查看: 3007|回复: 0
基于autocad的齿轮参数化源程序
发表于 2011-5-25 11:34:51 | 显示全部楼层 |阅读模式
Imports System.Math
# C& [4 O# V1 f3 Z9 G1 j3 TPublic Class Form1& @3 g8 ~6 m: o# N! d" W8 g% h
    Dim AcadApp As AutoCAD.AcadApplication
; N- x- i8 d, e+ q    Dim 刀具 As Object
; M1 z$ s# c, C. t, V    Dim Da, D0, D1, D2, D3, D4, n1, B, C As Double
& y& p. M( Q7 e8 H) }* W    Dim Z, m, Af As Double! w3 o+ u7 U+ q% M' q4 B% V
    Const Pi = 3.141592
- K$ O( d: @" z. C    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load- C. T( N1 y/ F2 x5 O: b
        Me.Text = "齿轮结构参数化三维造型"9 w# u6 s9 B3 ~5 B/ O
        Me.GroupBox1.Text = ""& r" K' H! y0 e' D2 Z8 j& U
        Me.Label1.Text = "齿数Z"
7 `, N/ i$ K9 ?2 r4 i        Me.Label2.Text = "模数m"$ n5 H& n1 V  o" f8 G+ @6 _; ?/ m
        Me.Label3.Text = "压力角Af"
5 l2 p: Q' I/ d* v$ G        Me.Label4.Text = "轴径D4"& V! ]- h' X; ~
        Me.Label5.Text = "齿宽B"7 _+ I% f0 I- m! l
        Me.Label6.Text = "D0"
, L* l0 K/ h# H) V2 ~) h        Me.Label7.Text = "D3"9 m# e6 J* N+ Y! H: ?$ h8 |3 Q! j$ o
        Me.TextBox1.Text = 40: {% j" g6 i9 d! a$ C" Z8 q
        Me.TextBox2.Text = 6- I- p% \! S9 x% \' P( @
        Me.TextBox3.Text = 20
/ f6 G$ T+ o7 l, D. V        Me.TextBox4.Text = CInt(Val(Me.TextBox1.Text) * Val(Me.TextBox2.Text) * 0.3)
3 t* y" @7 _* m) t, [( m1 [2 i        D4 = Val(Me.TextBox4.Text)5 \9 C, ^9 s* F9 K, ^% w9 S) P
        Me.TextBox5.Text = CInt(1.2 * Val(Me.TextBox4.Text))/ y1 s# y4 Z3 m) b6 c
        Da = Val(Me.TextBox1.Text) * Val(Me.TextBox2.Text) + 2 * Val(Me.TextBox2.Text)  y  V  L5 t4 n
        Me.TextBox6.Text = Da - 12 * Val(Me.TextBox2.Text)3 ~0 _/ L: @( X
        Me.TextBox7.Text = 1.6 * D4
# U) H2 J3 Q8 C3 H, s( a2 x        Me.CheckBox1.Text = "画腹板孔"
: h' n# z8 M$ Y; [6 U        Me.CheckBox1.Checked = True
" [3 d5 r# v7 [/ e8 ?. V5 M$ d        Me.Button1.Text = "齿轮结构造型"; B; Q1 C/ J% U1 t: [
        Me.Button2.Text = "结束": H( r! M7 u9 x* h: D, p
    End Sub
! y% A% N) |" ^. I; n- ?& t+ r5 q    Sub 连接AutoCAD()
( ~- ]. T: `0 u& c        On Error Resume Next
& m, F/ P% r8 A1 i* z  Q        AcadApp = GetObject(, "AutoCAD.Application")
7 s4 g; X+ z  h' t9 h$ |        If Err.Number Then1 t+ S8 w5 K9 O
            Err.Clear()
/ O2 o2 z3 P/ t$ _1 }            AcadApp = CreateObject("AutoCAD.Application"); X/ M* `, u1 b9 Y  \& |
            If Err.Number Then
' x+ y2 h2 ^2 z                MsgBox("不能运行AutoCAD,请检查是否安装了AutoCAD")
& |' v) R7 V  f: ^. x8 C                Exit Sub8 _$ W8 {; h' b* ~0 W% L
            End If+ F! ^4 j! h( ]# X% T2 S5 L  g
        End If2 @% e! n# H1 C" X. O' B9 \8 ^
        AcadApp.Visible = True '界面可视
& G: i! `5 U+ O, U        AcadApp.WindowState = AutoCAD.AcWindowState.acMax '界面最大化
% Y% z( S- H) N        AppActivate(AcadApp.Caption) '显示AutoCAD界面
# M0 C2 Z& g: F. s+ [9 u4 ]6 q    End Sub
: j+ o8 K+ C5 }+ o. O# H    Sub 齿轮刀具()( @  }) [! E7 ]0 ]. E, o
        Dim R, Rf, Rb, Ra As Single
: ]2 }* k' D0 L  Y" j        R = m * Z / 2
  }0 t; o: d/ w6 X8 W7 H7 N        Rf = (R - 1.25 * m)+ }- j  e3 q6 M: W3 [7 o$ ~0 V
        Rb = R * Cos(Af)6 K3 L1 P  |7 |. q# ~8 h' Y! H
        Ra = R + m& t6 j1 e$ O0 l2 F
        Dim Sb, th(3)
4 Y) Z9 E# X+ Q  f% q8 G, t2 z        Sb = Cos(Af) * (3.14 * m / 2 + m * Z * (Tan(Af) - (Af)))
1 a0 Q/ r! @; p' P, j        th(1) = (3.14 * m * Cos(Af) - Sb) / (2 * Rb)3 [7 I4 d- V+ w3 q4 I2 V
        th(0) = th(1) / 31 ^6 L9 t3 ]5 q9 ]1 h" K7 S
        th(2) = th(1) + Tan(Af) - Af
, {+ K3 x& r9 J& d" a        th(3) = th(1) + Tan(Acos(Rb / Ra)) - Acos(Rb / Ra)
3 ^: ]/ p: }6 l1 G: C: b        Dim curves(5) As AutoCAD.AcadEntity
( q3 U) Q. {0 ?  m        Dim points0(5) As Double' B( ]- [* u$ U, ~, N! Q7 o
        Dim points1(8) As Double
$ c# Q. K5 H2 e7 |$ ?        Dim points2(5) As Double4 |; I$ W( O- M4 k" _2 G. d
        points0(0) = 0 : points0(1) = Rf
  L/ e* p2 {- Q0 O        points0(2) = Rf * Sin(th(0)) : points0(3) = Rf * Cos(th(0))& B% u& g  ^* h1 [3 k
        points0(4) = Rb * Sin(th(1)) : points0(5) = Rb * Cos(th(1))3 y! r. Q# r3 M# y: X
        Dim startTan(2) As Double1 `0 s2 m/ V" |& I- |2 Z6 g
        Dim endTan(2) As Double( Y# V6 E  N' L1 l7 H
        startTan(0) = 0 : startTan(1) = 0 : startTan(2) = 07 Q1 {! X  v9 x3 p% n) Q
        endTan(0) = 0.5 : endTan(1) = 0.5 : endTan(2) = 02 {$ d7 o1 k* q9 f* E/ W1 j- c
        points1(0) = points0(4) : points1(1) = points0(5) : points1(2) = 05 w* F0 V. q1 E+ V' N
        points1(3) = R * Sin(th(2)) : points1(4) = R * Cos(th(2)) : points1(5) = 0
& b4 K8 Q- T- l, r0 L2 m        points1(6) = Ra * Sin(th(3)) : points1(7) = Ra * Cos(th(3)) : points1(8) = 09 \( z* @4 u( E9 y1 [! C7 i# L4 [4 n
        points2(0) = points1(6) : points2(1) = points1(7)5 w  e3 d+ O, O5 B9 k9 y: A
        points2(2) = points1(6) : points2(3) = points1(7) + 2.25 * m& ?# M8 d, u4 p9 ?  T6 Q0 J
        points2(4) = 0 : points2(5) = points2(3)
8 g8 p, C& B6 q0 d, |4 u        If Rb < Rf Then) g4 e( z' ?1 X& E+ l- E
            points0(2) = points1(3) * 0.2 : points0(3) = points0(1) + 0.25 * m * 0.03
6 [$ k# q7 z1 V9 U3 a. E            points0(4) = points1(3) * 0.7 : points0(5) = points0(1) + 0.25 * m * 0.8& t- X) F- Z5 b+ j6 O
            points1(0) = points0(4) : points1(1) = points0(5) : points1(2) = 09 I2 ?% e+ L  D+ u- I
        End If
5 k% K- z! R& o6 o/ B        curves(0) = AcadApp.ActiveDocument.ModelSpace.AddLightWeightPolyline(points0)' n( f' P; I1 y
        curves(0).SetBulge(1, 0.2)
3 }# ?0 d: i9 B1 I# l) \+ W        curves(1) = AcadApp.ActiveDocument.ModelSpace.AddSpline(points1, startTan, endTan)! r" r0 |2 Q+ D
        curves(2) = AcadApp.ActiveDocument.ModelSpace.AddLightWeightPolyline(points2)
2 p' `. ?& H5 G        Dim point1(2) As Double
# {$ M8 f9 S+ E1 `$ _! J& i* I        Dim point2(2) As Double
7 C5 q, r7 n+ v4 E0 G        point1(0) = 0 : point1(1) = 0 : point1(2) = 06 k; j+ B- b& w6 M' R
        point2(0) = 0 : point2(1) = 1 : point2(2) = 0
) J7 f8 I5 z0 F- S5 d' C! ~+ d7 @        curves(3) = curves(2).Mirror(point1, point2)" X4 C" \1 r2 }; K# ~5 _& w5 {7 Q' ^
        curves(4) = curves(1).Mirror(point1, point2)
+ u3 s3 z3 C2 W, s        curves(5) = curves(0).Mirror(point1, point2)
5 x+ O, }, c0 V9 C0 [  A        刀具 = AcadApp.ActiveDocument.ModelSpace.AddRegion(curves). C5 @; d2 z" s6 O" b8 g' N4 c. v4 U
        Dim taperAngle As Double
8 Y) D' T- \5 Q7 m  A        taperAngle = 08 N1 v& ^6 _3 D! l5 |
        Dim solidObj As AutoCAD.Acad3DSolid9 _0 R! b+ q& j2 H8 N; v
        solidObj = AcadApp.ActiveDocument.ModelSpace.AddExtrudedSolid(刀具(0), B * 1.1, taperAngle)
; W3 b3 Q* L( R+ q* f8 A7 z. ~        Dim center(2) As Double% K7 N3 |+ ?9 i
        center(0) = 0 : center(1) = solidObj.Centroid(1) : center(2) = 0
: [) V7 k' g4 C! J  ^$ Q        solidObj.Move(solidObj.Centroid, center)% {- I3 m. `+ R% F4 d+ a4 O
        Dim basePnt(2) As Double
4 Q  c+ z$ Z+ T' P5 M; v7 z        basePnt(0) = 0 : basePnt(1) = 0 : basePnt(2) = 0.0#
. t" ^0 _9 F- \# Z: x        刀具 = solidObj.ArrayPolar(Z + 1, 2 * Pi, basePnt)' H# Z- y' p. b; H# G, P- r" `
    End Sub
/ _. v$ y3 {) Z; t( V1 i; ^    Private Sub TextBox1_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TextBox1.TextChanged, TextBox2.TextChanged
+ x4 |7 q) \; ^$ P" U% l1 S" p        Me.TextBox4.Text = CInt(Val(Me.TextBox1.Text) * Val(Me.TextBox2.Text) * 0.3)
  _- ]0 y* B5 _8 @  x        D4 = Val(Me.TextBox4.Text)
: o# C: X7 z+ X5 L! U; i0 f7 g7 P        Me.TextBox5.Text = CInt(1.2 * Val(Me.TextBox4.Text))1 F" G% V3 I8 k, M
        Da = Val(Me.TextBox1.Text) * Val(Me.TextBox2.Text) + 2 * Val(Me.TextBox2.Text)4 c6 D2 k# a) N
        Me.TextBox6.Text = Da - 12 * Val(Me.TextBox2.Text), @8 X* `4 Y3 C/ N6 T3 M
( N1 A5 }; P9 C1 d6 p6 K, C0 `+ G    End Sub
) }8 Y$ h$ m& N8 K; A, [4 t+ N* e    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click* o0 b7 I" P- |& U
        Call 连接AutoCAD(): Q3 O1 a! h) |' ~) F+ j6 N) H
        Dim entry As AutoCAD.AcadEntity" N- q( B( J$ A' ~& Q6 y2 u) ^* k& E
        For Each entry In AcadApp.ActiveDocument.ModelSpace" r& E3 M  T/ L$ z
            entry.Delete()9 A7 l8 C0 f- A( k9 o0 j
' i" m7 B0 B! ^" q  B& h: g8 K
GMT+8, 2025-4-30 18:58 , Processed in 0.057931 second(s), 15 queries , Gzip On.
