查看: 2762|回复: 3
如何这么多点生成曲线,每次再偏移40同时再旋转5度生成曲面
发表于 2011-4-13 16:11:09 | 显示全部楼层 |阅读模式
Ⅵ
! |% t; F" `/ Q4 {
! S7 o! P& X8 t, y9 y1 r        ) c5 j/ i9 y6 B; I3 @5 b
/ R* N, ]+ J2 n5 n) w# J
" G5 C8 x1 P5 n1 u
; {$ O, _; D/ a( ?' qRa        Xa        Ya0 G1 [# ^3 W' _) R  o. c
1.001        0.488         2.060
% }: V* g) W4 v4 v. b        0.000         1.046 ' @- p% y; @3 \' u" E$ j
        0.832         0.205
6 B4 u8 C7 w" XX        Y1        Y2( k9 s! A) k' \4 E3 j7 t
1.254         2.464         0.144 & ]3 _% P: |3 a6 ~
2.514         3.025         0.022
0 q, x/ v6 H8 T7 [% @  ]3.768         3.497         0.000
/ }, }& j6 y8 b5.027         3.919         0.067
  C1 t+ R) ~4 t* e& u# I4 {6.281         4.302         0.174
+ J" E/ m# Y! p5 g; d1 _7.558         4.662         0.301 8 {- p: D* C' D7 D7 F8 j
8.812         4.999         0.442
6 [8 ~. T7 o/ N! O8 m10.071         5.325         0.596
: G4 r' }  m  n* u11.325         5.640         0.757
1 M7 k9 J! j( J- C6 m12.585         5.938         0.933
. u- X" S  e, Y, o20.120         7.619         2.041
5 s: L2 K9 E& Q; S+ o3 e27.677         9.110         3.127
! ]) r8 A/ }6 [% G/ a35.235         10.369         4.088 % V; D3 \9 Z7 X0 C6 m8 k  w3 {
42.770         11.370         4.898 7 G& b$ f8 Z1 Z
50.328         12.112         5.578 ( Y% f  t: l1 u" M
57.863         12.602         6.045 8 Q2 v  w$ R! e; a0 Q. G( P  e( O
65.426         12.815         6.343
  g0 Q6 B+ D, m3 Z72.961         12.753         6.450
9 h9 K; s  v' N" v8 c7 |' t1 p80.519         12.433         6.388
3 N# {, R. J4 P$ a8 t& H88.054         11.966         6.219
- x0 Z+ @- e: }( v: e95.612         11.325         5.938
' B. Y* W# G) J& k& E5 [& R103.147         10.538         5.533
4 l- e0 Q: t1 Q1 `; b110.704         9.604         5.027 % c4 u- v# \$ [" j) |
118.245         8.581         4.454 3 T* R# C9 I8 }. A. i' S3 E/ N) x( M
125.803         7.451         3.768 4 Y7 J# P- y8 p% N+ a1 U' Q/ ~
133.360         6.259         3.042
5 Z1 z. p0 b5 g9 e140.895         5.005         2.277
" S% L. S4 a; I1 Y1 e148.453         3.661         1.423
0 X; i$ E- ~( o! `# L: y7 ^1 X155.988         2.300         0.534
  g/ F9 l7 l/ c# f
1 v; y+ b0 K' J) {3 u' Q6 f/ ~                5 h3 c1 @3 @6 l' ?( C. Z/ N
$ y4 T% e% @# N$ F; E1 J0 V
$ q$ T. y2 b8 O' o- b1 G4 d
* {7 R: i1 x% [; g: A# V& \  m0 c2 p
7 O- P8 j# W) w" P; |! d+ O9 oRb        Xb        Yb/ I$ Q. e& l" C9 E) M  Y  {
0.748        160.500         1.485 . l1 F1 H+ C2 b8 l7 N, s7 O. H4 j
        160.374         0.000 ( y5 P3 V9 q6 r' c; v. K
        160.274         0.007   e( e. c9 N0 ~5 [; k# U! Z7 Y8 o
发表于 2011-5-9 11:43:36 | 显示全部楼层
你所说的每次便宜40是什么意思,是什么方向吗?不太明白。
 楼主| 发表于 2011-5-13 21:41:58 | 显示全部楼层
就是所有坐标点在下一个平面上去建立,两个面之间40mm
发表于 2011-6-27 14:03:00 | 显示全部楼层
选择“曲面”——freestyle——3D Curve命令,就可以了。至于后一个,楼主可以尝试使用阵列的命令。
GMT+8, 2025-4-6 22:38 , Processed in 0.058615 second(s), 14 queries , Gzip On.
