. { L: x* R, e6 e/ [, l
* j8 k! F/ @4 [$ G2 `
0 F4 R3 D1 ]9 P: t% ?& B) [ 钢 号 |
$ ~. ]& u3 w3 Q$ o+ D: A1 ^6 @6 ^
6 J0 r2 i% J) {8 z+ c! ?+ Z 临 界 点(℃) | 4 |* m1 g1 P/ S7 Q$ d/ D$ m) B( T5 I
3 ?/ p; \+ a4 [; q, ^# } 退 火 |
3 s: o! n2 b! V& ~. ~: @9 @/ a* C, }4 e; J8 G
正 火 |
; J9 G8 r/ X F1 c' Y5 t4 |! d: U
6 v/ H; G( i- L9 d; C) r% J9 M
Ac1 |
3 ?) y7 f/ A. D L- `; u$ t* F* l' `4 {1 e7 |! t0 x [# R
Ac3 |
* ]' g5 s# W" _/ }9 A' m8 V4 ^" M/ Z7 q) m Y$ o
Ar1 |
) S( O% [1 O, {) K7 H/ P1 e3 C, q ]* I' a4 G
加热温度(℃) |
3 a: T5 v6 J! G! V( @: a1 \+ S( c0 K, ^, s! ~: m
冷却 |
0 [& S, u( `) M8 p: N
0 h" X0 [. w/ T5 h HB | $ y4 n& o% J: l" o* O
4 d/ d: \) M+ o- e- e1 T% I7 x2 {
加热温 度(℃) |
$ r" r7 P& B4 f6 B1 k; [; M- c8 h+ i6 S; p5 f+ R
HB |
# p- V/ A$ z) g9 W; l: z. z/ m; M
. ?- I, x" ^' j: t
6 p2 V# a" N3 j 35 |
# E& q2 p F9 d* y9 y! F K. c5 }6 J' @
724 | * H. ]! H y0 o T- l
5 Y2 ^( Q+ ^& w4 q& `% I) m 802 |
4 [$ o, s3 ^. V [- h8 p
9 e' @# K) ` {# X: l& x 680 | 6 G, F0 {& }- G6 N; j6 f2 K* B3 w
8 K7 ]: ]! p5 i' u5 p) }" v! _ 850~880 | 7 N- o0 g; ?) j& @
0 ^5 m$ a/ \% q 炉冷 |
5 F. Q G' R' p' U3 I) D1 n
* V& ^6 A- X w1 t- } t/ a ≤187 | " p8 M) W6 E6 L3 S! a
4 s" F6 `. W) d" j' ]
860~890 |
x2 V, [, N( b& X% N7 {9 r+ Z3 `( L" u% t3 Y$ P4 Z( K% O
≤191 |
# n' P( A2 m) P2 X7 f) f; A6 f( g& e( W' l
! A9 G+ m) }6 h$ ?4 I$ ?9 C
45 | 7 | I# G6 g% t; A4 t2 i: L
" h0 \# ^; K2 w/ G3 Z7 r h. i# } 724 | - \' V$ W9 ?' C6 o8 D2 Q
, [6 [) ~; }# @8 u& W4 e- V- L* t 780 |
* e+ Z, `% ?- @6 l) W3 a1 z8 D( \/ L7 h
682 |
' O0 _7 h6 ~4 A! L
; v* J6 `! h8 Z3 O 800~840 | 8 }1 t5 S% y R, C2 ^! h
0 F' u; f$ L8 J& v
炉冷 | , _% X& {2 K% y+ l( p# ?
# p% {! Z# M/ K. F
≤197 | ! |. W( X- H2 X$ s1 H
. n+ ?* ]+ {- X# H5 }2 a
840~870 | % |3 D3 `- U" S( s
/ k: |8 h' x6 ^4 X7 [7 t d. r: M
≤226 |
t5 Q/ i9 T5 j5 C% y0 h% u
2 X) ] p, a* w( N# e' B; A0 d
+ c! X* j& [2 I 45Mn2 |
# g: l( l. |: f( C7 W: I! S3 H; W5 s3 ] T8 i6 k( k* f
715 | " O% W) N( t, n, ]2 p! ~8 `5 R1 S
) W2 B6 E: t9 H4 t' R4 h- ~! x
770 | 6 l& C; R# L r8 X; J# ^
# u. L2 I( B$ \
640 |
5 R' D( f3 s. W- {. T9 d9 p: u) B/ E" g- D
810~840 | # i& k* j7 D* Q7 I: } C5 b `
; R O5 F) @( ?% `" t: p! G* f5 h 炉冷 |
! a V. W! C3 d) e/ E9 b( H3 G1 K4 Z' l! S' }
≤217 |
) ]% b! K: |2 Z. i2 v& p3 v6 V' j' K9 s& P" `/ K6 m: b. y
820~860 | " E J g5 B) A: y5 k- S j
- q$ {# ?$ S; q0 H* i 187~241 |
! G: M% ^: n. Z* a% ?8 w/ g, h7 a
+ [& m2 o3 K9 N/ y
40Cr | ' ]2 F2 z: t( ~5 t8 M; k
* h! r8 j. _& k& j2 n8 ~6 g
743 |
7 C( r" `# g9 |; S% H% I( n" K" ]! f8 z/ G6 N$ C& ?& {
782 | 3 _0 k$ h9 }) ]& Y8 S
- x# T7 `. s9 ?. u
693 | + c7 p& d: p' K* ]; j0 {
5 j5 n7 \# g4 N+ X: R7 Z 830~850 | 6 P3 Q) D9 e! T0 L5 |
1 W6 e$ J- o9 I, i9 [- c3 `) K. w) t 炉冷 |
! @+ a; V! i. A3 V% l% A1 i0 p+ b; F; z+ l. j, S' u; B
≤207 |
" Y; ?4 Y' Z% Y$ R. M4 l+ J- E' R! |3 u0 C) }
850~870 | - M0 B) {% u( F ?7 _( ^( |# j
: y# \# C/ u: n- F8 W T" ^4 _, b ≤250 |
6 C( q- l9 k3 ]4 ?7 j4 ~. d5 U* c
) g% s6 s! U! G7 y, x! a1 [8 X0 n5 p h' ?
35CrMo | 3 |1 @. d% |' T9 G* u x, r( L
" o0 @4 @) G% v, k* E9 t 755 |
% l! _2 A! l0 K& {) y: G1 G( D0 L$ s& u$ C
800 |
6 j! c! l5 t! U1 N: {$ L. X" M; d3 H) ]9 C! H0 }; i ^
695 | & b( m3 j9 E' U3 l7 G
9 `+ c* t2 h( v& ?+ g# J2 Q
830~850 |
/ d2 W& B- y6 a( G0 {3 ^, J
$ j' P1 w1 A% ?+ P1 o* i# ?" {/ v8 ? 炉冷 |
% M' E$ I: c/ ?9 \9 x9 n
3 ?1 `& z; m5 D' d+ T# T; y9 S* q ≤229 | " H2 g6 S; v) Q
' K& L: A' ~9 ?4 K2 B% A
850~870 | 0 I9 v, V |0 Y" @: q8 M$ e! I0 L
9 z; p& O8 t1 W" ]
≤241 |
v5 t1 Q! C$ b/ ^2 P& p
0 J2 _8 ?" x; d2 E. I0 p' {+ A7 T5 `7 S4 }
40MnB |
) q( V$ @* d- R" F( t: J
* d6 _: Q9 s8 a0 ^, h2 C4 c$ d2 h 730 |
! Q# W9 i" R0 m& L* y" f% F' F' B3 V3 v9 }3 s3 F) g, B M$ x
780 | " D4 g- G* N1 H, p0 S
0 G8 G9 ^) K: X a
650 |
1 j1 H9 f- v/ r" k# o4 v6 B7 J. q4 f# D, x) O
820~860 | ) C7 T3 {4 j8 e( b7 Y* e% T
+ ? r! d# X! _" @
炉冷 | 8 E2 a" L& E1 g: ?% D( o
, D7 Q$ \" Z& I- h) B
≤207 | 5 ?) ]; h' \2 m# F' R! e
, \; {/ s6 i! {
850~900 | # o$ ~' x) m3 X* w
, B* @+ d* @8 Q8 r; V
197~207 |
5 t" T1 t* W2 N$ {, z2 r
* y: L% |7 V& X1 R9 h: Q
?# g3 { F+ l( Y% L 40CrNi |
5 I6 K3 n8 B8 C% k; N4 l8 ]) C5 Y- V5 u+ c, I* W/ ^
731 |
* y! ?' ?# s" t! Z5 ^5 j7 i2 Q" C3 t E- D/ H
769 | ! q3 C% i3 k8 {5 q% `1 M
/ G6 ]" |4 F# e 660 | ) M: B I$ m; l% N v
( ]7 f* d0 U% m: A- M7 E' ^ 820~850 | 9 k; e" [4 J$ H
# P3 s+ r5 e& O3 k' p) P) Q 炉冷<600℃ | ) |# N9 N. L0 ~+ G8 m
* C& C0 S6 Y! n5 k
- | 9 I7 C# ?7 p" |$ U' |6 r
3 M7 ?0 o( N- F
870~900 | * y9 A5 @9 ~0 N5 j7 i( p4 t
: F" h6 m, K. H7 R! e ≤250 |
+ q- k+ f. T1 h+ t u
: E4 X l9 G2 `0 [# }
6 n9 @# J. w6 T) D* R 40CrNiMoA |
- x3 x. E: {, B$ v/ n8 {: s. S( Y6 h
732 | , f$ \$ ]: P3 ]: }: |
4 t* N0 `+ c R# q6 _
774 | * W) Z1 L q6 l% r3 D
$ P/ h* G) r& s* f# M4 u
- | & P% x1 ^0 O( e- t$ `8 f+ \
2 N1 s$ w6 [+ `, }. I2 F4 o, J; o 840~880 |
9 R- a) m5 V6 P7 p7 C0 R) E6 ~- {' I6 b4 }, M5 a
炉冷 | ( d @0 C |+ h$ K) T- D) e
6 W1 W& d6 x, u+ \0 M& L ≤229 |
, E1 i& t- d1 s* V; w' u# Z# F
6 d; D1 v$ q* _# F 890~920 |
: C7 F; {1 `; S* e3 m7 T5 {. T
& x1 }" a. i8 P" w - |
$ N1 c% A9 d# z( l- h
$ u, v9 e1 o0 Q6 s& D4 R6 t V: u1 k. x" A4 L
65Mn |
) L) R) W8 Y; I2 h! [) L0 x8 d8 [" O5 Y/ a- u
726 |
. `+ a/ n* t9 Z; H# _9 O/ k+ Z& s& M3 |1 U2 L' z
765 | 3 b. [6 A, A/ \% m0 p Z; @
1 ~) d% K1 |9 x0 P6 @) C3 r
689 |
q P6 b: \! I
0 ^* B$ d- V3 ]% o 780~840 |
- H0 R* d1 P0 W: X8 n1 r+ V
! u& X# h: {$ q2 a5 U 炉冷 | 8 W' s3 i, `3 t7 ~& d1 Z; h
, H* o: P6 Z9 G7 O0 F& h D, n0 S ≤229 | 5 | W N) j( {. c3 S* W
( }) Q& E: b; b$ ?4 K
820~860 |
5 j4 N& j S% m$ M
Y( e3 g. ~' K$ u, z7 Y/ W ≤269 |
, W, o# @* b: { D
1 O, ~2 q t; c; @
6 `3 l+ {2 K7 g# H! p' O" r 60Si2Mn | $ z( f V# d P
. Z. n3 I% T& x: w3 f6 k 755 | + y5 J6 m$ S; p
- R, q5 P4 G2 ^7 v: l2 O$ i7 T$ P, V5 D 810 |
6 |# u3 ]6 A( u1 G! F) `, t/ v& r
700 | ; `; g* m q+ v/ f7 t7 U% P8 C
% @+ o& T1 }1 j5 C
$ e0 l6 z/ D! p0 Y0 a( ]
3 O- ]* F P; ~/ n8 H# p( b - |
4 O( Q5 w& [8 W" i5 I J
) B3 n. J5 z- X$ Q: k7 e5 ^ - | ' f. y- X8 z1 c/ G* S
# r# v& s7 `( h3 ^1 d8 E1 e% C c
830~860 |
& ^# S1 N4 c6 m7 K5 Y" A$ v# \- l8 ?; Z! G7 p) F
≤245 |
6 S- I# ~0 W& H* y8 N& i8 K' `
$ e9 Z! `1 c3 R' s0 J6 T) S+ V+ q' _6 e f
50CrV |
& q7 o/ t( U1 z- v
* b8 P$ N1 J& o$ p. m 752 |
! V; Z# ~: W! b1 Z" J( v0 V: d* k
. m( N2 M2 K4 f$ ~% J8 J 788 | 8 N# x6 {+ m9 c" ~
a( ^. H7 ~* F1 ~5 d+ m7 |: V, Q 688 | 5 k# w# H; X V' A! A7 j
% g. W( \7 ]) a0 T" q3 q6 N' v - |
9 `# K( d/ ]/ y4 @5 H. e0 c) v% P* U9 a4 L! h- G
5 O6 J. a. X, n( F
0 P& Y1 n- Z( g1 ?; E - |
, p0 W7 c2 Y: g- s/ ~0 o7 H# d( n1 }% w3 w/ U
850~880 |
4 p: J9 T1 B6 ^+ F, Q" y
$ u1 @8 f$ {* Y. S# S0 m, Q" I7 ~ ≤288 |
% }3 [. W' m+ h" F D; B) d
# K3 ]1 \4 q# Z/ W' p3 y2 ^! D% e" l# Z8 ~7 H5 m
20 | + ^+ m1 {0 [- X- o& J
0 o. i+ p2 j3 O. A) y
735 | 0 ?& m$ W( x' u* j
% {) v% L# R( }" x& B8 u
855 |
; }! Z y+ W0 Y6 y4 z
& K2 [. \9 e& ~% J3 U 680 |
, A' s# y# o6 E% A
8 \, i, Y8 Y# I/ b- |" U' H - |
( d) q/ g4 W* l3 {$ p
7 P8 z6 O& j2 A! ?6 d5 F5 e G - | 1 A$ F) |' c/ R
9 F* X l: T8 M - | . H: r( k) `, L- a
$ R* F2 E* G* E+ m 890~920 | ( K4 }% O5 x& g6 v8 V) ~; @
+ j. R4 v4 d- M9 N; Z ≤156 |
" a5 L! ^0 V9 w: z1 ^5 i
7 P* S3 ^. L1 Y }( _3 B9 v% ^) P+ Z; x* H8 j7 C3 T$ p, z7 t
20Cr |
V# N' o: U/ i# H, ^% z5 S
% Y% G/ o. f* V3 X& ]3 d" Z' B( r 766 |
; X8 g# d; z. K- b/ n; y7 `/ f
8 M% H" a; E0 x( O8 } 838 | ; K: m6 y* ]2 G! ^5 Z: \8 G
) R! w) _6 n; b 702 | 1 F" o5 T2 N% }2 U+ V/ c
1 j; U) {6 c( E8 A Z% S* i
860~890 |
9 U7 K( J w/ z0 K- `8 I& g; S
2 W( X) X _% ? b, E 炉冷 | - ?8 O( T$ u; b9 M9 p" r4 U
, W: V/ S+ _) D( x7 e& Z1 [2 Z8 p ≤179 |
& H8 t8 c0 O5 w+ ]6 p* ?
( u' d& v' N2 x6 x 870~900 |
) N$ N! w) c$ L+ Q
: _: N% j6 c3 i+ w+ x ≤270 |
* \1 B5 a- n# ^7 @& _- u+ p
5 H' n2 w; x! e% U# X
* V* o- ]1 W6 q, c 20CrMnTi |
. c+ I X$ s0 h" C1 R* Z( w+ J# E% @2 }3 V7 \; c1 g& P$ K- }
740 |
( b: L. X: n) a/ t* A" r! ]- J p4 W, Y- m8 ?! |! I& \
825 | , X. |/ K- r. T" d- R6 D
3 x) o4 \5 w3 ]4 j! @
650 | $ Y7 } \: n' R- P, i6 }$ ?
5 r; I0 j# K' H' B J, P& J
$ h7 L. m8 t6 I' W
& x, ~ T1 Q4 I2 ? - |
x4 h+ @' z- n: p
/ ^, J- F9 z& ]4 f9 K6 g - | ) ^0 }& A+ G# w5 e
# x/ g7 E( j- a9 b
950~970 |
/ \& q. v' |0 y+ V
: V2 A5 O/ V# d1 e+ G 156~207 |
/ }, n3 ~: s# y: Q: W
- E) U, H5 O& e- ~
2 M2 g$ G2 Q4 d w7 Q 20CrMnMo | + M2 R9 V8 {# [8 M; Z" v6 v5 R
9 w1 {3 ?* e1 {2 L; p4 m 710 | ! C* G& @) e$ a3 ]( F8 I5 Z
& d; ^* B4 s2 X& M3 W" r) q 830 | 6 [/ |! S( I1 w3 g" t& I
3 O9 T# F5 q5 O/ J
620 | , P1 J6 C+ S& \0 }
& F0 K7 i' a! e0 R
850~870 | % ~- a0 p s' o- k
; k" V4 ]) z! w, i v+ ^
炉冷 | 3 h* A* _- R! c h9 R, g
1 F/ _7 [2 S! f% s4 W3 S ≤217 | 7 _ w7 i. ^3 F+ a$ ^* `* `* k7 q
. T$ s4 K+ r" [# g) v o4 _ 870~900 | # |* a8 P) H1 z6 B1 a* }
% k" R4 H: f/ Y$ K3 m: k - |
1 j7 W$ s) ~) N+ U* w* A, C$ o: z8 r7 N1 J! E1 l+ Y2 G" u* _9 K
4 F% r/ C2 e6 ^, e8 J6 K; H 38CrMoA1A |
+ j+ D- P. @! p6 f) u: q Y$ H
1 U+ l" A1 | P0 {+ {( Z. G 800 | & U3 \6 g1 g) B7 X
8 [4 H) c! A/ {( W/ V7 v s
940 |
8 t5 ~# @: r; b! L$ |$ v' P6 S1 Z6 k8 ?+ a
730 | ' \. d' V) o" m
7 x* n: L o% ~# H3 ]0 Q( u# k" w, _5 i
840~870 |
0 T/ h1 [; I8 k) N& ^* u6 v# E$ n9 Q" q5 F4 ^
炉冷 |
5 K1 z8 E) E0 J) j5 T( N) y- E/ N/ k* d: ?% v1 Z1 n+ f
≤229 | 4 `1 n0 Z4 [ G) e
: W. E1 _% N8 n9 X* r
930~970 | + b1 k8 `. V6 R# l9 ^6 D# O
# f- j& E9 a. D' o3 W& H2 {8 V - |
