楼主: fan782830040
请教:清洁度
发表于 2011-3-28 21:05:56 | 显示全部楼层
10毫克是指表面杂质的总质量,杂质的最大颗粒直径是100um。
发表于 2011-3-28 21:35:43 | 显示全部楼层
学习了!!!!!!!~
发表于 2011-3-30 12:01:09 | 显示全部楼层
这是我们的试验方法及要求,看对你有帮助吗?
+ ]% i/ Q# B9 L" i1 X: ~7 W: VTo determine cleanliness of fittings by passing fluid thru passageways that deposit particles onto 5 micron (0.005mm) filter paper. The filters are placed in oven at 100 degrees centigrade for 60 minutes, removed from oven and weighed, then Acetone is sprayed thru fittings passageways onto filters where particles are collected. Next, the filters are placed in oven for 60 minutes, then removed from oven and examined under microscope for particles that are measured for length and weight, with finally recording results on data sheet. Only the largest particle located on each filter is measured and recorded. One samples from one part number presented below were used for testing purposes.
fan782830040 + 1 希望有中文的啊!英文也可以。谢谢
发表于 2011-3-30 12:15:45 | 显示全部楼层
呵呵,,,学习了,,,刚开始还真看不懂
发表于 2011-3-31 22:38:56 | 显示全部楼层
我看成光洁度了,哈哈...又学习了
GMT+8, 2025-2-22 01:38 , Processed in 0.054384 second(s), 16 queries , Gzip On.
