一个以前编写的智能铣平面程序,感兴趣的朋友可以分析下算法
; m; Z- S* f7 w) [0 O/ g. H: ]* n; q%0 X* P1 N7 z- s4 g* t
:30
" R$ M" O, S8 q6 d7 f4 \" q/ J#100=54 (*加工坐标号*)* M2 Q2 c' r4 U3 T
#101=1 (*刀具编号*)
! U# `1 z* Y: F; M4 }% L& A5 A#102=2000(*刀具转速*)
8 G8 @. X0 o; l. c# D#21=500 (*进给量*)6 G. O% G. V% g3 b
#1=0 (*下刀点*)
' Y8 z3 P: {! r/ T) n/ D, F#2=0.1 (*每层切深*)7 x: L9 Y, Y Q; M9 o0 f
#3=0.3 (*加工深度*)
. x* M, r. T& h# }, Q2 B! h#4=400 (*板宽*)
5 U7 f( Y) |/ V0 Q, _1 u: h#5=500 (*板长*)( ?, n" T! Q. Q. Y
#30=100 (*刀直径*)$ ^; {4 }5 w4 ^; b2 E
M98 P1902 x+ N! ?- e% O+ o7 T
M98 P8119, C: ^- C: V# W$ j+ v, w# [
M30
9 k7 P( }7 u& {:190: m" P }+ A: I; K: N) f
#100=FI[#100]0 e8 w/ b2 e( z! y. G4 j% A
#101=FI[#101]5 A( a8 `1 ^# j E5 s
G80 M5
' S' A8 Q# M6 M4 O0 c. z M9$ m& a' @1 K3 Y% q
G69% ~( r1 T8 ?! i4 r. H9 Z( Q
G52 X0 Y0 Z0
# T/ m" u( R: ~ G91 G28 Z0
/ ^; M/ O0 H, r% x) N# a7 L G90 G0 G#100 X0 Y0$ D5 S+ w. O1 s8 Y+ s
G43 H#101 Z100.0
' d( M5 @; z: T. Q9 D M3 S#102
3 D- s7 v' ^. O M99
% E- A; i/ {/ [; c1 j; v- a:81192 D2 A2 }0 F' t5 F o
IF[#4111 EQ 0]GO 3001' l2 W6 @' s& p3 J4 H2 X
IF[#4003 NE 90]GO 3002
; w/ L }9 v: B* l #6=10.! \# j- Z) [: ^- @! a( @
#7=10.
+ a) E0 u. M, P# F0 D #8=#5+#7*2
# ^9 ^, M5 m9 R( q. c IF[#8-#30 LE 0]GO3002# N: X, u; b' r5 y" U4 Y
#9=FI[[#8-#30]/#30]+1
& S- F! Q s- @) c0 R- P0 R #10=#1+#2# }. `- B. A! f/ h. R$ p
#11=[#8-#30]/#9
/ @- m$ j* q0 t, B+ x, q7 D: U: q IF[#10 GT #3]GO 3002& Q( J7 B) i2 H# p
#14=[#4+#30]/2+#6
/ d) b8 Z3 m/ c) ?' w$ W9 L #15=[#5-#30]/2+#7 D( N+ l% [1 i) N# |4 k
G0 X-#14 Y-#15
& Q: x2 Y1 ]' S# p3 d8 Q. K+ a7 a& D G1 Z-[#10-#2] F1000- P5 o. T* L9 Q7 b/ L! s
#12=0.
9 O: F* o1 r/ `7 D #13=1.3 }/ w0 a1 l# Z9 T- s2 W
WH[#10 LE #3]DO 1+ I4 e, c" Q7 a+ g+ G+ Z
G1 Z-#10 F#21
$ K9 R' t* |( z0 h& T #17=#9*[#13 AN 1]
3 n. O2 Y( f3 B( q #18=[#13 AN 1]*2-15 h" v/ I. @8 Y
WH[#12 NE #17+#18]DO 25 U. M5 l0 {2 b+ i9 c I. }
#16=1-[#12 AN 1]*2
( I2 _& R# c: v6 A9 N9 s) h #16=#16*[#13 AN 1]-#16*[1-[#13 AN 1]]) ]3 P4 s; g g$ N D; r
G1 X[#14*#16] Y[-#15+#12*#11] F#21* ]/ x5 i' G4 d. V0 s
IF[#12 EQ #17]GO 1
2 K- K+ ~! ~& X: E* k" F2 k4 L* M; A G1 Y[-#15+[#12+#18]*#11]$ D {" n% K5 J9 J. `
N1
0 ~3 ?! z' B6 ~4 p8 X1 g #12=#12+#185 A; l6 A% j9 ?7 V: f
EN 22 R. D% d: d- [5 {; y
IF[#10 GE #3]GO 3
3 O$ ^- @/ u( L( z t4 ? #10=#10+#2) v! B! C# N& d' j! _6 J
IF[#10 LE #3]GO 2
4 ^% z& b. v5 e V) x ?. d* J #10=#3' A9 F! X/ K' |
N2" s. ?+ ~9 q3 U0 ~
#13=#13+1
' L+ K3 Z3 O$ H2 W3 @ #12=#9*[1-[#13 AN 1]]
]4 }% Z0 n$ F1 { EN 1
; E. a* T) S6 A; SN3
% i c" e' \! T M5
! U/ ~$ z- M- | M99 |2 j2 J& w' k8 K* w6 i
G91 G28 G0 Z0
1 x, |8 f: v B. h G91 G28 G0 Y0
* R' ~, q$ g+ V! a) G! \; E M99, i- t$ W9 U1 N+ u6 F; w
N3001- @' u1 l# z* x
#3000=1 (NOT TOOL LENGTH)
8 G. S0 M7 k4 O6 m, B* VN3002
$ Y' ?& \- O! f" R4 C- z #3000=2 (DATA ERROR)5 ~& O- C2 j) H& v8 J( h3 X, S
& Q. a! _( Z; F7 D$ V
3 ~7 r3 V0 ^$ ]/ v' d本程序由有<<宏疯子>>之称的龙记模架公司第一宏高手编写!!!!!7 B1 Z$ d1 A+ [' Q* i5 E* ~1 c) O
+ N' Q4 J- ~1 e
