查看: 4733|回复: 9
找人帮忙翻译一段关于模具的英文文献,谢谢啦!
发表于 2011-1-4 12:33:10 | 显示全部楼层 |阅读模式
本帖最后由 a64578626 于 2011-1-4 12:35 编辑 2 k8 n/ v' ~1 ]  `) g6 ~- m4 B
! X+ n: g( a) [; }% i, h" M' L# |; j      The plastic-injection process is one of the important manufacturing methods to polymers, which provides products with high dimensional steadiness, low manufacture cycles and costs. One of the problems affected on the quality of the final product is the gas entrapments occurred in the mold filling stage. Generally,the residual gas in mould is exhausted through the venting system.However, the dependence on the venting system complicates the mould design. Furthermore in certain condition, it is difficult to integrate the venting system into the mould. Now this problem can be avoided by using permeable steel to make mould or mould inserts. With permeable steel, gas generated in the mould cavity can be exhausted directly through the micro-holes of the mould and the venting system is unnecessary anymore. Moreover, the mould structure and design becomes simple, whereas the venting and aspirating function is preserved. Many researchers have been attracted by permeable metal’s forming, measurements and applications. ZHANG,studied the effects of warm compaction on fabrication of porous iron and adopted macromolecule polymer to generate porous in permeable iron. NORMITUS,investigated the effects of partially alloyed and prealloyedpowders with different compositions of alloying elements and compacting pressure on the Young’s modulus and Poisson’s ratio of sintered low alloy steel.ZHANG, chose NH4HCO3 to generate porous in NiTi shape memory alloys and formed gradient porosity by changing the amount of NH4HCO3 added. LIN, analyzed the effects of sintering processing parameters and compaction pressure on the filtration performances of stainless steel porous metal. ZHOU, investigated the reason of porosity formation, effect of pressure on porosity and linking of pores in metallic porous material.
' X2 `# ~4 E+ T- o, t% r+ h      However, though permeable steel is very important for making plastic-injection mould, how to obtain proper permeable steel, apply it into plastic-injection process, and retain the permeability after secondary machining haven’t been well studied. In this work, a kind of permeable steel was obtained by controlling the compact and sintering processes. The details of these processes were presented in section 2. Section 3 demonstrates the permeability of this material through macroscopic experiments, microscopic metallographs and scanning electron microscope(SEM) images. Since most plastic-injection moulds require secondary machining, the effect of different machining methods on the permeability of porous material is also presented in section 3. In section 4, the permeable mould was used along with an injection set to make real plastic-injection parts. The high quality of the parts further validated the good permeability and venting function of this permeable steel.6 [7 b, w3 n5 s; D% G0 ^5 a% \
下面这是整篇文章,呵呵     ; P, c8 r% F; p: k3 Q! ~% W
- `; P  M: `  I$ [$ `; J
" C/ k( q! _& Q# a; m4 s
: L' f& m' a8 I; ?4 {0 O7 v
您需要 登录 才可以下载或查看,没有账号?注册会员
发表于 2011-1-4 13:02:27 | 显示全部楼层
本帖最后由 peace80 于 2011-1-4 13:24 编辑 : Z8 d0 i8 l3 k; I' x% f
; K: g9 G+ a) z" L+ E& J) N' p注塑工艺是聚合物重要的制造方法之一,这种聚合物提供了生产周期短和成本低廉的高稳定性产品。影响到最终产品质量的其中一个问题是在模具灌浆期发生气体截留。
" X- t3 k$ X& z0 s# A6 U0 q  H
7 _0 p+ D& j8 b. p" t-------------------------
4 H! e+ M7 C% G5 N+ Q/ m8 C百度+谷歌两大利器的结果,沾不沾点边阿。
还不错啊  发表于 2012-2-29 17:28
 楼主| 发表于 2011-1-4 18:06:17 | 显示全部楼层
呵呵,不过你整理的不错了,我用机器翻译时根本不搭边
发表于 2011-1-12 13:57:17 | 显示全部楼层
你整理的不错了继续发展
发表于 2011-5-30 16:58:45 | 显示全部楼层
要的就是这个,谢谢LZ,等我先去加威望后来下载
发表于 2011-5-30 17:44:34 | 显示全部楼层
太专业了,看不懂,请高人帮忙了
发表于 2011-5-31 18:40:08 | 显示全部楼层
这东西  自己翻译就是了  还上来找别人
发表于 2011-6-3 11:36:36 | 显示全部楼层
真的看不懂啊...郁闷了..
发表于 2012-2-23 20:46:38 | 显示全部楼层
很好的资料啊。学习学习
发表于 2014-7-24 20:09:54 | 显示全部楼层
威望不够额
GMT+8, 2025-10-20 13:34 , Processed in 0.079639 second(s), 18 queries , Gzip On.
