的检测试验。
# d- m7 P# Q) z5 A+ s$ L0 B8 q
, Z; d3 m7 U: X; j9 D/ H1 XBD-CRI injector testing bench is a tool for checking the injectors used on diesel engines,such as BOSCH,DENSO,DELPHI and so on. It allows you to test Common Rail Injectors and Normal Injectors.Watching of the injector's spray, measure of the opening  pressure of injectors.( A, q& m5 W4 `% O! o- Q
" t/ w5 `( _( \; q- r0 V& r2、试验台参数检测采用windowsXP操作系统实时控制,可以设定和存储被测试喷油器参数,控制直观、简洁。内置消雾系统,改善工作环境。可同时测试6只喷油器。% E* I' e/ f1 c
" \; |9 h1 I: |& n# U" u
2 Control by computer, WindowsXP operating  system.You can set and save test data.Friendly picture allows you easily tooperate it.It's equipped with suction for frog .It can test 6 piece injectors at the same time.
; k1 k  T4 j; o- X- M5 b5 v1 D/ A. I( _% ?3 f1 V5 e
二、主要功能:9 T  P+ H5 A( R( u& C0 ^
2 d/ z. Z: s6 N3 F/ I7 C9 w2 N& |
1、共轨喷油器高频电磁阀性能检验。
; Z* p; ?/ W5 p+ Y7 R8 e
6 k4 z! A" u% E( j, e( S( A1 Checking of the solenoid valve of injectors." \* i( F% G$ k+ f" l
& R4 b- J% n6 w1 K6 X
2、共轨喷油器喷油量检查。! i+ Y  `" b& C( I5 |: z) t
% @. V% n( E  U' [* `$ |2 T2 Measurement of the delivery and overflow of CRI.
( n( C2 f( g# S% i2 g- t8 `& B
3、共轨喷油器雾化性能检查。
# m- _7 d  L# W8 z- K5 V' i# {- N, t  Y" i
3 Watching of CRI injector's spray.2 h0 |4 c* ?* _5 N
' ]  x. C: F. V8 j7 a3 s
4、共轨喷油器密封性检查。2 y$ f& y- r" f8 ?% Y/ L+ W
# i0 u2 I1 \& R7 @
4 Checking of the sealing of CRI.
. A7 {, ?& f  p; w
8 q! A; a% `+ v1 `3 H) B5、普通喷油器开启压力测试。+ L9 r' p1 e* z- d9 J3 m
) s) e: }- U# g3 o, ]5 Checking of the opening pressure of injectors. 6 B* ^5 ?' A: G# O3 V" Z6 q( C
6 I- h; e& a+ |- a5 ^
6、普通喷油器密封性检查。5 t! Q, t: J; S: B
/ v, ~& I* L" D2 t) s1 c: [6 Checking of the sealing of injectors.) M7 T4 h0 l1 W! ]2 ^
; }: v9 g1 Q% h7 、常规喷油器雾化观察。
4 U* z0 b" h, o8 `& ]! Z3 ]. K- L, A, u3 |/ L: A
7 Watching of the injector's spray.; p: v3 c1 X8 x
' ^+ y! j/ ^4 `0 l9 I三、喷油器试验台主要技术参数:! ~9 l1 ^$ s( t. d( \' y
, A& L/ Y# V, S1、供油压力:0-200MPa。: Y( U5 Z, q. [- c8 s
* S% Q' o( E" \* t. L
1 Feeding  pressure : 0-200Mpa.& ?+ f" V9 f6 n5 \& d
1 T- F5 f, Q9 R: _5 ]
2、压力表量程:供油压力表:0-300MPa;$ @+ X& U6 `5 w7 F: b( U+ \
$ V& }  O- J1 X/ U* m               气压表:0-1.6MPa。
0 _* I% o2 I( S* s  m* A1 g. |: h) G& j9 X& ]" P& N2 I( K
2 Pressure gauge : Feeding  pressure gauge : 0-300Mpa( w6 m& M7 ?. F0 W( h5 [
7 b0 c% G4 |+ u, O# k' C
               Air gauge :0-1.6Mpa.
7 `9 O) x% R  D6 m( Q9 ?2 ^2 l. N# }/ q0 O
3、量筒;150ml/24piece。& T: V& U8 ?. l4 c+ D
6 M& O2 r. _5 M* J2 s3 Graduate :150ml/24 piece.* J/ v& j5 I4 |' g9 h$ X8 a6 t
7 \+ T6 K3 `) p2 i7 {1 U1 ]
4、油箱容积:4L。9 g/ ]- ?- b# D# {2 K
1 O0 r' t' o$ j- @
4 Fuel tank :4L.
8 [, K( K/ A2 _' z6 ^- Y* H; ~
! C0 c# t' b: |. q( R$ g5、输入气源:0.8MPa,36L/Min。
  ], c  l$ Y8 k5 e, B& u' ^, y& s1 q
5 Air in: 0.8Mpa ,  36L/Min.8 s1 W! g3 t2 O6 I! [5 e! A0 B
9 B5 r: p5 O  R, S$ E" O, \% Q
6、输入电源:AC220V/50(60)HZ
- p/ [, r  ?4 |7 g) v  T; c* {6 f9 Z
3 @+ ?* p2 u# c2 K3 ~1 Q1 r6 Electrical power in: AC220V/50(60)HZ.
# U! @3 H5 K: z  B
: B3 [: }/ _! g" l3 v& F. j, s" yWe can create special requirements for other models test bench, based on customer requirements
发表于 2011-7-29 21:02:04 | 显示全部楼层
互通有无 发表于 2011-7-29 09:10
) G+ x$ q  C/ a我以前做过水压试验机,钢管生产线上用的,最高60MPa,口径最大300毫米,钢管长度要6000-12000毫米;你需要 ...
- G9 s4 \" Y8 m" x60MPa用什么密封的呀,最大就做过4MPa的,这么大的压力不知道你们用的什么密封方式,可以介绍下你的设备吗,及密封方式和材料的选择呀!
用水压圈 里面有不锈钢压块。  发表于 2012-7-29 20:46
发表于 2011-7-29 21:09:55 | 显示全部楼层
200MPa,大型矿山机械吗?
发表于 2011-7-30 08:55:49 | 显示全部楼层
我们可以做。。你试验胶管怎么不用水呢。。我们给兖矿做过一160MPa的胶管试验爆破机
发表于 2011-7-30 09:46:22 | 显示全部楼层
具体项目,想干的人还不少啊
发表于 2011-7-31 07:26:45 | 显示全部楼层
买个高压柱塞式水泵就可以了,油压机不一定要用柴油,用水是一样的,再说你用柴油也太危险了,如果一定要用油作为介质的话,那也应该选择煤油。
 楼主| 发表于 2011-10-14 17:20:40 | 显示全部楼层
该帖子目前仍有效,水压试验台厂家可以联系我。
发表于 2011-10-14 20:57:11 | 显示全部楼层
就是太远,要不兄弟想试试{:soso_e113:}
 楼主| 发表于 2011-10-15 10:16:44 | 显示全部楼层
大海无边 发表于 2011-10-14 20:57 + D# F) w% S$ _3 A' z" z
就是太远,要不兄弟想试试
7 K7 @; i- p( j- F9 Y; J# H
其实之前询了一家公司,三个月了连个方案都没确定,看来不想挣这份钱。
! R4 j9 p# K; m5 p, `- R2 G
发表于 2011-10-15 11:26:54 | 显示全部楼层
200MPa,这么大压力啊,…………
GMT+8, 2025-2-23 15:48 , Processed in 0.068284 second(s), 15 queries , Gzip On.
