这是本人制定的焊接定额标准供参考 开坡口定额标准
5 M4 M. t' R$ X5 I8 v0 S. A 4 s. E; c3 P% Q1 O. ]* r9 R( u: C
$ ^% r3 C7 a; |1 m9 O. m5 R: T
& i( s" Q8 ]7 U- d# y4 | w; k
! K- C. X% T% o# x; ^' A/ f5 z 7 b/ F0 @- m( n) v* }% E5 Z6 H+ O
C( e. C- t* _4 ?" u e 9 r- T( r6 x+ u4 ^6 Y, R
5 N, }' n7 N# X: T0 f# D2 l8 y2 k
* v. [0 {8 |: j8 \: j6 P V3 h : \& e% B* s9 r- L1 [
- c3 M) b1 }. m ; ~9 I% M: \$ V( ?# G9 O
9 N8 x% ^2 d, N5 T6 g. K4 T% E ( k3 u2 B$ d% W) @
; u" O/ m1 H7 }1 [" B# @6 e
( y+ `9 u; }. N6 q$ x/ r0 Y, W 0 |5 j0 B" v" W* I5 @6 ^3 e: Q
5 G6 B j2 l& @* y7 |
3 s; [% ~ q' u6 f$ G4 h- n: g + h! w" E0 b4 R1 l/ L0 b d% q
* C7 P7 r8 l8 U" r( P
2 S( e1 Y1 v' Z* A( L4 k % X3 a+ c" ?# {+ G; i# P
% T8 ~5 D. I- w+ P3 n " n% P& \& t1 F0 E, y: q$ g
. G5 X: c) `% }2 V2 ]# X ! W; m' R9 C% G5 z5 G# F: T# s9 i
% e( K! _$ ]1 r- Z0 F! a$ ]8 `4 _& h
6 f2 Y9 X% i0 f
( y% t+ d5 V4 @; b& w D/ D
9 k3 \. ?/ R6 V
. c# R1 g+ m4 L* q4 {9 Y
; R' O% _6 d( n y% Z 4 x1 v/ }. Y; o
0 V- [% x; [% }% ]
1 U% L: t2 B% Y8 i8 D6 E3 N0 s 2 h+ U8 [$ d; u1 q
3 A- g6 c% A7 j7 V, A: O . C$ |+ _) ]! g, F9 b1 j' c
8 w9 Z9 H" l G& t2 S+ ~. ]
) {% @, t& t$ M" e: R
4 V g, Y. B0 e/ u 0 U; P6 @$ M7 v: i% \+ t* R" P) h7 ~
; G1 n8 E/ F6 q' q3 V
, u5 c" ^# c$ N; ^1 F) j3 p
& R. S. X$ ]) S6 j' k) R
+ r: i. R! a8 c* J0 j: _4 i2 K 7 Y# _) H3 Y. \, J- K2 e% \
. B5 N, ?1 {5 }( K % M2 M0 O8 i/ ^* M" Y
! o% V# |3 }$ v; G! H4 i" L
% v6 G7 l; G5 {7 G M- H0 A o- n: `: m; C0 @2 E# N
: z6 z+ }' X1 k( ?! u / i+ a8 j+ p5 U0 L. _7 o4 K. U
4 X5 _+ O! x4 f $ N4 Z; f( P+ W6 D+ x! p+ o
9 ?) i6 U D" D- G# D8 K
$ r+ k: w' Y" P9 o& e
/ G" p8 I+ g9 t: F' F
+ r$ h5 \# q( \ 0 k6 f9 P4 U+ }# R7 h7 u3 q
+ r l! W. Y5 I8 a( N
5 l5 ]2 E Z' f) w! r2 D* O$ \
+ \- p+ v& ]% ]/ ?$ W) K 2 z4 ~+ B3 b! ~6 M( L
) ~# m X. K9 v) {. p# P t
7 z% A- }! G2 e& U: Y
) y: O( w1 N/ `* o - W* k0 h" G, \! S* {% f: l
- t/ p6 _$ A" t* l* }% }- p
7 c" _. t; r9 @1 t0 u
! Y, y( K; L0 K2 g' i 6 g8 X/ x Y8 Y) I" r4 K
# v6 B7 r" Q) P; N( D
; T" v0 M. g& W0 X7 N0 [% P ) R3 v& R/ O" }" Z& Q
2 h1 i3 b3 s* ?, n, L
5 |/ K0 b) @$ K" x
( \' s4 J( f+ k& s! y. Q! Q
8 ?! k) B2 ^: G' l- X& j- S& r
1 H( u5 O0 G1 ^8 b' U
3 P: e% n O9 Z; Z# i. F 9 H* }9 {! w1 ]
) t4 {: q2 |9 l- r
3 g' t1 B7 V! A 5 W$ t: {9 ?& L) a/ i7 w
% i9 C, k" b, l$ p! j ' Z% @5 T) d( @* L: e# i# g* D
$ b, F% L8 E! ?% T
' e3 h1 R, U% | I/ k$ P. j: ~: a
+ s1 X. s. O* F" F- i* A9 p 8 E6 Z5 G$ ]4 L9 }, G
: ]* _. l3 W. G' C O5 k
! F; i* m# g' u( a
$ `* W2 ^9 J# j) c( R. z
; c, _+ m: p" Q9 ?2 Y3 I W 8 Y7 L9 @4 ]! k
) H% Z! N/ b% B- }7 h# c g
* u2 [8 ] z) {0 C3 h
4 I$ Q# r5 f. a, E) k% \5 }+ E3 v 7 w& v* e9 r3 }4 c. P) V" Y* K
- P4 p7 {! t& f! x# c. S) \
. [" j$ W+ G0 V9 p4 {7 C! M
4 \; U& j/ h3 z- Y# k8 ?3 v) ]
角焊缝焊接定额标准 单位:h/m
; R3 A) ~3 ]. r2 }4 F序号 焊脚高度mm 焊肉重量kg/m 焊肉重量 系数 焊接定额T=h/m
- g6 k* I# Q8 l& J& D 电弧焊 气保焊 药芯焊 * [5 ?! u/ u: C$ E; c
1 5 0.098 0.7 0.16 0.125 0.117
# o. [- ~; b5 X9 x. S" e# d+ ~" D1 _2 6 0.14 1 0.21 0.167 0.167 ) `- X9 d& j( Q7 _; x$ O
3 8 0.25 3.571428571 0.31 0.25 0.298
* E5 i- t/ _4 F) H9 j4 9 0.32 4.857142857 0.4 0.32 0.382
' Q$ M# @% f# ]% C7 s+ R5 10 0.39 6.357142857 0.5 0.4 0.465
; w- R1 y% U& Y/ C% R6 11 0.47 8.571428571 0.58 0.46 0.56
7 f" M, J1 f8 e! }7 12 0.562 8.857142857 0.68 0.54 0.668
W- X; `3 F$ P; D& |& l) x1 H8 13 0.66 9.857142857 0.84 0.67 0.785
* E& t+ t+ S0 Z, n6 a9 14 0.77 11.5 0.98 0.78 0.917 0 l$ n" o, c) n2 N" s1 I0 m
10 15 0.88 12.85714286 1.11 0.89 1.05
' z& p- A( S4 S: d/ {" W& Y11 16 1 15.85714286 1.25 1 1.19
( m4 \, g' O0 P4 i4 Y7 I12 17 1.12 17.57142857 1.13 1.33 8 r, ~! o# \# a6 F9 u# b
13 18 1.26 18.07142857 1.25 1.5
4 G! M) I1 ]' f; N14 19 1.4 19 1.38 1.67
6 G4 L* z6 N% U6 M5 \15 20 1.56 19.57142857 1.5 1.98 * R: O" P" s% k
16 21 1.72 21.14285714 1.63 2.05
; ^9 C5 G& S( n17 22 1.88 22.28571429 1.75 2.23
( t9 K' w! G% V! S# Z+ h8 G- U0 V" v- \18 23 2.06 25.21428571 1.88 2.45
9 [: [4 w* w0 S+ X19 24 2.26 27.71428571 2 2.69 / o3 L/ O+ T7 D8 u( T5 E
20 25 2.42 17.28571429 2.88 ' Z# ]) C6 A0 k; I+ N! L7 k
21 26 2.62 18.71428571 3.12
- M- F3 v9 M) X# b22 27 2.88 20.57142857 3.43
* v4 K* p' x+ d8 D/ q* \( d23 28 3.05 21.78571429 3.63 ) ~) j9 e: _) w' y s3 n; c( V
24 29 3.27 23.35714286 3.89 . ]5 a' y: R# O5 E7 g
25 30 3.5 25 4.17
3 k2 \9 ~% A6 G: R% w说明 1.焊接位置系数:平焊1.0;横焊1.2;立焊1.4;仰焊1.8。 2.焊接难度系数:连续焊1.0;断续焊1.2;断续焊移位较多或焊接位置影响效率时1.44;环焊1.5;相贯线焊1.8。高度1600以上按【定额编制方法部分表5】增加系数。 3.均按不开破口计算。坡口定额见【焊前开坡口定额标准】。 4.特别说明:焊接定额各行业、各企业差异不大,起重机行业主要特点是:大型工件一般需集体施工;且焊接过程工件需要翻转,对此如考虑不周将造成定额失准。 5..各类系数可叠加计算。 * y* N" \# t+ C; J5 j% t
0 Y' y3 T" y; Y$ k# m/ t+ L
# H ?( h8 |; j- R . V# Z% @7 J0 l- T! m8 W: G' H+ M
- O4 C) A5 M: `/ J0 Y7 J3 d6 b7 Y
对接焊缝焊接定额标准 单位:h/m
8 N! w+ k/ l4 x9 P0 U序号 板厚t (mm) 电弧焊 气保焊 焊缝宽度 埋弧焊 焊缝宽度 焊接定额T=h/m , h, F6 D; x! @. v
电弧焊 气保焊 埋弧焊
7 Y% A# Z! B' |* m. h& I1 3 4-6 0.14 0.11 + t: _" @# e; F' Y. ]/ e1 u3 Z: \
2 4 4-7 0.16 0.125 3 C9 H* F9 W/ ~9 O @
3 5 4-8 0.21 0.167
$ n" S7 ^7 I+ X/ m/ j+ _4 6 4-10 0.25 0.2 0.30 7 I# N1 R( j6 S
5 8 6-14 10-20 0.3 0.24 0.36
* g4 M& W; F0 |' d7 v6 10 8-16 12-22 0.35 0.28 0.42 & t9 A# G! T& ^, B0 T
7 12 10-18 14-24 0.40 0.32 0.48 5 l d; y$ c7 H! S4 O
8 14 12-20 16-26 0.45 0.37 0.55
" k( Z- A) g8 z4 H, r! N& V9 16 14-22 18-28 0.50 0.41 0.61 . n9 ~! t# z$ i: ?( L& x
10 18 16-24 20-30 0.55 0.45 0.67 4 h5 T9 \0 N+ w* e" p+ A& r
11 20 18-26 22-32 0.60 0.49 0.74
1 m) c& B" [1 F$ _12 22 20-28 24-34 0.65 0.53 0.80 4 [# g3 W$ [* c9 ?, R6 I
13 24 22-30 26-36 0.70 0.58 0.87
0 t3 |& K1 @, x& g# \9 v14 25 " ?( Y# E' @8 l% y) L# U
15 28 24-32 28-38 0.83 0.66 0.99
6 _6 \- t4 s/ l/ ^16 30 26-34 30-40 0.88 0.70 1.05
" A2 Z! _3 _* P17 40 36-53 40-59 1.0 0.8 1.2
: d7 T: N I; v18 50 46-68 50-74 1.25 1 1.5 6 N9 h! ]* f! n2 f
说明 1.焊接位置系数:平焊1.0、横焊1.2;立焊1.4;仰焊1.8。 2.焊接难度系数:连续焊1.0;断续焊1.2;断续焊移位较多或焊接位置影响效率时1.4环焊1.5;高度1600以上按【定额编制方法部分表5】增加系数。 3.均按不开破口计算。坡口定额见【焊前开坡口定额标准】。 4.焊接定额各行业、各企业差异不大,起重机行业主要特点是:大型工件必须集体施工;且焊接过程工件需要翻转,对此如考虑不周将造成定额失准。 5.焊缝有超声波或X射线要求时工时系数1.2。 6.各类系数可叠加计算。
) ?1 E6 |' y, i! o. i 5 m% ?5 @. e6 X# S, X" O1 J) M
, U/ e/ c( n, T. q8 o , K$ K) j/ z9 p& A' M
+ `/ Z) h6 K7 H, c
6 e2 L7 y9 x: G/ Y : k8 o, b+ N: Z K3 ^6 |
