查看: 18313|回复: 33
看一则美国机械工程师招聘广告
发表于 2011-4-2 08:41:53 | 显示全部楼层 |阅读模式
不论英语,看看其它方面我们有无差距,能否胜任% E% I8 ~2 E7 _  P
$ \" O' K7 `/ h$ q2 I( Q9 n& U$ v
Mechanical Engineer, MTS-IV , W; Q/ K! {; S5 N; y: l0 H
Primary Responsibilities:
# c" S. Q* }3 f1 N; hPosition requires a senior mechanical design engineer who is experienced in the design and packaging of ruggedized embedded computer systems for military and aerospace applications.   The candidate will be responsible for the design, documentation and production support of electro-mechanical components and systems per specific customer requirements.  Within Aitech’s small company environment, the senior mechanical engineer’s role is a combination of leadership, mentoring, and hands on performance of the mechanical engineering tasks.  3D solid modeling techniques using Autodesk Inventor? and proficiency using AutoCAD? is required.  Knowledge of material properties and finishes applicable to the design of electronic packaging components is a must.  * q0 i" W& B' }- }0 b
0 [$ s8 f6 R4 [$ X9 a% n* qStrong knowledge of ASME Y14.100 and ASME Y14.5M-1994 practices / n! w1 S/ G9 C8 L$ u: h! c$ C
Working knowledge of the creation and control of Technical Data Packages (TDPs) per DOD-D-1000 and MIL-STD-100 " ^, y/ k2 ~) y
Working knowledge of military, ANSI/ASME and IPC specifications ! _* n% K! G$ Y- o! s0 ]% ~8 [
Direct experience in the design, analysis, and qualification testing of electronic packaging in avionics applications
# V. d, |4 b3 I  l& P; {Direct experience in the specification and control of Printed Wiring Board artwork process and fabrication required
* Y; h2 ~, ]; X( @* d6 r) M4 F( wPrepare and present customer presentations, and participate in face to face customer discussions and negotiations regarding complex technologies
8 T8 f5 ^9 F8 d- j$ pDevelop technical solutions derived from technology building blocks
6 z: o3 K1 T( p; q$ gLead special Research & Development project activities or investigations within the Mechanical Engineering discipline.
% L. R+ |* I4 qWorking knowledge of Document Control and Configuration Management procedures
+ y/ p/ V8 y' I9 EWorking knowledge of sheet metal and machine shop practices is a plus 0 e: k4 @- w, ~: S7 F" m: `+ v
Manage technical sub-contracts & |8 C$ t0 W+ |0 M6 A
Strong communication skills
2 A% K- f8 j- o8 F3 WIndependent worker who can operate in a small company environment % s4 N" H  ~4 Z0 W7 ]* j
Use project scheduling tools to estimate the total cost of a development program , P! ?6 e9 O/ P; e& ]
Coordinate activities of engineers within the Engineering Department and/or across Aitech programs and projects
9 n9 G  k# Q+ E  b. ?* }- r6 _Manage and prioritize multiple simultaneous activities " X: Y* ~2 s& A4 `; E: C+ ]
Successful candidate will have and be proficient with Microsoft Office tools 7 `* d3 W& \. X. E$ b) M
) K4 j1 `  @8 l; b& n9 IRecommended Experience:! y/ U! V  K! i9 [
Minimum10 years experience with military programs8 F' R8 W. T5 L- \$ @4 C/ P
6 d$ H) Q: p* b) _! t& l4 XRecommended Education:6 _2 [! R% s/ b  _
BS ME (and/or equivalent experience) with MS desired
' c! F2 c/ _1 f2 i9 F: I8 z3 {
3 h. j  t6 j2 q2 L0 w" Y  }* T* H) oSpecial Requirements:
" h4 V# r  Q. R0 z% i! A) ?! jPosition requires an engineer with a diverse background in the mechanical packaging of electronic circuitry for the development of embedded computer systems.
发表于 2011-4-2 08:46:46 | 显示全部楼层
这个是做军工的,我们没这个机会接触到
 楼主| 发表于 2011-4-2 09:04:48 | 显示全部楼层
只是民营小公司而已,国内同类公司很多
发表于 2011-4-2 09:41:19 | 显示全部楼层
牛.进来学学英语.
发表于 2011-4-2 10:13:09 | 显示全部楼层
看不懂
发表于 2011-4-2 10:13:45 | 显示全部楼层
在米国作工程师其实不容易的,尤其作机械工程师,很不容易,
. }8 p' J0 B# _! V# P米国不象我们,有严格的专业区分,我们国家,玩冶金的绝不玩其它设备,玩化工的,也不玩冶金,这是当年斯大林同志制定的,大家不可以乱串,因为叛逃的后果对社会主义是致命的,
8 O6 v1 ]7 Z, @- f
1 Y0 e$ e9 Q: G0 R8 i( z7 O米国的家伙就什么都玩,20年前,俺四周格子里的家伙,你一问,玩什么的都有,以前玩船的,玩飞机的,玩采矿的,五花八门,但都一个特点,来了,放下手提箱,脱了外套就干活,没有说什么适应半年的,
5 E! Z' S6 O7 ]4 A, u5 ^6 k, d! E4 F0 l7 `7 q9 c& [
中国的家伙,你20岁毕业,要特拼命的玩,到30岁之前,有可能赶上世界的平均水平,与他们平等,但可叹了,大家的时间都白混过去了,
' j  F& y1 P/ q# s9 g) p说点不客气的话,我们工程师的水平比人家普遍要低,视野窄,计算技能差,不适应变化的环境,
发表于 2011-4-2 12:20:08 | 显示全部楼层
这家伙,国外的机械工程师 又要会电路,还要会嵌入式系统,还有其他要求、、、这个要求比国内确实高得多啊~~~
- {. |6 s3 R) h: {0 |9 N                       路漫漫而修远兮啊。。。
国内高手还是有的  发表于 2011-4-7 13:09
这么多要求?》??大哥他们招的都是定向培养的吧??? 是不是一个专业专门开了这些啊???  发表于 2011-4-6 19:48
估计招的精英中的精英,如国内留学人才。  发表于 2011-4-2 21:20
明白多些总是有好处  发表于 2011-4-2 20:41
不是吧?  发表于 2011-4-2 12:34
发表于 2011-4-2 12:21:39 | 显示全部楼层
这样的工程师得多少薪水啊
 楼主| 发表于 2011-4-2 13:35:18 | 显示全部楼层
回复 tracyrichard 的帖子2 n* G) d! _1 \4 h+ l4 w* p
9 c2 o+ x% T& [5 b! Z7 V
不是的,这些属于了解性质的,学习一下大学电子信息工程专业的课本就行了% y7 F4 E. [4 P0 w* [
在电子行业工作,当然这方面知识懂的越多越好,才有利于与内部及客户交流) |: s/ E& Q1 V( X% l9 k+ E0 T. j
估计在美国这个职位也就十来万美金,在国内拿相应人民币
9 J) f' e% E6 Z1 e
总有个层次啊,有的要精通,有些要熟悉,有些知识了解就可以了  发表于 2011-4-7 13:08
了解有个屁用,就像穿起龙袍当太子,时间一长,没人会把你当成真太子,除非脑子有问题。  发表于 2011-4-2 21:17
发表于 2011-4-2 14:33:16 | 显示全部楼层
羡慕的同时努力学习,不需要非要超敢哪一个,活到老学到老这样才踏实
GMT+8, 2024-11-24 11:57 , Processed in 0.052840 second(s), 16 queries , Gzip On.
