1.Perpendicularity is out of tolerance: drawing's requirement is Φ125±0.011, perpendicularity tolerance of the outer circle and end face is 0.03mm, fact measurement is 0.06mm., e4 P5 E9 [* _! Z* B- h
2. Parallelism is out of tolerance: the required parallelism between the bottom assemble datum plane and guide installiaton plane is 0.02mm, fact measurement is 0.05mm.
/ ]$ m4 ]& `9 ^6 H. n3. Straightness is out of tolerance: fact measurement of the guide's front edge is 0.26mm(Middle is concave)( W' n0 u. E8 d4 B( g# A2 @
4. Dimension is out of tolerance: drawing's requirement is Φ150+0.04, distance between the hole center and the bottom is required 145±0.03mm, fact measurement is 144.94mm.
2 t" _$ E; ?! @& K- ]' Z. ?5. There are two repair-welding on the assemble datum plane, protruding 0.03mm(15mm long and 5mm wide), see attached photo. |
